Compaq CO1075 LCD With Green Tint
  • bgavin
    • Jan 2007
    • 1355
    This is my first LCD disassembly.
    The monitor is still working, but static images on the screen have an animated appearance, like the pixels are alive and chattering about. Booting the machine shows the normal black POST screen as very green.
    The two-part board has three CapXon 330uF/25v and two 180uF/25v of unknown parentage on the smaller daughter board. The daughter board has two transformers and appears to be the high voltage board. The primary board has the wall-wart and VGA connector inputs.
    This was mostly an exercise in lookey-see rather than attempting a repair. I'm just curious if bad caps could cause the above symptoms, if if the cause is deeper in. I know zilch about display service techniques.
  • PedroDaGr8
    • Oct 2006
    • 130
    Re: Compaq CO1075 LCD With Green Tint
    Did you try a different video cable? or by POST do you mean the monitors own post screen (if it has one)? A bad video cable can cause a color shift, while the moving pixel phenomenon can be caused by a dirty analogue signal, see a long video cable that goes near some other power circuitry and you will see what I mean.
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      The smaller board with xfmers is the inverter for the back-light.
      It is a high voltage board.
      A color shift usually indicates a problem in the inverter.
      The other problems sound like the video section which has nothing to do with the inverter except maybe sharing a power supply.
      Yes bad caps could cause those problems in either board.
      My experience is with LCD's is 99% fixing laptop screens and with those (don't say it!) I'm a Black-Box Tech. I just replace the whole inverter. Don't fix'em. They are too small for my eyes.
      If you jingle Davmax he is good with inverters.
      Mann-Made Global Warming.
      - Dr Seuss
      • davmax
        • Dec 2005
        • 899
        Typically the back lighting tubes work or don't. Lamp or inverter. One lamp can go the other still OK and leaves part of screen dull. Colour problems need swapping in another screen to check if cable or graphics card is the problem. If it proves to be the monitor then the video/ colour processing PCB is more suspect than back lighting. This can be affected by cap problems.
        Gigabyte EP45-DS3L Ultra Reliable (Power saver)
        Intel E8400 (3000Mhz) Bios temps. 4096Mb 800Mhz DDR2 Corsair XMS2 4-4-4-12
        160Gb WD SATAII Server grade
        Nvidia 8500GT 256Mb
        160Gb WD eSATAII Server grade for backup.
        Samsung 18x DVD writer
        Pioneer 16x DVD writer + 6x Dual layer
        33 way card reader
        Windows XP Pro SP3
        Thermaltake Matrix case with 430W Silent Power
        17" Benq FP737s LCD monitor
        HP Officejet Pro K5300 with refillable tanks
        • bgavin
          • Jan 2007
          • 1355
          I replaced this defective screen in a client machine with a new flat panel. For convenience sake (hidden wiring), I used the same analog VGA cable on both displays. The problem is confined to the failing Compaq unit. The new Dell screen looks great, and on the same cable.
          The unknown 180uF caps are on the inverter board with the transformers. The CapXon caps on the primary board.
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            What I tried to say before is that I think it has at least two separate problems and at least on each in the inverter and the video section.
            A green or red tint is usually an inverter problem.
            Bad power to the tubes.
            Much less often but it could be bad tubes.
            The jittery image doesn't have anything to do with the backlight circuit (where the inverter is) so that's a separate problem on the video board.
            - Dr Seuss
            • davmax
              • Dec 2005
              • 899
              That input interests me. How do back lights go green? Being fluorescent they are UV that causes the glass coating to flouresce, usually a colour determined by the coating. what experience did you have where this happened?
              Nvidia 8500GT 256Mb
              33 way card reader
              Windows XP Pro SP3
              • kc8adu
                • Nov 2003
                • 8832
                • U.S.A!
                the inverter wont cause color shift.
                failing ccfl tubes are often pink or orangered when they are cold.
                the mercury is tied up in the electrodes and phosphor.
                with no reserve due to laws about hg content we now see this type of failure.
                goes for standard fluorescent tubes too.
                used to be cathode or phosphor wearout were the normal failure.
