Daewoo LM2230W monitor
  • matthmal
    • Nov 2012
    • 306
    • Malta
    I have a Daewoo LM2230W monitor which was working fine till a few days ago. The monitor turns the screen black after a few minutes of use. The Power LED remains on and if I disconnect the VGA and re-connect it again it works again for a few minutes.
    Any clue of what could be wrong with my monitor pls?
    Regards,
    Matt
    Re: Daewoo LM2230W monitor
    You can start with this:
    https://www.badcaps.net/forum/showthread.php?t=39740
    • matthmal
      • Nov 2012
      • 306
      • Malta
      Apologies.... kindly find attached the photos of the boards from front and back
      • matthmal
        • Nov 2012
        • 306
        • Malta
        Any suggestions please?
        Thanks,
        Matt
        • Agent24
          I see dead caps
          • Oct 2007
          • 4951
          • New Zealand
          Have you checked if the image is still on the screen when it goes black? Shine a bright torch onto the panel and see if you can see the picture. You may need to wait for night or do it in a darkened room.
          If the power LED is still on but the screen goes dark, it is likely the backlights are shutting down while the image processor is still working.
          -David VanHorn
          • matthmal
            • Nov 2012
            • 306
            • Malta
            I haven't checked that yet, will check and will let you know
            • matthmal
              • Nov 2012
              • 306
              • Malta
              Hi, I checked the monitor as you said and unfortunately i cannot see anything with a torch
              • matthmal
                • Nov 2012
                • 306
                • Malta
                any help please? i really need to fix this monitor.
                  What DCV do you have on that white connector CN2 of the power supply/inverter board when the monitor stop working? You may have lamp problems, you can try turning down the brightness as low as possible to see if the backlights will stay on longer.
                  12V =
                  5V =
                  5V =
                  GND
                  GND
                  ON =
                  DIM =
                  • matthmal
                    • Nov 2012
                    • 306
                    • Malta
                    12V =
                    5V =
                    5V =
                    GND
                    GND
                    ON =
                    DIM =
                    You were right, turning down the brightness as low as possible does make a difference. It stays longer twice the time. Will try to get the readings tonight.
                    Thanks for your help, will keep you posted
                      by momaka
                      03-15-2023, 10:17 PM
                    • wattage
                      AOC AG493UCX 49-inch monitor - Firmware request
                      by wattage
                      Hello Badcaps Community,
                      The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...
                      07-13-2025, 04:41 PM
                    • ant3202
                      HP 27es - LED monitor - Monitor Flashing On - Off
                      by ant3202
                      Hi Everyone
                      Lately I am experiencing the deja-vu incident on one of the led monitor like this.
                      https://www.badcaps.net/forum/troubl...lashing-on-off
                      The monitor is HP 27es LED Monitor
                      https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
                      The monitor will randomly blackout and display no signal and will recover again.
                      Sometimes need to power and off again to restore the display but...
                      03-20-2025, 07:30 PM
                    • Rick_1234
                      LG 23MP55HQ LED Monitor turns off after a few seconds or flickers.
                      by Rick_1234
                      Good evening, gentlemen.
                      I have a problem with my monitor. It turns off after a few seconds or flickers. Shining a flashlight on the screen doesn't show any image, so I guess it's not the "2 seconds to dark" I read in the forum.
                      To turn it back on, I have to press the power button twice. Then after a few seconds it turns off again or flickers. See video.
                      https://drive.google.com/file/d/1L6S...ew?usp=sharing
                      Things I tried
                      - Bought a new AC adapter thinking that was the problem but the problem...
                      06-22-2024, 04:44 PM
                      Wise Wing F199 19'' LCD monitor - recapped
                      by momaka
                      Looking through my repair pictures and notes, it's been a long time since I posted anything in the LCD monitors section. So here goes that.
                      I'm dedicating this thread to one of the very first LCD monitors I repaired (if not the first one), which was more than 10 years ago now. The monitor is a Wise Wing, model F199. It's a 19” CFL-backlit LCD. I got it for free off of Craigslist in 2009 from a guy, who said he bought it for cheap from Wallmart and the monitor worked only for a little less than 2 years before quitting.
                      When I saw the Craigslist post, I wasn't...
                      08-24-2020, 10:58 AM
