ccfl change guide - search for
  • ttmi100x
    HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
    by ttmi100x
    Greetings everyone,
    I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
    The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
    Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
    Upon closer inspection...
    07-31-2024, 06:36 PM
  • DanPoka
    by DanPoka
    02-15-2025, 05:05 AM
  • mikey5791
    Help on Samsung Syncmaster T220 dead ccfl lamp
    by mikey5791
    This monitor previously is my main working monitor which i have been using for 8~9 years. Yesterday, when i switched on my pc from fresh to power on, the monitor is just black no display. I started dismantle to look inside the monitor power board but nothing looks suspicious or burnt. So i took my external ccfl inverter to try to power the monitor ccfl lamps which consisted of 2 lamps on upper part and 2 lamps on the lower part.
    Found out the upper ccfl lamp which is supposed to connect to cn304 on the power board did not light up. Then i installed a used working...
    10-18-2020, 03:17 AM
  • Verlengsnoer
    Bios splash/logo change
    by Verlengsnoer
    at firs, i hope this is the right place to post my question.
    Im looking for a tool to change the bios logo.
    everyone knows when you turn on your laptop/pc you will see the manufacturer logo like lenovo, hp, dell...
    i know that HP has a build in option to change the splash logo.
    but i want to change the manufacturer logo to an own logo.
    I try'd Change Logo 5.0, but when i make a backup of an laptop and edit the logo and flash the editted version back on the laptop the logo diddnt change.
    10-28-2022, 09:52 AM
  • lukkihapsi
    Asus Vivobook X515JA Weird Boot Issue
    by lukkihapsi
    Asus Vivobook X515JA Laptop
    Issue :
    Upon turning laptop ON, screen lights up - stays black & about 30+ minutes later ASUS logo is shown & boots to windows, then laptop works fine.
    Tried :
    Cleaned inside for dust, applied fresh thermal paste. No Change!
    Removed keyboard, Trackpad, fingerprint sensor. No Change!
    Removed Internal SSD. No Change!
    Updated BIOS to latest version. No Change!
    Removed battery and pressing power button for 1 minute. No Change!
    Weird Part :
    Upon turning laptop ON, screen lights up - stays black,
    I...
    07-07-2025, 12:07 PM
