Mystery 21" SGI monitor slowly gets fuzzy
+ More Options
Posts
  • pentium
    • Mar 2006
    • 2778
    I have not needed to use this massive monitor (so big it has an internal fan) until a few days ago when my Indigo arrived.
    At first the screen was fine...
    ...Then after a while (say ten minuets) The center of the screen (in the middle but spanning to both sides) began to get fuzzy. I really ignored it but then it got ugly.
    The screen suddenly began to distort really badly in the center and everything in that distortion was unreadable. I carried on using the top and bottom of the screen but slowly it spread out from the center and eventually the whole screen was fuzzy.
    <----I am out of focus but you get the point.
    One thing I noticed was that if I raised the contrast fro normal or opened something that had alot of brighter colors in it (like badcaps on firefox), the fuzz would either retreat to the center again or even go away but as soon as you minimized or hid that bright page or window in some way it would come back.
    Am I right to suspect dried-out caps or is this more complex?
    Forget ditching this one. My SGI's require monitors that use sync-on-green and standard monitors will not cut it.
    Find Nedry!
    Check the Vending machines!!
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: Mystery 21" SGI monitor slowly gets fuzzy
    looks like a bad focus divider network(flyback)
    iirc that is a mitsubishi.
    if a sony a bad crt.
    esp if it sometimes snaps and goes normal for a while.
    post pics of the inside.
    • pentium
      • Mar 2006
      • 2778
      I'll post a pic as soon as I can.
      No, there is are no snaps or arcing.
      Oh, and if I leave the monitor off for at least half an hour the picture would get better. Leave it alone for a week and the screen completely clears up but then as soon as it's used for ten minuets it starts again.
      Find Nedry!
      • pentium
        • Mar 2006
        • 2778
        Here are the pics. BTW, it was made by Hitachi.
        http://i11.photobucket.com/albums/a1...itor/front.jpg
        http://i11.photobucket.com/albums/a1...nitor/back.jpg
        http://i11.photobucket.com/albums/a1...itor/ports.jpg
        http://i11.photobucket.com/albums/a1...itor/label.jpg
        http://i11.photobucket.com/albums/a1...nitor/info.jpg
        http://i11.photobucket.com/albums/a1...tor/inside.jpg
        http://i11.photobucket.com/albums/a1...or/flyback.jpg
        http://i11.photobucket.com/albums/a1...itor/thing.jpg
        http://i11.photobucket.com/albums/a1...or/adjust2.jpg
        http://i11.photobucket.com/albums/a1...tor/adjust.jpg
        You need to make it easier to just attach pictures. :P
        Find Nedry!
        • gonzo0815
          • Feb 2006
          • 1600
          I would opt for some bad solder points and or dried up lytics. But ok, if KC8 is pointing to the flyback , then i would not exlcude this ;-)
          this unit must be getting realy hot, that they put in some fans.
          • kc8adu
            • Nov 2003
            • 8832
            • U.S.A!
            resolder the flyback pins just in case its the ground for the focus/screen block.
            if problem persists its probably a bad fly.
            • pentium
              • Mar 2006
              • 2778
              Oh great and I can't find my H/V discharge tool.
              Find Nedry!
              • starfury1
                • May 2006
                • 1256
                Ok me not Monitor guru but have fixed a few
                if thats 1988 I read yeah like nearly 20 years of service not bad
                All of the above
                My first thoughts were EHT horz circuits (possibly psu)
                Also check joints on any transistor type packs that are bolted to heat sinks on the pcb,
                expansion contraction can and does fracture these solder joints as well.
                Higher voltage electrolytic's tend to fail alot too 100 160 Volt type ones
                From the photo it looks like one of those large maybe be raised but hard to tell
                (for me anyway)
                Give it a good visual and check replace caps
                rework any joints that are liable to suffer stress or look iffy...solder's cheap.
                no guru on them like I said
                but this stuff applies to any TV, monitors of that age
                Hope for your sake its not a bad flyback
                Good luck Pentium and be careful
                • kc8adu
                  • Nov 2003
                  • 8832
                  • U.S.A!
                  if it is a bad fly try running till its fully hot and adjust focus/g2 for best image.
                  maybe it will play awhile without drifting.
                  • pentium
                    • Mar 2006
                    • 2778
                    I'm going to try to check for cold joints first. I still can't find my damn H/V discharge probe.
                    Find Nedry!
                    • gonzo0815
                      • Feb 2006
                      • 1600
                      The only thing, where i am a little coutiouse is the HV cable from the flyback. I usually pull the plug from the crt and discharge it to the black mask or a grounded metall part.
                      The crt itself can store some hv charge too, buti haven`t had any problems with that.
                      The HV caps are usually already discharged, so i only short them preemtive with a normal probe or any kind of wire i have handy.
                      But i ma not a pro too in crt / tv repair.
                      • pentium
                        • Mar 2006
                        • 2778
                        I usually go with a wood probe with a resistor and an alligator clip on the other end of a length of wire it's attached to and just go over the entire H/V section. I never got the knack of pulling the rubber flyback cup back and inserting the probe.
                        I also tried removing one with a screwdriver when I was four. In that moment I finally understood how the flyback transformer got it's name.
                        Find Nedry!
                        • gonzo0815
                          • Feb 2006
                          • 1600
                          yes, it is very nasty and a hard learned lesson
                          But usually under the rubber plug there is a steel clamp.
                          You can feel it and if proberly compressed you can easily unplug it whitout any problems.
                          But shure, the rubber may be degrade after time.
                          I have learned this while trying to put of a car`s engine with defektive ignition lock.
                          That damn ignition distributor`s rubber plug was realy degraded, and after a realy healthy zapp i refused to try it again
                          Those MB 190èr cars have had a very robust ignition system
                            by momaka
                            03-15-2023, 10:17 PM
                          • ant3202
                            HP 27es - LED monitor - Monitor Flashing On - Off
                            by ant3202
                            Hi Everyone
                            Lately I am experiencing the deja-vu incident on one of the led monitor like this.
                            https://www.badcaps.net/forum/troubl...lashing-on-off
                            The monitor is HP 27es LED Monitor
                            https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
                            The monitor will randomly blackout and display no signal and will recover again.
                            Sometimes need to power and off again to restore the display but...
                            03-20-2025, 07:30 PM
                          • Rick_1234
                            by Rick_1234
                            Good evening, gentlemen.
                            Things I tried
                            06-22-2024, 04:44 PM
                            Wise Wing F199 19'' LCD monitor - recapped
                            by momaka
                            Looking through my repair pictures and notes, it's been a long time since I posted anything in the LCD monitors section. So here goes that.
                            I'm dedicating this thread to one of the very first LCD monitors I repaired (if not the first one), which was more than 10 years ago now. The monitor is a Wise Wing, model F199. It's a 19” CFL-backlit LCD. I got it for free off of Craigslist in 2009 from a guy, who said he bought it for cheap from Wallmart and the monitor worked only for a little less than 2 years before quitting.
                            When I saw the Craigslist post, I wasn't...
                            08-24-2020, 10:58 AM
                          • sew333
                            Pc shutdown, monitor flickered with no signal after 10 seconds
                            by sew333
                            My pc:
                            10850K stock 4800mhz stock Kraken X73 good temps
                            2x16 GB DDR4 GSKILL 3000mhz XMP
                            Seasonic Tx-850 Ultra Titanium
                            Gigabyte Rtx 3090 Gaming OC
                            Aorus Z490 Pro Gaming
                            1 TB SSD
                            4 weeks ago i launched Metro Exodus Enhanced and during cinematic advertisement part ( 30 fps ), pc just shutdown.
                            Also monitor flickered with NO SIGNAL 10 seconds after shutdown. So only monitor and pc was affected.
                            Next i pressed only power button, rebooted again and its fine again. Happened once and i cant reproduce.
                            Power...
                            02-22-2022, 10:27 AM
