HP LP3065 or Dell Ultrasharp 3008 Panel
  • raljr
    • Apr 2013
    • 5
    Made repairs on monitor and in doing so cracked the good panel
    So I'm looking for broken monitor with a good panel
    These two monitors to the best of my knowledge share same panel
    Anyone have either one?
    Thx,
    Bob
  • Lumberjack777
    • 464
    Re: HP LP3065 or Dell Ultrasharp 3008 Panel
    You might get lucky and find one on Ebay someday. I saw a panel last month for $375. And it was even scratched. I offered him $200 but he wouldn't take it.
    You need to make sure you match up the exact model number from the sticker on the panel. Examples will be LM300WQ5-STA4 | LM300WQ5-STA2 | LM300WQ5-STA1 | LM300WQ5 | LM300WQ3-STA2 | LM300WQ3 | LM300WQ1 | LM300W01-STA2 | LM300W01-STA1
    You can also buy them new from China for about $600 to $700. Your best bet would be to find one with a bad power supply at an auction site. Good luck.
    • raljr
      • Apr 2013
      • 5
      Thanks for info
      Hopefully someone here is able to help me
      I'm trying everywhere
      Thx
      • Bowline
        by Bowline
        06-11-2025, 10:13 AM
      • shovenose
        Better Panel for Dell Inspiron 15-5558 Laptop
        by shovenose
        Got this for free it's pretty much the perfect laptop, with a backlit keyboard, they already upgraded to 16GB RAM and a 500GB SSD, etc. but the screen sucks - it's a 1366x768 TN panel. I'm assuming the optional upgrade panel for this model - a 1920x1080 IPS panel - will be a direct swap, but researching that it's still a fairly mediocre panel according to Notebook Review: https://www.notebookcheck.net/Dell-I....145836.0.html
        What I'm wondering is how specific these have to be? I've established that both the current panel and Dell FHD panel use the "Embedded...
        06-05-2022, 09:23 PM
      • pickledegg
        Dell Inspiron 7501 / Vostro 7500 (2020) - eDP connector pinout/panel compatibility question
        by pickledegg
        Hello. I have an Inspiron 7501 here, it's the same as a Vostro 7500 in some markets (no clue). I was looking to replace the LCD, the panels included with these models are terrible.
        I have the schematic and it is a 4 lane eDP port on the board but the pinout seems quite weird, my question is if anyone recognises this weird pinout and knows of any other Dell models that may use it or even any compatible panel models. I have the 40-40pin cable that was used for the models with touch but do not need touch capability, was just looking for a better quality screen and higher refresh to actually...
        10-02-2024, 04:54 PM
      • Akhlz001
        by Akhlz001
        09-20-2025, 07:15 PM
      • master3112
        by master3112
        07-29-2025, 01:55 PM
