Benq t720 - 0 seconds to black
  • guirnab
    • Apr 2015
    • 13
    • Česká republika
    Hello guys,
    i have Benq T720 (for about 10 years) and it started to suffer from "2s to black"...well, it was more like 500ms to black. I had to turn off and on the display for about 30 times to stop blacking out. Then i found a "fix" - i lowered the brightness to minimum and it just worked®. But now, the display won't light up at all. It's still just the backlight issue - i can see the picture with flashlight.
    I disassebled the LCD and found five 470uF and one 1000uF capacitors visually bad so i bought replacements and replaced them. But it didn't help at all. Could you please point me out where to look next? The board is quite complicated for me. Here is the photo:
    <in attachment>
    I highlighted replaced capacitors with green color. I tested the yellow one on capacitance meter and resoldered it, because it seems to be ok.
    Thanks for any help! :-)
    Re: Benq t720 - 0 seconds to black
    Resolder the joints on the transfomer's legs, transistors/MOSFET, all that area in the inverter section.
    Check the transistiors/MOSFET for shorts or leakage.
    • guirnab
      • Apr 2015
      • 13
      • Česká republika
      Thanks for (quick) reply :-) I tried to resolder everything suspicious with no luck.
      Acording to the 2s-to-black guide I :
      - measured highlighted MOSFETs. Everything has more than 200 ohms.
      - measured secondary windings on highlighted transformers. All four had 750 ohms.
      Any other ideas?:-(
        Are those transistors (4 of them) by the small rectangular grey caps labeled as C5706, C5707?
        • selldoor
          Slow Learner
          • 7870
          After resoldering if there is no flash from the lights check PF751 which I think is a fuse.
          • guirnab
            • Apr 2015
            • 13
            • Česká republika
            yes, C5707
              I forget to tell you to check the fuse F751 for the inverter circuit, when this fuse is bad, it will show 3~4 Ohms, it should be <1 Ohms + your probes resistance.
              • guirnab
                • Apr 2015
                • 13
                • Česká republika
                Thanks guys, I couldn't find the fuse before Well, that may be the case. It definitely has more than 1 Ohm (out of range on multimeter). I guess it won't be easy to find replacement around here and I am afraid to just short it :-)
                I'll try to find some tomorrow.....
                  I believe it just a 2A or 3A fuse (see what is printed on the body) so any 2A or 3A fuse with 25V rating or higher will work. That fuse is made by BEL FUSE.
                  • Lumberjack777
                    • 464
                    In my experience with those BenQ's it's always 1 of those transistors (or mosfets) that has shorted. And that causes the fuse to blow. I'd probably recheck those out of circuit first. Because if he just replaces the fuse; it will probably blow again.
                      • 30911
                      if lowering the brightness made it work then it was detecting a lamp overload.
                      at 10years old, it's probably got bad tubes.
                        Well I did tell him to test those C5706/5707 and the MOSFET,s so hopefully he tested them correctly.
                        • guirnab
                          • Apr 2015
                          • 13
                          • Česká republika
                          I am back. I was at local store, but they had only 2A picofuse (or 5A) and i need 3A. So I bought the 2A and 3,15A (big) tube fuse as backup.
                          First I tried the 2A picofuse. Backlight worked for 1s and then the fuse blew up (yea, I was kind of expecting that, but at least I know the backlight works).
                          Then I soldered in the big 3,15A fuse. I know it's not ideal, but it worked perfectly! (well...for the first try). After I assembled everything back together it stoped working again...but with different symptoms:
                          YouTube video
                          • selldoor
                            Slow Learner
                            • 7870
                            Is it connected to a PC?
                            • guirnab
                              • Apr 2015
                              • 13
                              • Česká republika
                              Not on the video, but it does exactly the same with VGA connected.
                                That looks like the 2-seconds to black, the LED power light stays on but the backlights go off. It can be the lamps or something is still not right in the inverter section.
                                If you have test lamps then it will help narrowing down the cause of the problem.
                                • selldoor
                                  Slow Learner
                                  • 7870
                                  Budm - could it be a faulty startup cap?
                                  • guirnab
                                    • Apr 2015
                                    • 13
                                    • Česká republika
                                    It's not (pure) 2s-to-black. On the video top of the screen is brighter than it should be. I'am afraid to let it turned on for longer than seen on the video...
                                    • guirnab
                                      • Apr 2015
                                      • 13
                                      • Česká republika
                                      Startup cap is the biggest one (150uF 450V)?
                                      • selldoor
                                        Slow Learner
                                        • 7870
                                        No it is a very small one in the primary/hot side often 50v 100uf perhaps one of the 2 green ones bottom right in your picture.
                                        It could be the bulbs as Bud says - tried turning the brightness down again?
                                        • ChIck3n
                                          Dell u2311h 20000 seconds to black issue
                                          by ChIck3n
                                          So I've had this monitor for probably a decade now, and it's finally starting to fail. Began with a little sporadic flickering, then eventually started going black (power LED stays blue, can still see image on screen with flashlight). A power on/off fixes it for a bit, but then it happens again. Once it got to the point I was dealing with this every few minutes, I opened it up and just replaced all the caps (minus the big one) on the power board with new Panasonic ones. All the old caps tested fine on an ESR meter, and this worked for 5 days. But the screen just went black again today, so...
                                          09-09-2024, 11:44 AM
                                        • DrankinSAW
                                          LG 37LG5020 and the tale of 2 seconds to black.
                                          by DrankinSAW
                                          I bought an LG 37LG5020 with a very strange issue.. it turns on, the display looks fine, but still, after 2 seconds, the TV shuts the backlight off..
                                          However, if i leave it plugged in for 20-40min.. the time it takes to shutdown the backlight, doubles (to 4 seconds)..
                                          I bought a new inverter, set to arrive on December 13th
                                          11-22-2023, 01:10 PM
                                          HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera EliteDesk 800 i7-7700 Specification for Upgrade or Repair
                                          This specification for the HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera boardview and EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our...
                                          09-12-2024, 02:00 PM
                                          MSI Cubi N 8GL-063DE/N4000/4GB/W10P/Black N4000 Specification for Upgrade or Repair
                                          This specification for the MSI Cubi N 8GL-063DE/N4000/4GB/W10P/Black can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Cubi N 8GL-063DE/N4000/4GB/W10P/Black boardview and Cubi N 8GL-063DE/N4000/4GB/W10P/Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                                          09-12-2024, 01:58 PM
                                          Acer Aspire Acer Aspire 7 Charcoal Black Notebook 7 Specification for Upgrade or Repair
                                          This specification for the Acer Aspire Acer Aspire 7 Charcoal Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 7 Charcoal Black boardview and Acer Aspire 7 Charcoal Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                          09-07-2024, 05:00 AM
