Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
  • DanPoka
    • Jul 2023
    • 39
    • România
    I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
    Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
    This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered at first but mostly it would stay on. What I had expected was that the backlight would turn off as previous but that didn't happen. So I thought what's different.. What was different was that the data cable from video processing board was disconnected from the LCD.
    ​​​​Sure enough when I put the monitor back together, monitor would come on and backlight switched off in a second. Now I could bring the backlight back on by shorting the leads I soldered on C3 and removing the short thus re-enableing INL chip.
    My question is what would cause this strange behavior?
  • DanPoka
    • Jul 2023
    • 39
    • România
    Here is schematic from Electrotanya
    Electronics forum for electronics experts to repair defective appliance.
    • DanPoka
      • Jul 2023
      • 39
      • România
      * I could bring the backlight back on but only for a second.. (By shorting and then releasing C3)
      • DanPoka
        • Jul 2023
        • 39
        • România
        Why would disconnecting data cable would result in different behavior from backlight?
        • DanPoka
          • Jul 2023
          • 39
          • România
          Mea culpa.. I also switched input of lamp 1 with lamp 2. I didn't realize..
          • DanPoka
            • Jul 2023
            • 39
            • România
            Any advice now, thanks..
            • DanPoka
              • Jul 2023
              • 39
              • România
              This morning it would mostly want to stay on. Then after a while hissing sound and won't turn on for more than 1 second. Hissing sound seemed close to inverter circuit. What do you say bad inverter circuit or bad lamp? Hissing sound was like adjusting speaker volume where speaker has defective volume potentiometer.
              • DanPoka
                • Jul 2023
                • 39
                • România
                After more testing I've come to the conclusion it is the lamps or at least one that is defective. I've seen it flicker like a bad neon lamp.
                So I've decided I will replace them with led lights. Which ones to buy? Please help
                • DanPoka
                  • Jul 2023
                  • 39
                  • România
                  Will these be good 19" 417 mm?
                  • Zilicon
                    NEWSYNC B27F165 MONITOR HAS NO BACKLIGHT. board no: JY85QS_UPH_LS_R10.3
                    by Zilicon
                    Greetings everyone.
                    Please I need help with the above monitor.
                    Below is the summary of what happened and what I have done:
                    The monitor started by turning off 2 seconds after it was turned on. It displayed with a backlight when it turned on. However, the standby light remains on after it is turned off on its own, I have to press the power button again to turn it on, but it will go back to standby after 2 seconds.
                    The backlight driver IC is 0b3350cp.
                    I applied a 370k SMD resistor on the CMP pin which is pin 6, while the other...
                    11-07-2023, 09:12 AM
                  • ttmi100x
                    HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
                    by ttmi100x
                    Greetings everyone,
                    I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
                    The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
                    Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
                    Upon closer inspection...
                    07-31-2024, 06:36 PM
                    by momaka
                    03-15-2023, 10:17 PM
                  • turmix
                    AOC U34G3XM, new monitor, black screen with backlight on, possible shortcircuit during dissassembly
                    by turmix
                    Hello, I'm working on a new deskmod pc project and have a problem with my monitor, an AOC U34G3XM, well, I may have bricked it.
                    The monitor was dismanteled and the separate parts parts integrated in the desk. the screen panel alone is on the upper part, and main board/video board + power board on the back of the desk (not enough place on the cover to fit it)
                    At first everything was working smoothly, then I decided to change the connexion between the video board and the screen for a longer one. Still working fine
                    During another reassembly, I made a mistake, and...
                    01-29-2024, 03:48 AM
                  • keepread
                    Dell monitor PSU vs Dell laptop PSU
                    by keepread
                    Hi there!
                    Someone gave me their old monitor, it's Dell S2715ht.
                    The owner was using it when his PSU began to smell and then to smoke. It literally began to melt. He turned the monitor off, pulled the PSU, and ditched it because it was smelly even after it cooled. So I got the monitor but not the plug.
                    Now, I tried to bring the monitor back to life, by plugging one of my many Dell laptop PSUs. They are of the same 19.5V, and the wattage of the laptop PSU is higher than that which the monitor is rated for. Visually, the socket on the monitor seems compatible, and the plug plugs...
                    10-30-2025, 04:45 PM
