Hanns G HG191A monitor
  • mariushm
    • May 2011
    • 3799
    This lcd display went through my hands, no questions really as the problem was a faulty ccfl tube which got replaced with one from another display I had around so it works now.
    It's just that it was a bitch to open and put back together (involved 20+ minutes of using plyers to cut metal back so the ends of the new lamp would fit) so I figured it would be worth to at least post a picture of the power supply inside and the bad ccfl tube.
    Elite caps everywhere, they look ok so I didn't bother changing them.. it's a "value" lcd monitor anyways with poor view angles and just 1366x768
    audio input is a crappy dip package amp, didn't bother to remove the "heatsink" off it.... the vga board is probably the plain generic vga board, couldn't be bothered to remove the vga connector screws to pull it out.
    In case it helps someone finding this thread through google, the panel worked with the display board and power supply from a 20" lg monitor I had with bad panel.
    psu
    bad ccfl
    sound amp and display board (back)
    great success
    master hoarder
    • May 2008
    • 12175
    Re: Hanns G HG191A monitor
    That power supply looks exactly the same to what was in a HP W19b monitor I fixed a few years back. Mine had a white screen due to shorted ceramic cap on t-con board. The Elite EB caps were fine when I checked them. Overall, this particular PSU runs cool, so I don't expect there to be too much problem with the Elite caps... not any time soon anyways.
    ChiMei by any chance? In my experience, their panels have the worst viewing angles I have seen.
    • DanPoka
      by DanPoka
      02-15-2025, 05:05 AM
    • RetroComputingGrotto
      Hanns.G Hi221 Monitor - Works For A Second & Then Blank Display
      by RetroComputingGrotto
      I've got a Hanns.G Hi221 Monitor that works for a moment and then the display goes off but the power LED indicator remains on. If you power it off and back on again it does the same thing, it comes on and then the display goes blank. From a cold start it takes 10 seconds or so before the display goes blank but if you turn it off and then back on again after it already being on it goes blank a lot quicker so I'm assuming something is getting hot which is causing the display to go off.
      I've uploaded a video of it happening on YouTube:
      I've taken the monitor...
      01-11-2024, 05:37 AM
      by momaka
      03-15-2023, 10:17 PM
    • wattage
      by wattage
      Hello Badcaps Community,
      07-13-2025, 04:41 PM
    • ant3202
      HP 27es - LED monitor - Monitor Flashing On - Off
      by ant3202
      Hi Everyone
      Lately I am experiencing the deja-vu incident on one of the led monitor like this.
      https://www.badcaps.net/forum/troubl...lashing-on-off
      The monitor is HP 27es LED Monitor
      https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
      The monitor will randomly blackout and display no signal and will recover again.
      Sometimes need to power and off again to restore the display but...
      03-20-2025, 07:30 PM
