ASUS VH222 has no image
  • ucdzombie
    • Nov 2013
    • 54
    ASUS VH222 23" LCD screen. Powers on, but has no image. Tried the flash light trick and saw faint image. So either inverter is bad or back light is bad. I'm suspecting the inverter because there's a discoloration spot on the power board. Please take a look at the picture with the voltage reading. Any help will be appreciated!
  • newtothis
    • Mar 2013
    • 1556
    • england
    Re: ASUS VH222 has no image
    Can you take a pic of the connector that goes to the logic board so we can see the silk print please.
      If you look at the screen in the dark room, do you see the backlights flash on for seconds?
      • ucdzombie
        • Nov 2013
        • 54
        Apologize in advance because I'm not sure if this is what you're looking for. I'm a complete dummy. There're two connectors
        • ucdzombie
          • Nov 2013
          • 54
          I don't remember seeing it flash at all. When it turns on, there's no back light because the color of the screen doesn't change to dark bluish grey. I will check again today.
          • selldoor
            Slow Learner
            • Dec 2010
            • 7870
            Could easily be the inverter transformer.
            Can you see the numbers on it?
            May be one of these?
            http://www.lcdparts.net/TransformerD...ProductID=3699
            To test - no power to board meter on ohms 2000 test S1 to S2 and S3 to S4
            • ucdzombie
              • Nov 2013
              • 54
              OK I got the reading:
              S1 to S2 has 500 ohms, S3 to S4 has no reading at all. I didn't de-solde the transformer. I tested by touching the leads on the back of the board. Did I do it correctly?
              • ucdzombie
                • Nov 2013
                • 54
                OK guys, another update! Today I turned it on, the LCD screen actually turned on. I saw the ASUS Logo, and I could see the desktop for about 1 second before it went dark. Power light stays on (blue).
                • ucdzombie
                  • Nov 2013
                  • 54
                    OK, then check the transformer high voltage windings resistance, you can have bad lamps also, you may have get a couple test lamps or make some otherwise you can spend a lot of time trying to fix the board when you may have lamps problem, need to narrow that down.
                    https://www.badcaps.net/forum/showth...er+testing+cfl
                    • selldoor
                      Slow Learner
                      • Dec 2010
                      • 7870
                      budm - looks like his inverter transformer is shot - if he is testing it correctly.
                      500 ohms and 000 ohms!! post 7
                      ucdzombie - we really need the part number off the transformer but it doesnt
                      look good.
                      If you cant read the number (even parts of it might help)
                      then a picture of the back of the board where the transformer is so we can see where you measured. Sometimes there is lacquer on the joints try again
                      making sure you are down to metal.
                        Sorry, I missed that post.
                        • ucdzombie
                          • Nov 2013
                          • 54
                          look good.
                          Here's the part number I think:
                          http://www.ebay.com/itm/Inverter-Tra...-/261267004394
                          And the back of the board:
                          Also, remember I said that there's a discoloration spot on the board where those two Zeners are. They're weird. One side has 15v and the other side has 0v (as shown in the first post).
                          Thank you everyone for being so supportive!!!
                          • selldoor
                            Slow Learner
                            • Dec 2010
                            • 7870
                            Remove it and test again check the winding is not snapped just by the pin - if it is it may be re-attached
                            I would get one ordered from the link you have found.
                            I dont know about the zeners -perhaps they just run hot - budm would know better.
                            Perhaps upgrade any caps associated will help them run cooler.
                            • Davi.p
                              Hobbist Tech
                              • Sep 2009
                              • 4476
                              • Italy - Milan
                              The not turning on of the backlights and the lack of a voltage on that ferrite seems to me a strange behavior for a normal transformer or ccfl failure, can you post a picture of the downside, 'cause is needed to watch at wich point to test for the psu outs.
                              • ucdzombie
                                • Nov 2013
                                • 54
                                Updates! The transformer enjoyed a nice barbecue and S4 was burned beyond recognition. Look at the charcoal on the board. So I'm wondering, what if i just solder another wire onto S4 and make a new pin?
                                • ucdzombie
                                  • Nov 2013
                                  • 54
                                  What do you mean by the downside? You mean the other side of the PSU?
                                  • Davi.p
                                    Hobbist Tech
                                    • Sep 2009
                                    • 4476
                                    • Italy - Milan
                                    i mean "lower side" but now you have found the problem.. don't photograph..
                                    • selldoor
                                      Slow Learner
                                      • Dec 2010
                                      • 7870
                                      WoW! not seen one do that before - if you can find the end of the wire, you can try and fix it. To solder you will need to scrape the laquer insulation off the end of the wire. before you move on to making a pin test the resistance again it needs to be within 3 % of the other one so 485 to 515ohms if the s1 to s2 is correct..
                                        The wire will be hair thin, it is going to be difficult job since the wire will be too short to reach the post.
                                        You will also have to remove the carbonized section of the board since carbon conducts electricity especially it is in the high voltage section that can be as high as 1500V or more.
