Dead iBook G4 screen
  • Tom41
    • Oct 2005
    • 336
    • England
    The LCD on my Mac iBook G4 has just died. If I look with a flashlight, I can still see the picture on the display - there's just no backlight no matter what I do. I think the laptop took a little knock, and since then it's had no backlight.
    The laptop itself is still working properly (in fact I'm using it now to type this); I just need to plug it into an external monitor to see anything - which kinda defeats the object of it being portable.
    The backlight is not even flickering when I move the lid and adjust the brightness control; there's no response from it whatsoever (not even a dim glow). In the one part of the laptop that I can take apart; the slot beneath the wireless card where you put in additional memory and I can't see any cables that might have fallen out. Is there anything I can do to try and revive it, or am I doomed to having to send it away to Apple for fixing?
    You know there's something wrong when you open your PC and it has vented Rubycons...
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Re: Dead iBook G4 screen
    i think you will have to completely disassemble to see what is going on whether a cable has come loose or the inverter is busted or the ccfl tubes are damaged or dead.
    here is a few disassemblies to see what is involved
    http://repair4laptop.org/notebook_lcd_display.html
    probably you can fix it yourself. if the ccfl tubes are busted then make sure you order ones with the same colour temperature otherwise the screen will not look the same
    • starfury1
      • May 2006
      • 1256
      here's another disassembly how to here
      Not really the voice of experience with mac screens but as Willawake said most likely inverter or backlight
      (hope for your sake, it is a lose connection)
      although I've never used them possibly try Ifixit for parts
      (or get an idea of what you need)
      HTH
      Cheers
      You step into the Road, and if you don't keep your feet, there is no knowing where you may be swept off to." Bilbo Baggins ...
      • willawake
        Super Modulator
        • Nov 2003
        • 8457
        • Greece
        the important things when disassembling laptops are to first do some research and find some howtos or pics for the disassembly. to get familiar with the sequence, it is often not the same. Then you must document it step by step as you proceed. i usually get some paper and stick the screws to it with sellotape and annotate on the paper. there are usually many screws of different size. i also take photographs periodically.
        i cant really help with the inverter troubleshooting i know a few here can though. replacing tubes is not too bad. just need surgical gloves though to handle them and also must be so goddamn careful when soldering the wires to new tubes. need something to hold them steady. any stress and pop tinkle. and you really only get your 3 seconds of soldering otherwise again pop tinkle.......apart from that it is not too bad.
        • Paul S
          • Sep 2006
          • 326
          Here's a link to an inverter repair site, I think they are in the US:
          http://www.laptop-inverter-repair.biz/
          And their sister site on ccfls:
          http://lcd-backlight-ccfl.com/
          I got a replacement ccfl for my Inspiron 1150 laptop from an eBay dealer. The color is not quite right. As Willawake said, the color is important, but I don't know what the color ranking method is. I don't recall seeing it listed at the ccfl sites I visited.
          Replacing the ccfl is the cheapest, so do that first. Save the old ccfl, if it doesn't fix the problem you may want to put it back in.
          My laptop inverter has a short in the transformer. Here's some pics, sorry for the poor quality as I used a camera from work. (That's why I posted about what's a good digital camera.)
          • starfury1
            • May 2006
            • 1256
            Yes willawakes advice above is very very sound good advice....Always Document your disassembly
            To add to paul S on inveters
            Found these on inverters, not sure how much use they will be.
            here
            look more at the bottom of this page
            Here
            more really a "send it to us we fix" but has info on their construction and faults
            parts plus few how to's
            not really directed at ibooks thought and it does have a how to change backlight like willawake was describing above
            (maybe willawake can offer an opinion on it)
            here
            HTH Cheers
            BTW should have made it a bit clearer too....the link in my post above is for a IBook G4 according to the info in the first bit of text....
            (not that you could tell that from the title)
            • Paul S
              • Sep 2006
              • 326
              Yes, by all means take pictures of how the ccfl is installed. By the time I got a new ccfl, I had forgotten exactly how the dam thing went together!
              I did the best that I could, but now I have some bright sections along the edge where the ccfl is.
              The color on mine isn't right, so I ordered a different bulb. I'll have a chance to get it right the second time. First I'm gonna get a digital camera to record the disassembly.
              • willawake
                Super Modulator
                • Nov 2003
                • 8457
                • Greece
                ccfl colour temperature is measured in Kelvin or K
                if it is not right then the colours will be more blue, red or yellow depending on what wrong temperature was purchased. It is exactly similar to incorrect white balance in a digital camera which is also measured in K.
                There is a setup feature in some monitors that allows the selection of colour temperature. There may only be something like 3 choices however. I have not tried to setup a monitor with wrong bulbs that way though.
                Problem is that sometimes it can be difficult to find data on what colour temperature the tubes in the monitor are.
                • Donny2derby
                  LGOLED55B7V Clicking and dead screen.
                  by Donny2derby
                  Picked this up other week and when I originally looked at in the sellers house I got 3/4's of a working screen and some horizontal lines across the 1/4 of it which was dead/black.
                  Just tried powering it up at home and now all I'm getting is a clicking and some very faint lines on 1/4 of the screen whilst the entirety of it is dead.
                  When using the remote I get two red clicks on the standby. Not sure if this means anything or helps. The same when I use the manual power up.
                  Help appreciated. I'm an electrician, I've fixed a few in the past so not a total...
                  08-10-2023, 04:23 AM
                • aazjo
                  A1502 screen only issues
                  by aazjo
                  I have a MBP A1502 (early 2015, 820-4924) with a screen that will not turn on. I have swapped screens with a cracked test screen and the computer boots and the cracked screen works for both backlight and image. The black/blank screen appears to do nothing.
                  I have collected resistant data from the cracked screen connector pins and submitted to OBData server:
                  1 PPVOUT_SO_LCDBKLT OL
                  3 I2C_BKLT_SCL 9.97M
                  4 I2C_BKLT_SDA 9.89M
                  5 PP3V3_S0_EDP_R 79.10k
                  6 SMBUS_SMC_0_S0_SCL 321k
                  7 SMBUS_SMC_0_S0_SDA 323k
                  8 EDP_BKLT_PWM ...
                  11-04-2021, 11:46 PM
                • maxim2511
                  LG 55EC930V OLED - swich on swich of no screen
                  by maxim2511
                  My Oled Tv is 55inch tv, 3 days ago I notice that middle of the screen is getting warmer and on picture I have ghosting, missing red color. Color red was still displaying, but it was not so strong as corners of the screen and watching some movies makes me angry.
                  Then I get an idea to take it apart and clean boards from dust.
                  In side of Tv was not so bad, I take compressed air in can, and gently blow up.
                  Also I was thinking to styrofoam sponge to isolate power board from screen that the middle of the screen will not worm so much. Because Led on screen when gets higher...
                  05-14-2021, 02:21 AM
                • kino0924
                  Screen Replacement for A2337
                  by kino0924
                  I have a 2020 macbook air m1 that needs a screen replacement (cracked)
                  Right now, I have few options but not sure what to take
                  1. Screen only from aliexpress (80 USD)
                  2. Housing and screen from aliexpress (144 USD)
                  3. Genuine used screen from ebay (250 USD ish)
                  4. New screen from ifixit (450 USD)
                  To be honest, I dont think new screen from ifixit is worth it since I can get it replaced by apple with same amount of price (haha)
                  Now, I am wondering is it really worth to spend 100 more on used genuine screen....
                  01-19-2023, 02:02 PM
                • dicky96
                  HP Elitebook Screen blank - backlights but no image
                  by dicky96
                  Hi guys
                  I'm trying to fix this laptop screen
                  Basically the owner is a computer shop and they brought it to me with two screens. They said the repair shop they use could not fix it, so I thought i would try to see if I am better than their current repairer!
                  OK so I have the original screen which works but has lines across the bottom quarter of the screen
                  I have the replacement screen, which they fitted and it worked. They then put the laptop on one side for a couple of weeks until they found a buyer. When they showed it to the buyer, the screen would...
                  04-28-2021, 07:30 AM
