A Tale of Two Dead Viewsonic VA720s
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: A Tale of Two Dead Viewsonic VA720s
    Depends on which series he sells.
    The GE series is slightly better than Panny FM.
    The GD series closely matches Rubycon MBZ.
    The GC series roughly matches Rubycon MCZ.
    From GE 'up' Samxons go:
    GE -> GD -> GC -> GA
    (There may be other Samxon series that I am not familiar with.)
    Mann-Made Global Warming.
    - Dr Seuss
    • gonzo0815
      • Feb 2006
      • 1600
      If heat is the main problem, i would considering Samxon RS, sure not the greatest ESR, but 7000h endurance rating.
      I think they should equal the FC`s in ESr rating.
      • bgavin
        • Jan 2007
        • 1355
        This implies the Samxon GA series is superior to the Rubycon MCZ... I thought the MCZ was as good as it gets...
        • davmax
          • Dec 2005
          • 899
          Yes the GA series is an incredible product line.
          Link to data: http://www.samxon.com/PDF/prodPDF_106.pdf
          Gigabyte EP45-DS3L Ultra Reliable (Power saver)
          Intel E8400 (3000Mhz) Bios temps. 4096Mb 800Mhz DDR2 Corsair XMS2 4-4-4-12
          160Gb WD SATAII Server grade
          Nvidia 8500GT 256Mb
          160Gb WD eSATAII Server grade for backup.
          Samsung 18x DVD writer
          Pioneer 16x DVD writer + 6x Dual layer
          33 way card reader
          Windows XP Pro SP3
          Thermaltake Matrix case with 430W Silent Power
          17" Benq FP737s LCD monitor
          HP Officejet Pro K5300 with refillable tanks
          • RJARRRPCGP
            • Jul 2004
            • 6304
            I can't tell is that cap is bad or good! Please get another angle of that cap!
            Also, your symptoms sound more like the motherboard is failing to POST.
            This can include a damaged processor on the motherboard.
            ASRock B550 PG Velocita
            Ryzen 9 "Vermeer" 5900X
            Arc A770 16 GB
            eVGA Supernova G3 750W
            Alienware AW3423DWF OLED
            • Operandi
              • Jul 2006
              • 46
              #26
              So I successfully fixed the 2nd Viewsonic, actually a couple of weeks ago...
              I went with Panasonic FC from Digikey since Topcat didn't have Samxon in one of the values needed in the correct size. Sadly due to a typo on the order form I ordered the wrong caps for the Elite 470uf 25vs so I ended up only replacing the known bad 1000uf cap, oh well . Here are the finished results.
              It's actually an OK display, especially considering how old it is. I think the backlight may be failing however as I've noticed when monitor is cold (low 60s) the backlight doesn't kick in right away, but after about 5-10 mins of warming up it's fine. I assume thats a sign of the florescent light approaching the end of its life?
              • PCBONEZ
                Grumpy Old Fart
                • Aug 2005
                • 10661
                There are various ways it's implemented and I don't remember the specifics.
                Basically the initial power-on cycle gives a little extra kick to initially start the tubes.
                The caps that didn't get replaced might have something to do with that.
                - Or not. Or something else. Or yeah, aged tubes. Hard to say.
                Congrats on your progress.
                It works! It works!
                - Dr Seuss
                • PCBONEZ
                  Grumpy Old Fart
                  • Aug 2005
                  • 10661
                  Nichicon HN, Samxon GC, and Chemicon KZJ are all comparable to MCZ with specific can sizes being either slightly better or worse between the models. (Slightly)
                  Nichicon HZ and Samxon GA are superior to all of the above but usually limited availability and added cost make them not the best choice.
                  - Dr Seuss
                  • Operandi
                    • Jul 2006
                    • 46
                    #29
                    Yeah, when it's cold it gets an image for split second and then nothing. I can tell it's th backlight because if I can still see the picture If I shine a flashlight on the panel.
                    I'm just using this as a backup display anyway so I think I'll call it good.
                    • davmax
                      • Dec 2005
                      • 899
                      #30
                      The short burst of backlight is possibly related to an over current trip that is rest when powered off. There is likely excess current that needs to be identified. Usually there are two sets of lights. Disconnect one set at a time, this may locate a particular lamp/inverter problem.
                      The kick to start the backlights is quite simple. The inverters have a high voltage that is current constrained by a series capacitor. At "switch on" the voltage is high to strike the tubes and then the voltage drops away due to the series reactance of the capacitor.
                      Nvidia 8500GT 256Mb
                      33 way card reader
                      Windows XP Pro SP3
                      • Operandi
                        • Jul 2006
                        • 46
                        #31
                        Thats for the suggestion davmax, that sounds like a good next step. One that I would probably take if this was a nicer/newer monitor but it isn't...
                        As it is it's fine as backup monitor, it only has startup troubles when it's really cold (sub 60f).
                        • double_DD
                          How can I be sure that my EC chip is dead?
                          by double_DD
                          As the title suggests, how can I be sure that my EC chip is really dead?
                          I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                          Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                          03-12-2025, 07:47 AM
                        • ngml
                          Repair of an LG split AC system indoor unit PCB
                          by ngml
                          I am trying to repair an LG split AC indoor unit, which does not start and gives a CH05 error code.
                          This indicates an error in the communication between the outdoor and the indoor unit.
                          The outdoor unit is fine, so the problem is the indoor PCB.
                          The indoor unit is an LG PC09SQ NSJ (3SNM09JA2FA), and the PCB has the following type number: EAX35907219-1.2 (see photo1)
                          I changed optocouplers ICO1X & ICO2X and the NPN transistor S9013 which drives optocoupler ICO2X (see photo2), but this did not remedy the fault.
                          Does anybody have the schematics of this board,...
                          02-01-2025, 12:55 PM
                        • disorder
                          ps5 edm-033 dead after hdmi/usb ports destroyed
                          by disorder
                          hello guys,
                          i need help to repair a edm-033 ps2
                          history : as always hdmi port and usb ports destroyed after unplugged
                          after change them, ps5 dead too : 1 beep, no blue light. after inspection 1.8v power was shorted, and because of dead panasonic chip. after remove it : no short anymore
                          so i changed it
                          now i have got 5v stby,, 3.3v stby, 3.3v power, 1.8v power and no short on them
                          but the ps5 is dead again : 1 beep, near 10 seconds with power lines and then off, no blue light ...
                          i don't see any projection of liquid metal on pcb.
                          01-14-2025, 12:48 PM
                        • nobbnobb1
                          Bose Companion 5 - Unit Powers On then Cuts Off Shortly After
                          by nobbnobb1
                          Hi guys,
                          Trying to salvage a Bose Companion 5 computer speaker system that powers off shortly after powering on. It's got a primary USB input (built in DAC) and an aux 3.5mm input. The USB appears to be the primarily source that tells the unit to power on (control pod LED goes green) as the unit has no power switch.
                          When I first connect power to the unit, plug in the USB, it will play audio nicely for a minute before it drops out and the unit appears to go into standby (control pod LED goes red). It stays in standby and I cannot seem to power it back on without physically...
                          02-03-2022, 11:14 AM
                        • zunasthegreat
                          Chieftec GPS-450-AA with dead 20N60C3
                          by zunasthegreat
                          Hello everyone hope all doing well!
                          I have this PSU (GPS450-AA delta oem) around for like 4-5 years and I had it recapped early 2020 or 2021 with mostly UCC KY and Nichicon PW's. The bulk was and still is fine, the original Ltec's were bloated and empty. The previous issue was some major coil whine noise and at times random shutdowns when going idle. Today it started tripping the mains breaker and I think I have dead APFC mosfets (20N60C3). Right now upon checking I have the Q1 and Q3 FETs dead so far and I guess those are responsible for the PFC circuit. The only thing I care is If there...
                          09-01-2024, 07:12 PM
