Acer AL1916W, can't find the problem
  • selldoor
    Slow Learner
    • 7870
    Re: Acer AL1916W, can't find the problem
    ok I must have misunderstood something earlier when I said its no good testing lamps as you have no voltages. I have read through and you do have 5v and 13v so do you have any bulbs in anything you can use test are anything you can test these ones in.
    If not, do you have a 3v battery or a 500 ohm or 1k resistor perhaps you can force start the power supply with the main board disconnected - that will bring lamps on hopefully.
    • Phoenix83
      • Jan 2014
      • 53
      • Slovakia
      I try to connect 4 bulbs like BUDM wrote in here: https://www.badcaps.net/forum/showthread.php?t=19987, they don't light up.
      So the inverter don'd work, think.
      • selldoor
        Slow Learner
        • 7870
        OK do you have a 3v battery( CR2032) or 2x 1.5v batteries or a 500 ohm or 1k resistor
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4286
          • Italy - Milan
          the inverter must be switched on with the command from main board or from a connection between 5v and bl_on signal through a 1k resistor but don't use cfl lamps like budm , use its own first, that can be good..
          • Phoenix83
            • Jan 2014
            • 53
            • Slovakia
            Yes have batteries, 500ohm, and 1k resistors.
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4286
              • Italy - Milan
              #26
              ok you have the pin labels near output connector but its on the shadow in your pic. so locate by yourself the blon pin and do what i've said previously, if you have doubts post here the pinout, please don't post picture, baadcaps.net's harddisk is not big from there to the ionosphere
              • Phoenix83
                • Jan 2014
                • 53
                • Slovakia
                #27
                Here's pinouts
                ADJ EVA
                GND GND
                GND DET
                +5V +5V
                +13,8V V_adj
                MUTE SHUT
                ADR- ADR+
                ADL1 ADL+
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4286
                  • Italy - Milan
                  #28
                  i don't understand labels , are uncommon, last 6 left/right are for audio, remains adj, eva, adam.. ehm sorry.. det, v_adj, but those adj seems "adjust" so a variable signal like the brightness, i think EVA is not EVA but ENA=enable=bl_on, whatch better.
                  • Phoenix83
                    • Jan 2014
                    • 53
                    • Slovakia
                    #29
                    Find this in service manual:
                    CN5 input connector:
                    Pin no........symbol........desc.
                    1..............AOL+..........audio
                    2..............AOL-..........audio
                    3..............AOR+..........audio
                    4..............AOR-..........audio
                    5..............Shutdown....audio
                    6..............Mute...........audio
                    7..............Vol_adj........audio
                    8..............+13,8V........+13,8V
                    9, 10.........+5V............+5V
                    11............Aud_DET......audio
                    12, 13, 14..GND............GND
                    15............ON/OFF........Enable (on): 3,3V; Disable (OFF): 0V
                    16............BL_Adj.........Dimming control (PWM=260Hz Vpp-p=3,3V)
                    Hope it helps
                    • Davi.p
                      Hobbist Tech
                      • Sep 2009
                      • 4286
                      • Italy - Milan
                      #30
                      so the EVA you wrote is the on-off, do the test discussed earlier..
                      if the lamp doesn't light up place a 1k resis. also to BL_adj and 5v
                      • Phoenix83
                        • Jan 2014
                        • 53
                        • Slovakia
                        #31
                        I don't understand this so much ...
                        • Davi.p
                          Hobbist Tech
                          • Sep 2009
                          • 4286
                          • Italy - Milan
                          #32
                          I think he suggested a lamp testing but if you have not tested the onscreen lamps for now is unuseful, the second part he repeat what i've said earlier about the ps board power on forcing with 1k resis. (aahh.. aaahh.. oxigen!..)
                          • selldoor
                            Slow Learner
                            • 7870
                            #33
                            Yes I was suggesting testing the lamps but if you cannot use another monitor to test them and dont have spare bulbs then I or Davi will instruct you on how to try to jump start the power supply with a resistor.
                            First though can you look on the back of the board for R210 - in your picture it is
                            to the right of the 14 legged IC in the top left corner. Is it marked 10R0 and can you test it - just on the board for now.
                            • Phoenix83
                              • Jan 2014
                              • 53
                              • Slovakia
                              #34
                              R210=10,3ohm
                              How can I try to start it up with a resistor? And the battery for a what needed?
                              • Davi.p
                                Hobbist Tech
                                • Sep 2009
                                • 4286
                                • Italy - Milan
                                #35
                                Have you forgot? I've told it in the past 10 posts
                                • selldoor
                                  Slow Learner
                                  • 7870
                                  #36
                                  Its either the resistor OR the battery - I ask if people have either but they are used differently but for the same purpose.
                                  Thinking is that the main board is not sending a signal to the power supply to switch on so we reproduce that.
                                  The signal is usually 3v so whet you do is disconnect the the main board
                                  and connect a 500 or 1kohm resistor from the 5v pin on the connector
                                  to the on/off pin (looks to be pin 15). If you have the lamps connected then
                                  when you switch on/plug in the power supply they may light or at least flash.
                                  Sometimes it is necessary to also jumper the 5v to the BL adj (pin16)
                                    If the main board BL_ON line is stuck LO, then you have to disconnect that line otherwise it will keep that force on voltage to be low.
                                    • Phoenix83
                                      • Jan 2014
                                      • 53
                                      • Slovakia
                                      #38
                                      So I joined pin 9 to pin 15 through a 820ohm resistor. Backlight started flashing. At least something works. I need to find the SM for model with RTD2533V scaler. Some manuals I have found but they are all with TSUMs
                                      • selldoor
                                        Slow Learner
                                        • 7870
                                        #39
                                        Hurray - as you say something works though flashing may not be enough!!!
                                        Anway did you see this
                                        http://mvptek.koreasme.com/en/produc...uct_04_03.html
                                        looks like pinout for the IC.
                                        If as we think it is just not getting a BLON signal - how about trying to trace pin 15 back -may just be one of those little switching transistors stuck.
                                        Can you post a better picture of the part of the logic board with pin 15 and going across
                                        • Davi.p
                                          Hobbist Tech
                                          • Sep 2009
                                          • 4286
                                          • Italy - Milan
                                          #40
                                          I remember that the switch board shows a dual led lit, it's not normal i think, the problem is more probably in the mcu, after that why backlight flashes i don't know..
                                            09-06-2024, 05:27 AM
                                          • fmajbour
                                            Acer Nitro 5 model A515-51 keyboard problem
                                            by fmajbour
                                            I have ACER Nitro 5 model AN515-51 main board model LA-E911P Rev 1A after replacing the mainboard keyboard stop working properly.
                                            Some keys not working like Q,Z,C and some keys show deferent chr$ if i press K i will get I press D for F4 key etc...
                                            i have tried all software issues like drivers test the keyboard on Windows 10 and Windows 11 and Linux with same problem.
                                            I have check the keyboard connector on the mainboard every thing looks ok.
                                            Then i replaced the keyboard with new one ......same problem exact same keys problem.
                                            I need your advice if anyone face...
                                            11-13-2023, 09:50 PM
                                          • ahmarzo
                                            Acer TMX314-51 laptop battery problem
                                            by ahmarzo
                                            I have acer laptop tmx314-51 with part no 6050A3020501.
                                            The laptop is working fine on adapter and battery is also charging and when adapter is disconnected in on state the laptop gives backup on battery and gives good backup.
                                            But when laptop is powered on through battery only the laptop does not power on and there is 0 voltage on battery connector.
                                            I have not not tried another battery as it is not available locally could this be a battery problem.have checked discharging mosfet and there is no shorting to ground on any pin of battery connector.
                                            The schematic is not available...
                                            04-11-2025, 09:14 AM
                                            Acer Aspire Acer Aspire 7 Charcoal Black Notebook 7 Specification for Upgrade or Repair
                                            This specification for the Acer Aspire Acer Aspire 7 Charcoal Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 7 Charcoal Black boardview and Acer Aspire 7 Charcoal Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                            09-07-2024, 05:00 AM
                                            Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook 3 Specification for Upgrade or Repair
                                            This specification for the Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Swift 3 Ultraschlankes Notebook boardview and Acer Swift 3 Ultraschlankes Notebook schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
