Problem with LCD Panel board
  • jetadm123
    • 2169
    Re: Problem with LCD Panel board
    Suggest you re-measure the voltages of the OZ9936 as you did in post #12.
    • bammbammfran
      • Apr 2014
      • 476
      Hum ?
      since you have 5 volts in on 6 and ground on 3, I would think that when the 5 comes into 1 that 4 and 5 should turn on or at least try to.
      Bad chinese chip ? or something else is stopping it from turning on ?
      see what resistance you have on 4 and 5 to ground ?
      verify resistance on 1053 at R104
      • mokie
        • Jan 2014
        • 61
        • spain
        I have checked pins 4 and 5 and they actually "try" to turn on. They go up to 325mV for a short period of time and then they both go to zero.
        Resistance between pin 4 and ground: 11.9 Momhs
        Resistance between pin 5 and ground: 12.7 Mohms
        R104 is 105.5 komhs
        • mokie
          • Jan 2014
          • 61
          • spain
          Voltages are the same than post #12
          • bammbammfran
            • Apr 2014
            • 476
            well, I am stumped.
            I went though my boards to see if I could find an so8 to compare readings, but most of my controllers are 14 or16 pin. I found an OZ9930Dn with 8 drop-in pin but I can not find a datasheet of that.
            325mV is like nothing
            Only thing I can think of doing is either removing resistors at R107 and R108 one at a time to see if that chip then puts out 5 volts at 4 and or 5 with them removed
            or
            If you have a fuse and since it doesn't seem like 4 or 5 are shorted, jump 5 volts to 4 and 5 to bypass the OZ (I think that should fire up the 2 aop609)
            • mokie
              • Jan 2014
              • 61
              • spain
              #26
              oh, this is getting even worse. I have removed R107 and when I turn it on the monitor doesn't do anything. I check with ohmeter and there's continuity between pin 4 and ground. I have removed the OZ and the continutiy persists.
              Maybe I should try to link an external inverter which I have over here.
              • bammbammfran
                • Apr 2014
                • 476
                R107 is on pin 5 side so that shouldn't have caused pin 4 to short.
                Pin 4 goes pretty much right to the 2 AOP607 so one of them must be shorted
                • mokie
                  • Jan 2014
                  • 61
                  • spain
                  #28
                  Yes, i have desoldered both mosfets and one of them was shorted. I give up.
                  Now I'm trying to connect an external inverter to power the lamps. I have located the ON/OFF wire coming from the logic board and now I'm looking for the brighness one. Do you know what range of tension have the brightness control?
                  • bammbammfran
                    • Apr 2014
                    • 476
                    the brightness is usually the pin next to the on/off where the two boards connect.
                    Your pictures do not cover that area from the bottoms so I can not point it out
                    it also travels to pin 7 of the OZ controller
                    No idea on your tension question ?
                    • mokie
                      • Jan 2014
                      • 61
                      • spain
                      #30
                      ok, thank you for all your help. I have located the brightnes control (next to the ON/OFF wire). When I change the brightness on the screen I can see how change the voltage on this wire.
                      But, the external inverter doesn't change the brightness at all. This inverter is like this one http://www.ebay.es/itm/390711004363 . It has 4 pins (V+, ground, ADJ, ON/OFF).
                      I will have to settle with change the contrast only.
                      • bammbammfran
                        • Apr 2014
                        • 476
                        did you check the voltage at the inverter to see if it is going up and down with dim ?
                        what is the highest and lowest it goes ?
                        other option
                        http://www.ebay.com/itm/LCD-Power-Su...-/231235076087
                        • mokie
                          • Jan 2014
                          • 61
                          • spain
                          #32
                          What do you mean by "at the inverter"?. I have checked voltage while connecting the inverter at pin ADJ and the tension is varying but not the brightness.
                          Maybe it would need more voltage, Right now I'm feeding it with 12v but the Vin says 10-30V
                          • bammbammfran
                            • Apr 2014
                            • 476
                            I wanted to know if the voltage right at the inverters pins of the power connector (not the bulbs) was going up and down.
                            and does it go all the way down to zero and up to 3 volts or do you have different amounts of voltages when you adjust it at the main board
                            Most of the inverters that I worked on like the one you are using used 12volts, so that should be ok
                            • mokie
                              • Jan 2014
                              • 61
                              • spain
                              #34
                              It goes from 1.1v approximately to 3.3v. It doesn't get to zero.
                              • bammbammfran
                                • Apr 2014
                                • 476
                                not all inverters go all the way to zero and some go as high as 5
                                either way, I would think that since your voltage does go up and down in the common range that the inverter should dim some
                                you can try to reset the main board settings to factory if you have that option
                                I had one that resetting it fixed the dimming issues once
                                you may even have warm / cool / etc user settings options that affect brightness
                                • SM-Piyes90
                                  • Feb 2014
                                  • 120
                                  • Morocco
                                  #36
                                  Hi everyone , am interested in this topic , and would like to put my two cents .
                                  Ok so we have here a working CCFLs but no display , witch leads to a lot of theorys but anyways , i se that you are measuring the Inverter IC outputs with a simple DMM witch is not a good idea , since the Inverter IC output is a high frequency square wave switching on/off the two MOSFETS .
                                  So since we are still in the inverter board stage we shloud clear it up first but you can make the same tests for the SMPS power board witch consists of a PWM IC and mosfet/s .
                                  IMO , start first with the power mosfets and check for shorts .
                                  And the best way to make sure the IC is working is checking the VCC pin first (~7 vdc) , and then putting oscilloscope probes at the IC outputs/driver to see if we got a square wave with an amplitudegoing from 5v to 12v.
                                  If all the above tests good then its time to check the HV transformer.
                                  • mokie
                                    • Jan 2014
                                    • 61
                                    • spain
                                    #37
                                    Appreciate your help but now I'm trying to adapt an external inveter that I have. As you can read before, I have located both ON/OFF and brightness control but the brightness doesn't seem to work. Later on I would try to reset the logic board.
                                      • 30964
                                      brightness issue may be a compatability issue.
                                      check the datasheets for the old invertor chip and whatever is on the replacement.
                                      there are 3 types of dimming.
                                      I2c serial
                                      PWM
                                      and variable voltage.
                                      • mokie
                                        • Jan 2014
                                        • 61
                                        • spain
                                        #39
                                        Maybe that's the problem. Now I have the monitor working without brightness control. Thank you all guys.
                                        • SM-Piyes90
                                          • Feb 2014
                                          • 120
                                          • Morocco
                                          #40
                                          What IC did you have on the older inverter and also the new one
                                          • m1ch43lzm
                                            by m1ch43lzm
                                            05-12-2025, 08:37 PM
                                          • advant
                                            by advant
                                            02-03-2020, 12:25 AM
                                          • lostone
                                            Looking for help with a Viewsonic VP230mb where the backlight comes on only momentarily
                                            by lostone
                                            Hello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
                                            First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
                                            When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...
                                            05-19-2024, 11:40 AM
                                          • stylishconsultant
                                            un60j620dafxza - Samsung No Display Problem
                                            by stylishconsultant
                                            Hi All,
                                            Need help.
                                            I have a samsung un60j620dafxza led tv. When I plug it in it has no display, no sounds, and no standby lights.
                                            So I opened the tv and disconnected the power to the mainboard and the backlight powered up. This according to many people says that this is a mainboard
                                            problem. I checked the voltage coming from the stb and I read 1.3 volts on pins 1,3,5 and 7 which are low volts instead of 13 volts which i think the lcd panel
                                            might be drawing too much power from the power supply that it prevents the right voltage going to the mainboard....
                                            09-04-2024, 03:26 AM
                                          • perzyk23
                                            Lenovo T580 - LCD Panel problem - error 0288
                                            by perzyk23
                                            Good morning,
                                            I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
                                            10-25-2024, 12:42 AM
