So, I have had this monitor awhile now. It had started to have some issues with turning on/off randomly. But then just stopped and worked fine. I had to move and put it away in storage (it had sat about 6 months) and had not used it for a bit. I took it out yesterday and plugged it in to my desktop and it turned on right away, but then only goes to the red/blue/green/black/white color test screen and does not show video other than that. It clearly recognizes that there is something plugged into it since upon removing the hdmi or vga cable, it goes to the sleep state with the amber led. Is this a normal thing to happen? Is it fixable or should I just scrap it and try to find something else?
Hanns-G HG281d
Tags: None
Re: Hanns-G HG281d
Try replacing the two caps on the main board:
https://www.badcaps.net/forum/showpo...&postcount=151
https://www.badcaps.net/forum/showth...=HG281&page=32Never stop learning
http://www.badcaps.net/forum/showthread.php?t=24809 -
Re: Hanns-G HG281d
https://www.badcaps.net/forum/showth...=HG281&page=32Comment
Re: Hanns-G HG281d
Buy the correct low ESR type caps and may be taking it to local TV shop to have them remove the old one and install the new one for you. Verify the work and make sure the caps are put in with correct polarity, and good solder works.Never stop learning
Re: Hanns-G HG281d
Ok thank you for the helpComment
by ShinjuHey All!
Long time forum member here with a problematic laptop issue!
I got a RZ09-0196 with a bloated battery (still worked and charged fine) I pulled the old cell pack out and installed a new cell pack in its place.
The laptop would not power on with the new battery installed without the power supply being plugged in.
When booting into Win10 (all up to date BTW) I saw the battery icon with 49% plugged in not charging.
TL;Dr version, old battery worked, charged but was bloated, installed a new non OEM replacement, laptop/windows... -
by zwectI have this Asus ROG laptop (the 1060 + 6700HQ variant) which lights up the power button's LED when i plug the charger in but does nothing else. Opening up there are no signs of any burnt or corroded components, i've checked the resistance of both CPU and GPU's cores on the caps underside them, the CPU's VCCCORE's caps read 1.2ohm and the GPU's NVVDD read about 0.5 to 0.6ohm. I then tried to check any voltages while the laptop is plugged in (without any of the removable parts) and the GPU's core voltage instantly goes to 0.8v when plugged then getting slowly warm, the PCH does so too (not so warm...
Hello Everyone!
I have an Acer Aspire A315-42 laptop. I generally leave it on for long time by closing down its lid (so it enters the sleep mode). Recently, it rained quite heavily in out area. And the humidity and moisture seem to be high. So one late evening, after I opened the lid and turned on the laptop, it did power on as the blue light turned on but after it booted to the desktop screen, just 5-10 seconds after both the screen and blue light went out and laptop shut down (the blue power light turned orange). And after 2-4 seconds that orange light went off and the laptop died....06-28-2025, 02:57 PM -
by pluggedDanHi all,
I have an A1706 that was liquid damaged, the logic board turns on and works when the battery connector is not plugged in, but when the battery is plugged in, the computer is stuck on 5v @ 30-40 Mah, and USB-C meter will reboot every 5 sec or so, pressing and holding down the power button will make the USB-C meter to stop boot looping, and if you keep holding it, fan will quickly spin up and turn off.
when the battery is unplugged and plug in the charger then plug in the battery it will stay on 20V and 1.6A-2.6A but when you unplug the charger, the computer... -
a2251 820-01949 usb c amp meter malfunction when battery is plugged, can someone help me to troubleshoot this? no short on sda and scl lines and 3.3 voltage on both lines
- Loading...
