HP/Sony CRT Monitor - markings on the screen
  • SurrealMustard
    • Jan 2015
    • 487
    • The United States of America
    I recently got an HP A7217A (rebadged sony FW900) monitor that works pretty well, but there's some kind of issue that appears to be with the anti-glare coating (maybe) being damaged. The picture illustrates this better than I could describe it, so those would be worth a look.
    Any ideas as to the cause of the problem and any possible ways to fix it? I've tried all kinds of standard cleaning strategies.
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: HP/Sony CRT Monitor - markings on the screen
    kids using it for a chalkboard?
    looks like you will need to strip the antiglare to fix.
    • SurrealMustard
      • Jan 2015
      • 487
      Inquiry
      No, I got it like that. Any ideas as to how to get that antiglare coating off?
      • R_J
        • 9591
        Thats part of the crt glass, you would need a glass polishing compound like cerium oxide, but then the screen would end up being shinny.
          • 31214
          did you try wiping it with glass cleaner, vinegar, white spirit etc.?
          • SurrealMustard
            • Jan 2015
            • 487
            Markings
            A little progress has been made since last time. I've had very minimal results with glass cleaner, Formula 409, and SimpleGreen. The most success I've had so far is Magic Eraser drenched in Formula 409, but that's still pretty slow going too.
            • Sparkey55
              • Jan 2010
              • 1523
              Re: Markings
              Something that I would try, (because I am nuts anyway) is to take the crt completely out and use carb cleaner on the face. Do not get any carb cleaner on plastics or the Dag coating.
              • SurrealMustard
                • Jan 2015
                • 487
                Fixed!
                After a few days of intense scrubbing with Formula 409 and Magic Eraser, I finally got the rest of that coating off.
                It took a lot of effort, but it was definitely worth it. Now the monitor looks good whether it is on or off.
                • turmix
                  AOC U34G3XM, new monitor, black screen with backlight on, possible shortcircuit during dissassembly
                  by turmix
                  Hello, I'm working on a new deskmod pc project and have a problem with my monitor, an AOC U34G3XM, well, I may have bricked it.
                  The monitor was dismanteled and the separate parts parts integrated in the desk. the screen panel alone is on the upper part, and main board/video board + power board on the back of the desk (not enough place on the cover to fit it)
                  At first everything was working smoothly, then I decided to change the connexion between the video board and the screen for a longer one. Still working fine
                  During another reassembly, I made a mistake, and...
                  01-29-2024, 03:48 AM
                • Ryan.man
                  by Ryan.man
                  02-04-2025, 12:23 PM
                  by momaka
                  03-15-2023, 10:17 PM
                • abajor
                  A2141 Screen replacement. Boots screen freezes on Apple Logo 1/3 status bar unless connected to second monitor.
                  by abajor
                  Having this very weird issue.
                  The owner of this laptop complained about screen being intermittent when opening and closing, and has been using the laptop on a thunderbolt video connection since the screen failed.
                  I swapped with a working screen from an A2141 waiting for parts.
                  The Os exhibits this weird behavior where it boots to to 1/3 the status bar, then it makes the boop sound. It's at the log in but for whatever reason the desktop isn't loaded.
                  The laptop boots fine into recovery mode. I updated from Monterey to Sonoma and the laptop still has...
                  04-27-2024, 01:37 PM
                • 3D Modelka
                  AOC 27 monitor Q27G2WG4 doesn't display logo or image on screen
                  by 3D Modelka
                  Hello. I have a problem with my AOC 27 monitor, specifically model Q27G2WG4, which I have been using for 3 years. The monitor stopped turning on: when I turn it on, the backlight turns on, the indicator starts glowing white, but the logo on the screen does not appear, and there is no image. However, if I check in the Windows system, the monitor is displayed as connected and working. I tried connecting it via HDMI and DP, but the result remains the same. If I turn the monitor on and off multiple times, it will eventually start and work. However, when the monitor is working, there are no issues....
                  02-09-2024, 02:42 AM
