I've done some research and this appears to be a classic problem. There are other threads where there are recommendations for what capacitor to replace C504 with. My primary question is if that conventional wisdom is still the same, or has it changed. Have there been advances in "capacitor technology" such that there is a better replacement cap available? From what I've read, this cap is subjected to very high voltages and that is the reason for it chronically burning-up, so if there is a way for me to maybe spend a few dollars and make certain it never happens again, I'd be interested.
Secondary to that, on visual inspection on the "power" pc board, I note that resistors R508 (near C504) and R525 (on the other side of the pc board) are both discolored, and I wonder if they should be replaced also, as a preventative. Does discoloration of a resistor necessarily mean overheating, and does overheating cause permanent damage, i.e. a change in resistance value and/or a decrease in life-expectancy, and with all of that in mind, is it worth the time & trouble to replace them, as long as I have the guts of this LCD monitor exposed?
As always, any help appreciated and thanks in advance.
