Benq t720 - 0 seconds to black
+ More Options
Posts
    Re: Benq t720 - 0 seconds to black
    Well, I see on the video, you hit the power switch, the LED turns green and then the screen lights up with BENQ on the screen, then the screen turns dark and flicker back on for seconds and goes black again and but the green LED is still on solid during all these times. If it is startup cap, the power supply would have cycle off and the LED would have blink.
    I also notice that the bottom left of the screen is not as bright as the right side. I still suspect the lamps or the inverter problem.
    • selldoor
      Slow Learner
      • Dec 2010
      • 7870
      I have also been looking again at the video it is as you say also I have paused it and
      the bottom left also looks a bit pink ( another sign of a faulty bulb)- well does to me though I dont know what the Benq start screen looks like.
      I did have a monitor that did this once and took me two or three goes at reflowing the inverter joints to get it going.
      If you dont have spare bulbs perhaps try changing the leads from bulb to bulb - that is to say change the leads around on the power board swap the tow at the top in your picture for the two at the bottom.
        Or make two of these test lamps.
        • selldoor
          Slow Learner
          • Dec 2010
          • 7870
          Yes - he means these:
          https://www.badcaps.net/forum/showthr...er+testing+cfl
          • guirnab
            • Apr 2015
            • 13
            • Česká republika
            I tried to turn it on again (with PC connected). Something is not right. If I remember correctly, the Benq logo sould dissapear right away. It seems to me that its there for too long now.
            Btw, its not perfectly visible on the video, but the second "flash" is brighter than the first one...
            And after the second "flash" I think it's not displaying any image (from PC). I tried to shine a flashlight on it while moving notepad window (that worked before )
            Well, I have here another LCD monitor (LG Flatron L206WU). Do you think I could connect the lamps to it and its lamps to the Benq board to cross check it? I don't know if it is "compatible" - I don't want to break another monitor
            • Lumberjack777
              • Dec 2010
              • 464
              #26
              As long as the lamps are about the same size, or a little longer, it won't hurt anything. Just make sure the thick wire, and the thin wire, are the same where you plug it in, as the original lamps.
              I'd maybe recheck those 4 transistors (c5707) and the 2 mosfets because that's been the case in 99% of those Benq's I repaired. Once the transistor shorts, it takes out the fuse with it. But it wouldn't hurt to check the lamps I suppose.
              • Agent24
                I see dead caps
                • Oct 2007
                • 5016
                • New Zealand
                #27
                Could very well be the lamps.
                If you have another inverter you can test the lamps on that, too. Pink tint or flickering and they're bad for sure.
                -David VanHorn
                • ChIck3n
                  Dell u2311h 20000 seconds to black issue
                  by ChIck3n
                  So I've had this monitor for probably a decade now, and it's finally starting to fail. Began with a little sporadic flickering, then eventually started going black (power LED stays blue, can still see image on screen with flashlight). A power on/off fixes it for a bit, but then it happens again. Once it got to the point I was dealing with this every few minutes, I opened it up and just replaced all the caps (minus the big one) on the power board with new Panasonic ones. All the old caps tested fine on an ESR meter, and this worked for 5 days. But the screen just went black again today, so...
                  09-09-2024, 11:44 AM
                • DrankinSAW
                  LG 37LG5020 and the tale of 2 seconds to black.
                  by DrankinSAW
                  I bought an LG 37LG5020 with a very strange issue.. it turns on, the display looks fine, but still, after 2 seconds, the TV shuts the backlight off..
                  However, if i leave it plugged in for 20-40min.. the time it takes to shutdown the backlight, doubles (to 4 seconds)..
                  I bought a new inverter, set to arrive on December 13th
                  11-22-2023, 01:10 PM
                  HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera EliteDesk 800 i7-7700 Specification for Upgrade or Repair
                  This specification for the HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera boardview and EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our...
                  09-12-2024, 02:00 PM
                  MSI Cubi N 8GL-063DE/N4000/4GB/W10P/Black N4000 Specification for Upgrade or Repair
                  This specification for the MSI Cubi N 8GL-063DE/N4000/4GB/W10P/Black can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Cubi N 8GL-063DE/N4000/4GB/W10P/Black boardview and Cubi N 8GL-063DE/N4000/4GB/W10P/Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                  09-12-2024, 01:58 PM
                  Acer Aspire Acer Aspire 7 Charcoal Black Notebook 7 Specification for Upgrade or Repair
                  This specification for the Acer Aspire Acer Aspire 7 Charcoal Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 7 Charcoal Black boardview and Acer Aspire 7 Charcoal Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                  09-07-2024, 05:00 AM
