need help with asus vw246h thank you!
  • joeysupra
    • Apr 2015
    • 4
    hello there,
    I have an asus vw246h that ive had for a long time, it does the 2 second power on then shuts off.
    the board on the left is the replacement board on the right is the original. but the replacement board has one more connection on the connector, so what can i do? replace the connection?
    do you guys think its even the board?
    thank you!
  • selldoor
    Slow Learner
    • 7870
    Re: need help with asus vw246h thank you!
    I dont understand what you mean ? board on left cant see the connector but one wire is missing. the board on the right has 12 pins on the connector - all wired
    BUT the items in pic 2 have only 9 or 10 pins??
    Flicker may be more likely to be bulbs or bulb wiring or transformers.
    Find a post by budm in his sig there is a link to making a test bulb from a cfl
    • midibob
      • Nov 2008
      • 285
      I know exactly what you mean!!
      On my VW195 the power board has an 11 way connector but the motherboard only has a 10 way. The extra pin is left blank on the PSU side.
      You would need to confirm the pinouts on yours and I think you may be lucky that the schematic is available on the web for this model.
      As has been said we can't see the end of the other connector so is it a 12 way too?
      If so you may be able to just replace the connector with just the pins it needs. Hopefully the schematic will reveal all.
      Midibob
      • m1ch43lzm
        by m1ch43lzm
        05-12-2025, 08:37 PM
      • howardc64
        by howardc64
        Problem
        08-04-2024, 10:36 PM
      • 5mall5nail5
        Help identifying connector for ASUS 4090 Strix RGB LED connector
        by 5mall5nail5
        Hi All -
        I had replaced my ASUS 4090 Strix cooler with a waterblock and put the stock cooler on the shelf. Was moving it and snagged my sweater on the connector and pulled the wires out of the pins on the RGB connector. I tried to get them back on but its too small so I opened the stamped pins and tried to solder but its not a good repair and the wire broke on reinstallation.
        Looking to replace the connector on the cable side and get pins to crimp onto a new cable. Bought random JST and such but nothing is correct. Can anyone help identify the connector and possibly matching...
        05-04-2025, 07:47 AM
      • k-krzych
        Identify board to board connector
        by k-krzych
        Hello, can you help me with an id of this board to board connector, or the the tiny silicon flat wires for replacement? It is found on GPS unit and connects main board with pushbotton small board....
        07-08-2025, 12:32 PM
