No 5V on inverter board of Dell 2007FPb
  • tommy_b
    • Feb 2015
    • 11
    First time posting here, and I know I am not following protocol at the moment by not providing pics, but I was wondering if anyone is familiar with the circuits of the inverter board for a Dell 2007FPb monitor. I am not able to get the backlights to light up (although, on occasion, I have seen the Dell logo for a second or two before it fades to black). Normally the display is just black (no flashes or anything), and the two green LEDs are lit.
    I've already recapped with Panasonic FM and FC series caps, to no avail. I also replaced the power supply board with an external laptop power supply (19.5V), as I wasn't seeing 19V out of the power supply board. After poking around on the USB board, I do see that there are 5V, 3.3V, 2.5V, and 1.8V being produced. However, I do not see 5V on the inverter board to run the 20-pin PWM chip (OZ964GN PWM Controller) (i.e., the 5V supply pin, pin 5 - Vdda, is measuring 0.9V. That would explain why no backlights). It seems like the inverter board must be designed to produce the 5V locally, but am not sure. The Vdda pin is connected directly to a diode (perhaps a 5V zener?), but other than that I haven't attempted yet to trace out the circuit.
    Does anyone happen to know how the 5V for the PWM Controller is generated? Am I perhaps mistaken and 5V should be coming in externally from one of the other boards?
    I will try to get some pics of the boards posted later.
    Re: No 5V on inverter board of Dell 2007FPb
    The PICO fuse on the inverter board is OK? What is the DCV feeding the Inverter board?
    • tommy_b
      • Feb 2015
      • 11
      budm, many thanks for the quick response. I believe the PICO fuse is OK, as it measures 0.3 ohms across. (The PICO fuse is FP801, yellow resistor-looking part near the edge of board, yes?). The primary DCV is ~19.5V (I think it's supposed to be 19V nominally, by design).
      I'm beginning to suspect that the 5V is supposed to be supplied from the USB board to the inverter board, but its not making it out of the USB board for some reason. (Makes sense logically). I've identified three signals (TP716, TP714, TP713) that originate at the USB board and terminate at the inverter board (they're simply routed via visible copper traces from the USB connector to the inverter connector on the original Power Supply board. Since I'm not using the original Power Supply board, I've temporarily hand-wired these Test Point connections between the USB board and inverter board. I'm 99.9% sure the connections are wired correctly).
      I just went back and measured each of the above Test Points and noticed that there is 3.3V on one of the pins, and the other two are at 0V. Maybe those other two pins are supposed to be 5V and ground? I will have to see if I can find a path from the 5V rail on the USB board to one of those connector pins. Maybe there's an open resistor or something in the path. Having a schematic sure would help. :-) Do you know anything about the USB board circuit that may be of help? Sure would be appreciated.
        Can you tell me what DCV you have on all the pins of the connector of the power supply board to goes to the inverter board?
        Those pins with small traces are for BL-ON, DIM, the third one I do not know what that pin is, are those the pins you test?
        I do not believe the 5V is fed to the inverter board, it probably has its own drop down voltage regulator to convert 19VDC to lower Voltage to run the IC, that is how most the inverter boards I work on use.
        • tommy_b
          • Feb 2015
          • 11
          The pins on the inverter connector measure:
          1,2,3 = 19V
          4,5,6 = Ground
          7 = 0V
          8 = 3.3V
          9 = 0V
          I started to trace pins 7,8,9 on the inverter board and you seem to be correct about the 5V being generated on the inverter board. I only have a partial schematic sketched out (and it ain't pretty yet), but its starting to look like the 5V is generated off of the 19V input, as you said. I almost have enough traced out to determine how the 5V is generated, so I will post that portion of the schematic when I get it cleaned up. Might be helpful to others.
          Thanks for letting me know about the BL-ON and DIM signals.
            Pin 8 is probably the BL-ON pin.
            You may be able to trace out VDDA pin of the IC to see if it goes to pin 7 or pin 9.
            I can look at my board (need to find it first) to to see what is going on.
            • tommy_b
              • Feb 2015
              • 11
              I've got a good part of the circuit traced out, but not sure how accurate it is. However, now I've got a new problem. My external 19V power supply is shutting down, I presume due to overcurrent. I measured ohms between the 19V and Ground pins on the inverter board connector and am getting 3.5 ohms (~5.5 Amps). My external power supply can only go to about 4.25 Amps at 19/20 volts.
              Don't know what changed, as I was mostly just poking around with the DMM with power off. Before this, the external 19V power supply was staying on and I was measuring 19.5V. I wonder if I poked a bad solder joint with the DMM probe and made it reconnect again, such that it's now drawing a normal level of currrent (5.5A) from the 19V supply, whereas before it was drawing less. Arrrrggh! If it does normally draw 5.5A, then I'll need to find a bigger 19V power supply (or maybe I could drop the voltage a bit to get more current? ... my external supply is adjustable from 15V/16V - 19/20V; or maybe I could try fixing the original 19V supply). I'm giving up for tonight, but thanks for your help. Maybe I'll get back to it tomorrow night after work.
              • tommy_b
                • Feb 2015
                • 11
                Just a reminder to myself to try measuring the ohms between 19V and Ground on each board separately, to see how each board (USB or Inverter) is loading down the supply.
                Yeah, that's the ticket! :-)
                • tommy_b
                  • Feb 2015
                  • 11
                  Well, I found a new problem on the inverter board. One of the MOSFET chips (8-pin, dual MOSFETs) now has a short across one of the MOSFET's (gate to drain?). There may also be a short across a 4.7V zener and/or a 5.1K resistor in parallel with the zener (haven't pulled them off to check each one individually yet) that feeds the MOSFET gate pin. The zener and resistor are connected to 19V coming in on the connector, so the short was causing my external power supply to shutdown.
                  Anyone know what the part number is for the dual MOSFET chips? None of the parts on my board have markings. I guess I'll try replacing the bad components and give it another try.
                  • tommy_b
                    • Feb 2015
                    • 11
                    Found the MOSFET part number in another post:
                    p/n: SP8M3 (Rohm)
                    http://www.alldatasheet.net/datashee...HM/SP8M3.html?
                    • tommy_b
                      • Feb 2015
                      • 11
                      I've given up on this monitor (bought another working 2007FPb last night, so my dual monitor setup will soon be complete). Too many problems to debug on this one and no schematic made it too much work. However, I am thinking about converting this one to LED backlighting, since I already have an external power supply that might come in handy for that. Haven't ever disassembled a LCD panel, so that should be fun. :-)
                      Anyway, just wanted to say thanks to Budm for helping me try to debug this unit.
                      • m1ch43lzm
                        by m1ch43lzm
                        05-12-2025, 08:37 PM
                      • Garret Matt.
                        DELL Latitude 5430 Rugged CORE_D5K Rev.A00 Schematic and/or Board View
                        by Garret Matt.
                        I'm Working on replacing an Inductor on this Dell's board and I need to come up with a compatible replacement. As much as I would like to smash a comparable 2R2 in the same spot I'd like to confirm the specs before confirming a killed board. For my purposes I'd be happy with a second opinion on the replacement inductor or the actual schematics/board view. As this is a commonly used Dell Rugged in my local service area, schematics would greatly help in the future.
                        Thank you in advance for any assistance you can render.
                        Inductor In question. Buzzes like...
                        06-20-2025, 01:21 PM
                      • layad
                        Dell Precision 3591 with board number 223092-1
                        by layad
                        I’m repairing a Dell Precision 3591 with board number 223092-1.
                        I need a full BIOS dump (W25Q16 and W25Q512 if available), clean and bootable.
                        The original chips could not back it up as i used 3,3v instead of 1.8v programmer which ,killed the chip
                        bought new empty chip
                        the reason was to remove the bios password
                        Any working dump (from working unit) will help
                        is there anyway to rebuild one from scratch?
                        Dell Precision 3591
                        motherboard 223092-1
                        st 75nbp54
                        is there boot guard in Dell Precision 3591 with board number 223092-1 , which stored...
                        Today, 09:37 AM
                      • howardc64
                        by howardc64
                        07-24-2025, 05:17 PM
