Dell E248WFPb lots of vertical lines
  • GoneGault
    • Sep 2013
    • 105
    I have a Dell 24" monitor with vertical lines. Tearing it down, I don't see anything obvious. Can anyone give me some ideas to check?
  • selldoor
    Slow Learner
    • 7870
    Re: Dell E248WFPb lots of vertical lines
    Try unplugging cleaning and replugging all cables between video board and
    panel.
    If you unplug J3 you might get a plain white screen - backlights only.
    Any lines showing?
    EDIT Unplug with power off
    What is that little board between the main and the power
    • GoneGault
      • Sep 2013
      • 105
      Somehow I left a picture of the tcon board off, and I suspect it is the most likely culprit!
        It does not look like panel problem, either T-CON or the main board. How are the voltages on the T-CON?
        • GoneGault
          • Sep 2013
          • 105
          Voltage across the legs of the main capacitor on the power supply is 164v plugged up, but not turned on. With the monitor turned on it is 303 v. I pulled the main cap and checked it and it's uf value was good. I pulled, tested (they were ok) and replaced the 3 small caps on the main board. Started it up and it still has the vertical lines.
          Working upstream, I will now pull and test the caps on the 2 small boards that are between the main board and the tcon.
          • GoneGault
            • Sep 2013
            • 105
            I pulled and checked all the caps on the small board that connects to the main board; all were good. When soldered back in, the same problem persists.
            While replacing caps on the main board, I did notice a discoloration around D702 (picture); I don't know if it is significant and I don't know how to check it. Any help would be appreciated.
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4299
              • Italy - Milan
              No no no wait... that is not main board, please stop dismounting all the things without a reason, budm, YOU and i suspect the T-con especially and main/scaler board, the little board contains for what i can see 1 or 2 switching dc-dc reg. so if you want to suspect power issue test this board's outputs and report, after test also the T-con testpoints especially GMAVDD2, VGHC1, GAVDD1, GMAVDD1, VGH1, XVCC1, GAV1, GAVCC1, DAVDD1, V33, 5V1, VcomD, after search the web for the keywords -one of previous and the model of the panel- for example "(GAVDD1 OR GMAVDD1) LTM240T1-V2" so you can find places where someone, for example other users, post their voltages, bye!
              • nocturnalambition
                • Sep 2015
                thread has been a long time dead but I am having the EXACT same issue as the OP. Any pointers? As I have never attempted a monitor fix.
                • Stanley1843
                  by Stanley1843
                  06-29-2024, 11:54 AM
                • atticus_
                  Dell U2518D strobing/flashing with vertical lines
                  by atticus_
                  I dumpster dived a 1440p Dell U2518D screen the other day and figured I'd take a crack at fixing whatever issues it may have. I powered it up to find that even with no signal input the screen flashes rapidly when turned on and has vertical lines across it. I disassembled the monitor and took pictures of the 3 circuit boards inside it along the way.
                  The three circuit boards are labeled "power board l6256-1m", "LED Driver BD L6257-1". and "Interface Board L6127-1". if anyone has schematics for any of them it would be much appreciated...
                  06-16-2022, 02:49 PM
                • gpo23
                  Sony KDL-40V3000 - Vertical lines
                  by gpo23
                  i order a t-con because i had bad colors on my SONY KDL-40V3000 :
                  With the new t-con the color are good but there are vertical lines on all the screen :
                  I've tried the old t-con and it returned to the initial issue (bad colors but no vertical lines)
                  Is there a way to fix the vertical lines on the new t-con ?
                  Thank you for your help
                  gpo23...
                  10-04-2023, 09:11 AM
                • Firentiosi
                  1/3rd of screen black with occasional vertical lines - repair attempt for learning! - Kogan KALED58RT9220SVA
                  by Firentiosi
                  Thanks for offering your assistance with this. I'm an electronics enthusiast with moderate level of competence (have a decent lab with two power supplies, microscope, DSO, hot air, good iron, can competently work at a component level on SMDs, design and solder own PCBs etc). I really enjoying fixing things and learning new stuff so took up a free 58" LED TV and have been googling and watching Youtube videos to see if I can fix this! I am happy to go down to individual component replacement/strip replacement etc - it's all in the name of learning.
                  The issues are as follows: the...
                  11-27-2024, 12:33 AM
                • viking509
                  vizio e65 e3 LED tv color vertical lines center tv only
                  by viking509
                  I recently replaced the led backlights with LB65041 LED Backlight Strips and after putting it back together the backlights work but there are only colored vertical lines only in the center of the tv. I can see the Netflix logo (jumbled) after a minute or less the screen went dark. When I turned it on again the lines were back. Then I replaced the t-con board but the same vertical lines in the picture. My question is what is my next step? Could it be a source tab bond issue? A buffer board issue? Could I have loosened a connection to the panel when replacing the backlights? Should I replace the...
                  03-21-2023, 12:48 AM
