New caps, but still no power (Dell 3007wfp)
  • ped90
    • Apr 2015
    • 9
    Hi all
    I seem to have a bit of a stubborn monitor that doesn't want to fix. I'd love some help if anyone can provide it.
    I'll start with the symptoms - plug in but no power LED or anything.
    Opened up, caps looked fine but I thought I'd replace them anyway. I didn't bother with the big'un or the four little'uns near the centre of the power board (see video / should I have?)
    Video:
    http://1drv.ms/1MKb9Qu
    Basically, after doing so, nothing has changed. I still get a noise when I plug the mains in (you can hear it in the video) and still no power LED or picture.
    Can anyone advise on my next step? I'm no pro at all with this, so you may need to speak slowly
    I've also 'checked' the fuse by just passing through it with a wire, but as there's that noise while the mains is plugged in, I guess the fuse is fine?
    Thanks in advance!
    Ped
    • 31048
    Re: New caps, but still no power (Dell 3007wfp)
    small capacitors are the most important,
    they start the supply and smooth the feedback to keep the output stable.
    those are the first things i would have changed.
    • ped90
      • Apr 2015
      • 9
      Ha, well there you go. Thanks, I'll do that when I get home from work and report back...
        What DCV do you have on that big main filter cap (measure between the two legs of the cap)? >360VDC? The power supply board has PFC Voltage booster.
        Also, is there something leaking from the legs of the main filter cap?
        • ped90
          • Apr 2015
          • 9
          I didn't ever see any leaks from anywhere on the board. Will have a double check there when I get back tonight though.
          I currently don't have any measuring devices to check the main cap. I think it's time to invest! Can I get away with getting any old cheap meter or is there something specific I should look out for/get?
          Cheers the for replies so far,
          Ped
          • ped90
            • Apr 2015
            • 9
            Right, so I replaced the 4 small caps and now when I power on (not plugged into PC yet) the screen flashes red, blue, green, white... I think this is normal for when DVI isn't in. So I'm guessing that it's now fixed Thanks for the help, stj!
            Budm, I checked the DCV on the filter cap. It fluctuated a little at the start of the reading, then levelled out at 374V. Is this ok?
            • ped90
              • Apr 2015
              • 9
              It works
              Thanks for the help. Let's see how long it lasts :P
              • Tynan Dill
                by Tynan Dill
                Assuming...
                11-22-2024, 01:46 PM
              • PantherDave
                by PantherDave
                Hi all!
                05-29-2024, 02:01 PM
              • eryjus
                by eryjus
                05-10-2023, 11:21 AM
              • Mark01
                Dell Optiplex 7490 AIO - red power led after flash
                by Mark01
                Hi guys,
                This is my first post! 🚀
                I have no idea what I’m doing, but I’m learning by trial and error.
                I’m currently working on a Dell Optiplex AIO 7490—one of a bunch of AIOs that mysteriously failed to POST just a few days after the warranty expired. The original issue was that the PC worked fine until it was rebooted, after which it got stuck on a black screen (no backlight), with fans spinning at normal speed and a solid white power LED. Forcing it off by holding the power button would just cause it to switch on automatically and get stuck again on...
                07-04-2025, 12:54 PM
              • zlr8r
                Dell inspiron 17 (7786) - DP/N 09P7JP - odd power issues, starting with no power LED
                by zlr8r
                hey guys, hoping for some pointers to repair an eBay bought "faulty" laptop.
                Ill try and give as much info as I can.
                Dell Inspiron 17 (7786) Laptop
                Service Tag: 5J0NHT2
                Bios: 1.9.0
                When I received this , it would only flicker on the KB backlight for a second, then off and on.
                Then it started getting weirder!
                Sometimes when attaching the AC power supply, and pressing various pre-boot diagnostic keyboard keys... it did try to boot, in fact out of a hundred attempts, the laptop did actually boot into the Bios ! but never has...
                12-12-2023, 09:31 PM
