bad Dell 1504p monitor
  • badcap400
    • Sep 2015
    • 13
    • usa
    Hello all, I have a bad Dell 1504p monitor. It has no power led response whatsoever after the office had a power hit/surge. When I opened it up, I found a bad CapXon 100uf / 400v capacitor that had popped its top. Fast and easy, I figured, simple replacement. So I got a nice spare Nichicon unit in place, put the thing back together as nothing else appeared bad. However, I wasn't sure since many people have posted about problems with the daughterboards / mosfets on these. And, unfortunately, when I plugged it in, nothing happens.
    So, I suppose that there are probably some bad diodes / fets on this thing; is it worth it to find a used power board (~20-30 bucks it seems) or should I just debug and replace the parts on the power board individually given that it took a power hit of some kind? BTW, it was running on a reasonably current (18 month old Monster) surge protected strip; the power hit damaged some other gear also, even gear running on power conditioners (although they were old gear as well).
  • Davi.p
    • Sep 2009
    • 4266
    • Italy - Milan
    Re: bad Dell 1504p monitor
    What do you meean for "(18 month old Monster)"?
    You probably have some bad compo on the primary side of the power circuitry, for example the diode bridge "rectifier", or worst case, a bad glass fuse accompanied by bad big mosfet, Rsense, maybe IC, connected discretes, maybe other.. check them..
      "(18 month old Monster) surge protected strip" It is an AC outlet strip with surge protection made by Monster Cable company.
      How about upload good clear pictures of the boards?
      What DCV do you have (measured between the two legs of that main filter cap) on that cap you replaced? It should have around 160~170VDC.
      • badcap400
        • Sep 2015
        • 13
        • usa
        Ok, I'll have to take some time out to get the pix. I might be able to get the old cap out of the trash still. And I'll have to buckle down to get those measurements, have to get the daily essentials out of the way (kids and all!). Should that main cap DCV be measured while powered on or powered off-disconnected. It's a pain to flip the powerboard out of the mount and still have power on.
          You will be making DCV measurement in the PRIMARY DEADLY side of the circuit, when making Voltage measurement, the board must be plugged into the AC outlet otherwise you will not have the Voltage to measure, when taking resistance reading, no power will be applied.
          If you are not sure about safety precaution required when working in the primary side then I will suggest you not to do it.
          The main filter cap 100uf 400VDC is laying on its side isn't it?
          • badcap400
            • Sep 2015
            • 13
            • usa
            Yes, the 400vdc is laying on its side. I'll be careful when measuring; it's just that the way the board is arranged in the unit, it's 1 of 3 separate boards and it has to be exposed in order to see the correct leads. Could be done from the back....just a bit of a pain because of the way of the whole arrangement is.
            Actually, I could just pull the thing out entirely, separate it from everything else like the daughter and logic board, and then just power it while it's on my test bench by itself. Not having any load on it, wouldn't be a big deal?
              You can run the power supply/inverter board by itself to make sure it has DC outouts, it is an always ON power supply.
              • badcap400
                • Sep 2015
                • 13
                • usa
                Ok, so I pulled it apart again and measured the 400v cap legs at 165.1vdc. Will upload some pix in a bit. Maybe the transformers? The boards look ok in general; no burnt crud or darkened bits. Only the epoxy on the 400v cap was dark. Will post a pic of the bad cap too.
                • badcap400
                  • Sep 2015
                  • 13
                  • usa
                  ok, well, posted too soon. Looks like the inverter board has at least 1 probable bad transformer which was hidden by a plastic film cover. Here's the pix :
                  I took a shot of the edge of the inverter board where some translucent clear crud appears to have leaked from one of the transformers. In addition, on both transformers where there are 2 blue poly caps (HF224 / HC5012A), there's some dark brown discolored material between the caps and the transformers. Probably have to replace the whole thing as I wonder if the transistors on the other side are messed up.
                  On the power supply board, the big brown cap in the middle is the one I replaced which shows 165v.
                  Thoughts?
                    "I took a shot of the edge of the inverter board where some translucent clear crud appears to have leaked from one of the transformers." Those are just flux.
                    What DCV do you have on the pins of the white connector CN2?
                    • badcap400
                      • Sep 2015
                      • 13
                      • usa
                      ok, white pins from right to left (ie from the 1st pin next to the grey pin) 0v, 13.2v, 13.2v,13.2v, 13.2v, 9.7v
                      • Bowline
                        by Bowline
                        06-11-2025, 10:13 AM
                      • DanPoka
                        Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
                        by DanPoka
                        I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
                        Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
                        This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
                        02-15-2025, 05:05 AM
                        by momaka
                        03-15-2023, 10:17 PM
                      • Jesus Coder
                        Issues Reviving Old Dell 2408WFPb Monitor
                        by Jesus Coder
                        I have been having some difficulties reviving an old Dell 2408WFPb PC monitor that I received for free. When I first acquired it, the backlights of the display were on but alas no image was showing. After extensive research on the topic, I went ahead and purchased a new t-con board for the monitor. After installing the board, I was then presented with a new screen that was half black and half green (more so black). I have been unable to figure out what to do next as I have limited knowledge of display electronics. Might anyone on this forum have an idea of what may...
                        06-25-2023, 02:33 PM
                      • ChristianBr01
                        Dell 34 inch U3419W Monitor with thin stripes on partial screen
                        by ChristianBr01
                        I have a Dell U3419W Monitor that has some thin stripes on a part of the screen since Tuesday.
                        This lines cover about a third of the screen and appear for 2 seconds before disappear for another 2 seconds.
                        This repeats the whole time. I have not opened the case yet cause I had no time, but will try to fix it on this weekend. For me, it looks like a problem on the TCon... Am I right?
                        Does someone have seen this before?...
                        05-23-2025, 06:06 AM
