General Power board question - Fuse, Rectifier, TVS
  • llphat
    • Dec 2010
    • 20
    I had some issues recently with a few power boards with blown fuse, on checking it seems one of the bridge diode has shorted. After replacing the fuse and rectifier bridge, on power up the TVS (transient voltage suppressor) always explodes. Is this expected?
    Or should the TVS also be changed once the bridge has a shorted diode?
    The most recent case I had is the Dell 1800FP power board. Fuse F901 blown, on checking rectifier BD901 has a shorted diode after changing both TH902 explodes on power up.
    master hoarder
    • May 2008
    • 12175
    Re: General Power board question - Fuse, Rectifier, TVS
    Perhaps the high current that flows before the fuse blows is what damages those NTCs/TVSs.
    Not necessarily. But since it seems like a common occurance to you, maybe keep a few TVSs in stock just in case this happens.
    Also, when the fuse and/or BR has blown, I suggest you use the incandescent light bulb series trick in series with the monitor to limit the current. That way, if there are more problems, the light bulb will light but will not blow your new fuse. Here's a thread on how to do it:
    https://www.badcaps.net/forum/showpo...4&postcount=70
    • R_J
      • Jun 2012
      • 9551
      I suspect the tvs was also damaged by what ever surge took out the bridge. they don't always fail shorted, they can check open (or close to it) but when voltage is applied they blow
      • Steph.hen
        Bridge rectifier identification part number KPB305G
        by Steph.hen
        Hi all, a newby question about a bridge rectifier I'm trying to identify.
        I'm in the midst of reparing a battery charger in work which went pop, The bridge rectifier has shorted and took out a couple of other components. The rectifier in question has a part number KPB305G, and it looks like it's obsolete. Does any one know what I could replace it with?...
        08-29-2024, 09:52 AM
      • corrize
        A funny fuse story – Lumix LX100 II
        by corrize
        Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
        I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
        The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
        There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
        And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
        10-19-2023, 09:58 AM
      • EasyGoing1
        Reading input and output of bridge rectifier on the same scope?
        by EasyGoing1
        I have a 40 volt AC transformer that I put a bridge rectifier on, and I wanted to see the input signal and the output signal on the same screen on my scope, so I set one channel up with the test lead on one side of the input and the ground lead on the other side of the input, then I used another channel on the scope and clipped the test lead on the positive side of the output then the ground on the negative side of the output.
        When I connected the transformer to power, the wire that was connected between the ground lead on the second channel and the negative side of the bridge rectifier...
        06-26-2022, 12:52 AM
      • nicktasios
        Macintosh Quadra 840AV PSU
        by nicktasios
        I had my Quadra 840AV (which I recapped and had working) plugged in for some time without using it and randomly decided to turn it on today. Unfortunately it did not turn on. After checking the PSU, I found out I was not getting anything from 12V, only from the 5V rail. After a few minutes, I removed the PSU and plugged it back in the electrical outlet and it suddenly started making a weird sound and soon after smoke started coming out. I quickly unplugged it. I opened it up but on first instance I didn't see anything out of the ordinary really. I later turned it back on and one of the MOVs blew...
        12-22-2024, 05:07 AM
      • Ross Kohler
        Diagnosing South Bridge (FH82H370) on Asus H370-Pro Gaming Motherboard
        by Ross Kohler
        I'm learning about motherboard repair and I believe I've traced the issue down for the South Bridge on the particular motherboard I'm working on. My path of concluding that:
        - There's no sign of any attempt to power on when pushing the power button.
        - No PSON signal is reaching the 24-pin ATX connector.
        - The Super IO chip is receiving the PS_SWITCH signal from the power button and is relaying this signal back to the South Bridge.
        - The Super IO is not receiving the S_SLPS#_R signal back from the South Bridge
        - If I pull the Super IO S_SLPS#_R pin...
        04-16-2024, 09:36 AM
