Can I replace 30v 180uf cap with 35v 180uf? MPC clientpro 414 17" lcd inverter board?
+ More Options
Posts
  • ALUMINUMWELDER
    rolland elliott
    • Dec 2014
    • usa
    this is my first post so I apologize if I make any mistakes.
    three images below show inverter board, top, middle and bottom.
    I have 40 of these all in one 17" LCD computers and they all show the start up screen for a split second and then show white text for a split second before going completely black. Although the PC's are very old about 10 years I'd rather fix them then throw them in the landfill.
    the middle photo shows two green and gold capacitors, which are labeled:
    NK CON 30v 180uf 105 c f2053 EVL
    I want to replace them since they are reading 40uf and 90uf with multimeter.
    I have already swapped out a good inverter board with a bad one (on two pc's) and got a PC working again so I know it is something bad on the board.
    I cannot find any 30v capacitors on mouser.
    can I use this 35V one instead? I know I can use a higher capacitance rating, but i'm not sure about voltage?
    http://www.mouser.com/Search/Product...67-EEU-FR1V181
    [/IMG]
    Re: Can I replace 30v 180uf cap with 35v 180uf? MPC clientpro 414 17" lcd inverter bo
    Yes you can, but it has to be LOW ESR/IMPEDANCE type. I use Panasonic FM/FC/FR series for all my repairs.
    You should recap the whole board except the main filter cap.
    • ALUMINUMWELDER
      rolland elliott
      • Dec 2014
      • usa
      thanks for the quick reply
      the product spread sheet says 56 mOhms is that low enough?
      I only see two capacitors on the board, though I admit I am an electronics novice and do not know what everything is just by looking at it.
        "the product spread sheet says 56 mOhms is that low enough?
        What product spec sheet, the spec sheet of the original?
        If you get the FM series it will be good for sure, FR will be even better doe to longer Hrs.
        • ALUMINUMWELDER
          rolland elliott
          • Dec 2014
          • usa
          MOUSER says it is FR series FR1V181
          I am talking about the product spread sheet on mouser's web site
          I posted the link above in first post.
          I am so happy I was able to figure this out by reading this forum and getting help from people like you, thanks!
          • SteveNielsen
            Retired Tech
            • Jun 2012
            • 2327
            Yes it will be ok to use that capacitor. Going up on the voltage rating by 5v isn't going to make any difference. What Bud said, if you're going to buy and replace one cap you should do all of them.
            • m1ch43lzm
              by m1ch43lzm
              05-12-2025, 08:37 PM
            • howardc64
              by howardc64
              07-24-2025, 05:17 PM
            • lostone
              Looking for help with a Viewsonic VP230mb where the backlight comes on only momentarily
              by lostone
              Hello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
              First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
              When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...
              05-19-2024, 11:40 AM
            • Tynan Dill
              by Tynan Dill
              Assuming...
              11-22-2024, 01:46 PM
            • Hakuu
              by Hakuu
              Hi There,
              More Details
              TV Model - LG OLED77G1PUA
              07-12-2023, 02:37 PM
