LCD monitor sometimes white screen
  • hotice997
    • Jul 2014
    • 7
    • Bosnia And Herzegovina
    Hey guys!
    I have LCD monitor which was working just 5 minutes after you plug it in.After 5 min it turns off.I have opened my LCD and i found one bad cap.I have replaced it with brand new(its 400v 100uF).After that I put all things together and now my screen is white.Sometimes it happens to show picture for 1-2sec after I turn it on.I turned my LCD once and it was showing picture for about more than 7 minutes.I turned it off to put all things back and after it is showin white screen again!! please help
  • selldoor
    Slow Learner
    • 7870
    Re: LCD monitor sometimes white screen
    Fractionally better but still not in the right section!
    Check again the lvds cable that goes from ?????? board to the panel.
    I cant say which board as you have posted no pictures and not even told us
    the make or model of the monitor.
    Pictures please - one of the back showing the general layout and one of each board.
    Jpgs no bigger than 3mb posted using manage attachment
    • hotice997
      • Jul 2014
      • 7
      well,I know about what cable are you talking about.I have spent almost 2 hours of trying cable positions.Its not about cable...Well there is connection on the power board which says +5v output.I took my voltmeter and I saw that voltage is chaninging from 4.9 to 5.13 very fast.It has to be constant or?
      • selldoor
        Slow Learner
        • 7870
        • hotice997
          • Jul 2014
          • 7
          I have fixed it,thank you for you little help.How can I close/delete this thread?
          • kjn4685
            • Jun 2014
            • 4
            What kind of monitor is it and do you have a schematic.
            Lou
            • harp
              White screen repairs
              by harp
              To ask here... I have few devices with white screen problem, actualy nokia 2220 and some fuji? camera, and try to understand what is common problem to cause that issue.
              Yes, both devices work everything else probably ok, I mean, I hear intro melody and keypress click sound, DTMF tone, power on off... all ok.
              On desk is nokia 2220 slide, and I check all screen connectors and components arround it, measure voltage drop, but all looks ok. I suspect on slide flex cable, but it look ok and white screen is not interupt while flexing board, pushing conectors, and sliding up down. In attachment...
              05-13-2024, 03:43 AM
            • Ryan.man
              by Ryan.man
              02-04-2025, 12:23 PM
              by momaka
              03-15-2023, 10:17 PM
            • abajor
              A2141 Screen replacement. Boots screen freezes on Apple Logo 1/3 status bar unless connected to second monitor.
              by abajor
              Having this very weird issue.
              The owner of this laptop complained about screen being intermittent when opening and closing, and has been using the laptop on a thunderbolt video connection since the screen failed.
              I swapped with a working screen from an A2141 waiting for parts.
              The Os exhibits this weird behavior where it boots to to 1/3 the status bar, then it makes the boop sound. It's at the log in but for whatever reason the desktop isn't loaded.
              The laptop boots fine into recovery mode. I updated from Monterey to Sonoma and the laptop still has...
              04-27-2024, 01:37 PM
            • EazyBone
              Sharp LC-65Q620U White Screen
              by EazyBone
              Another TV topic!!
              I got this sharp TV that when I first plugged it in it showed the sharp logo and then went to the input screen. This was about 30 seconds and then it showed white screen. Now I can't see anything but white screen. This has a separate TCON and Main.
              The TCON is getting 12V and several parts are as well but the VGH line is only .5Volts which I thought is totally incorrect.
              Am I on the correct assumption that the TCON is bad somehow if I'm only getting that voltage or is there something else I should check?...
              08-21-2024, 12:56 PM
