2 Secs 2 Black- Dont belive what you see
  • maxcap
    • Sep 2015
    • 6
    • From UK temp in greece
    Hi Im new here and I wish I found this forum earlier as it has some supper info and guides, thanks for those that took the time to write them.
    My 2secs to black problem (2S2B) is/was on an LG Flaton W1946.
    My visual and nasal board inspection found no tale tale signs of heat damage to circuitry or capacitor leakage/bulges.
    With the set striped down I powered up with all the components laid out on the floor (granite tiles) and still got 2S2B even with LCD ribbon disconnected.
    At this time the cfls were still in the frame I had not removed them.
    The cfls looked in order with no signs of potential issues looking good so attention went to the cfl wiring but found no evidence.
    So back to the PCB main board using a usb microscope inspected for dry joints,foil lift offs ect.
    Nothing suspect.
    Inverter coil was showing a 0.845 Kohm reading I asked in the forum on a thread if this was OK.
    I decided to remove the cfls all together from the frame but this time when powering on with components laid out on the floor when I started lightly prodding taping the ends I heard a faint arching noise on the rear end of the top tube and the cfls stayed on this time.
    looking at the end rubber grommet it was not discoloured or showing any sign of internal issues so I removed it gently ( power off :-) ) and found the wire barely connected and the insulation had melted slightly but this was not evident with the small white rubber grommet in place.
    Now that has been solder back on and checked before assembly I let it run powered up for about 30mins for any issues before reassembly.
    What I want to say to the forum is don't believe what you see on the surface because If I never removed the cfls completely I would have never found the issue so quick and may have even started to replace CAPS.
    In the future I will always remove the cfls for total close inspection before ruling them out and as I never had a test cfl I might have saved some time.
    So my understanding is there is a sniffer circuitry that detects issues with the cfls before they can overheat and cause a fire.
    Am I correct on this?
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    Re: 2 Secs 2 Black- Dont belive what you see
    Yes. Inverters have extensive protection circuitry to reduce chances of electric arcs that could potentially melt something or cause a fire.
    A working TV? How boring!
      "I decided to remove the cfls all together from the frame but this time when powering on with components laid out on the floor when I started lightly prodding taping the ends I heard a faint arching noise on the rear end of the top tube and the cfls stayed on this time.
      In the future I will always remove the cfls for total close inspection before ruling them out and as I never had a test cfl I might have saved some time."
      That is why if you are going to work on lots of monitor, you should have test lamps so you do not waste time troubleshooting the board.
      https://www.badcaps.net/forum/showthread.php?t=19987
      What you find on the lamp assembly is one of the common failure.
      http://s807.photobucket.com/user/bud...?sort=3&page=1
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8331
        I fixed a few little TV's and monitors that had that exact same problem.
        • SoulFreeze
          Audio Issues - Realtek ALC3306 - Lenovo Slim Pro 7 14ARP8 - Type 83AX
          by SoulFreeze
          Hi, trying to troubleshoot some problems with this laptop I just finished repairing which had power issues (Burnt Buck converter - SY8883DFC shorted to ground).
          After repairing the above issue, I realized the following remaining problem,
          Sound only comes from bottom speakers, top palmrest speakers don't work. Neither does the headphone jack (static/buzzing).
          The computer recognizes headphones are connected and displays a popup in windows
          Sometimes, the computer will boot up and the sound will be working fine. However, if I run intensive programs and the computer...
          06-21-2025, 09:53 AM
        • Nagyesz
          Lenovo IdeaPad Gaming 3 15ACH - Ideapad 3 well known solder joint issues
          by Nagyesz
          I have a Lenovo IdeaPad Gaming 3 15ACH, which has started exhibiting the well-known issues of the Lenovo IdeaPad 3.
          All stress tests run perfectly, and there are no performance issues. However, the solder joints are almost certainly starting to fail. If the top two screws on the back are not screwed in, moving the screen results in a BSOD or, in some cases, a slight artifact and freeze. This is a 2023 notebook..
          How can I extend its lifespan? Could reflow help?
          It has ryzen 5 5500h, rtx 2050, no soldered ram.
          Example of the artifacts:
          03-01-2025, 11:11 AM
        • pwnjuice
          Bitlocker issues
          by pwnjuice
          Customers laptop had a Motherboard go bad and replaced it. they want to try to get data but. I am having bitlocker issues. I will list below
          Issue 1: When connect the drive to my computer to decrypt it I get this message. "there are no supported protectors on this drive the drive cannot be unlocked"
          Issue 2: When I run powershell as admin and try manage-bde -protectors -get e: I get this message. " ERROR: An attempt to access a required resource was denied. I also get the same error when I try manage-bde -status e: When I try the same with terminal with
          01-06-2025, 05:33 PM
        • Skgod
          Asus Rog strix g15 g513ih hn0865 and it's having display issues while running on igpu
          by Skgod
          Hey I am having Asus Rog strix g15 g513ih hn0865 and it's having display issues while running on igpu. Works fine when I open any game or whatsapp windows application. The issues are :
          Black screen, freeze
          The weird thing is that when as long as the laptop is running on igpu the problem keeps happening. But as soon as I open any game or whatsapp windows application, the laptop works completely fine.
          When the screen freeze or black screen I used to move the display lid up and down and it usually works like that.
          So can anyone tell me what would be the possible cause?...
          10-16-2024, 08:11 PM
        • duwane
          A2141 (2019 16" MB Pro) Strange macOS install issues. NAND? WIFI? FIRMWARE?
          by duwane
          Hi All.
          Sorry ahead of time for the text wall. This is a strange problem and I have tried to explain it as best I can. I realise this is a hardware forum (mostly), but I am still not sure if this is even a hardware fault! I am hoping that someone more knowledgeable than me in the area of understanding installation logs, or someone that has had a similar issue in the past may have some ideas of what might be causing this.
          The issue:
          Unable to do a clean install of any macOS versions supported for this model, even after fully erasing and formatting the internal SSD,...
          10-26-2022, 07:02 AM
