OSD Menu appears on own, LG Flatron W2361v
  • InsightBCK
    • Jan 2014
    Hi guys,
    So I have an LG Flatron W2361v outside of warranty, and the darn menu just pops up on-screen as it pleases, and stays put until it pleases. Pressing the button on the side does affect the menu, but sometimes it will just pop right back up.
    I've also noticed that the buttons no longer function in the way that they should... Every button does the same thing, except for one which will temporarily black the screen... I think that's the Auto/set function, but it's not the Auto/set button that performs it!
    I tried opening it up and disconnecting the menu and power PCB, but it would no longer display its screen.
    Then, when I plugged them both back in, I got the 2 seconds to black problem. I left it overnight, reassembled it, and it functions again, but with the same pesky OSD problem. I'm thinking it may have resolved both issues if I had left them off overnight, and plugged it back in that way.
    I've already broken the plastic a bit in my haste to and frustration with fixing it, but ultimately it's still a functional monitor and if I can fix the OSD problem I think I could keep it going until I can afford another one.
    Thanks for any help.
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: OSD Menu appears on own, LG Flatron W2361v
    Is it a button board with proper buttons or one of those sensor types?
    If buttons try cleaning them.
    Also make sure the connection to the main board is secure
    • InsightBCK
      • Jan 2014
      It's a button board, I tried swabbing it with rubbing alcohol, maybe I need to get under the buttons?
      How do I ensure the connection is secure? Do I need a multimeter or something? Or is it simply a matter of looking at the cables? Thanks for the help, man.
      • InsightBCK
        • Jan 2014
        Okay, well, I assume it has something to do with the connection - I took the menu PCB OUTSIDE of the bezel and left it lying behind the monitor on top of my speaker. No more symptoms.
        What can I do to diagnose and come to a more permanent solution utilizing this new information?
        Also, I broke the bezel clips so the monitor will never come completely together again, but I don't particularly care so long as it functions until I can afford a new one.
        • selldoor
          Slow Learner
          • Dec 2010
          • 7870
          Hi , must have missed your previous post - if you have a multimeter you can check out the board and cable. Unplug it from the main board,set your meter on ohms and test across the solder joints for each button. Press the button and the value should change from low to high (or infinity) or vica versa.
          If that doesnt show anything up then you can test from the button to the
          end of each wire within the cable.
          • Behemot
            • 4845
            • CZ
            I got this one, the inventer transformer was bad which is fixed now. But the capacitive sensor button is driving me mad, it is poping the menu, if you lock OSD than it triggers the "OSD locked" window. Would it be possible to replace with ordinary mechanical button?
            • bammbammfran
              • Apr 2014
              • 476
              do you have a picture of the button board that you can share ?
              the OP never posted one that I noticed
              If it is a touch sensitive button then a standard switch will probably not work
              • Behemot
                • 4845
                • CZ
                I gave it back to the owner to try to fix it again when he will get enough of the poping.
                I noticed some touch plastic, 4 LEDs and some SOP-8 IC. The second board with other buttons (SMD) is connected here and this capacitive board is connected to signal board.
                It probably is somehow deliberately connected into the display circuitry as one of those LEDs lights when I have D-Sub connected to monitor, even without power cord! But there is chance, if the whole capacitive board just behaves as one special switch, sending some signal back, than it may be bypassed by ordinary electromechanical switch?
                • Sraros
                  • Jan 2017
                  • 223
                  • Greece
                  Although this is an old thread, I wanted to say I have the same issue but for sure it's not the buttons. I had the same issue, popped out the power board and found a small diode blown, I replaced it and thought it got fixed but then again started again going crazy on the OSD. So I removed completely both boards and it still does the same! Can it be some bad caps or sth else?
                  • torkiy
                    • Dec 2020
                    • 11
                    • maroco
                    SHARP LC-32AF10N Main Board QKITPF537WJN6
                      LCD LED TV Service Menu Codes
                      TCL LED TV Service Menu Code
                      LG LED TV Service Menu Code
                      10-31-2024, 03:58 AM
                    • Retro140
                      Unnlock Menu for 2007 DU-27FB32C comerrcial CRT TV
                      by Retro140
                      So I was referred here when I made this poste over on AVForums: https://www.avsforum.com/threads/loc...lg-tv.3257234/
                      To summarize, this is a commercial TV and I can't get a menu of any kind. I know the overlay is working because when I change channel, adjust volume, turn on sleep timer I do see text. But I have not ever seen the user menu nor the installers menu. I've tried a bunch of remotes(more info on the AVF post) and tried every button...
                      06-18-2023, 06:13 PM
                    • Ierwin
                      Philips 58PUS7805 Menu working but no/weird picture from video sources
                      by Ierwin
                      I got a 58pus7805 that shows some weird behavior.
                      The menu and remote work fine and the picture is looking crisp and flawless while navigating the menu.
                      However, when a video source is displayed the screen either goes solid green (HDMI), solid black (SAT TV) or shows some fragments on mostly green background (AVI Playback from USB).
                      I tried to reinstall the firmware through the menu which was rejected saying it already had the latest version.
                      I managed to install the latest official firmware by holding the control button while plugging...
                      03-10-2024, 12:50 PM
                    • electrophoros
                      LG Flatron W2361V PSU Troubleshooting
                      by electrophoros
                      Hi everyone.
                      I am trying to troubleshoot this computer screen which went black and won't power on after a power surge.
                      I have measured the output voltages and there seems to be proper voltage pressence on the 5V outputs, there is no voltage on the 22V outputs and I am unsure of what I should be measuring on ADIM, BDIM, EN and OLP.
                      There also doesn't seem to be any voltage on the backpanel outputs:
                      I have already identified and replaced two bulging electrolytic capacitors, and there is voltage after the fuse.
                      07-27-2022, 07:37 PM
                    • vf fa
                      EIZO CX270 - No signal but Backlight and Panel works, logo works, admin menu works. OSD doesn't. What?!
                      by vf fa
                      Hi, so i guess Iยดll have to make a new topic here, as i browsed through hundreds of other threads but couldn't find a solution to my problem yet.
                      I got a EIZO CX270 from a friend. He said it doesn't work anymore and wont display any signal or take any OSD inputs. Well, as an aspiring photographer I couldn't say no, could I? Thought it was an easy game, replace a bad cap and have a working monitor. But nooope, it wasn't supposed to be this easy.
                      So let me start with the problem description. I'll try my best not to skip anything so this might get rather long.
                      01-31-2024, 01:40 PM
