ASUS VH222 has no image
Re: ASUS VH222 has no image
The wire will be hair thin, it is going to be difficult job since the wire will be too short to reach the post.
You will also have to remove the carbonized section of the board since carbon conducts electricity especially it is in the high voltage section that can be as high as 1500V or more.Last edited by ucdzombie; 12-06-2013, 04:07 PM.Comment
When I solder the magnet wire that thin, I just wrap it around the post and applied hot soldering Iron to it, it is enough to take of the enamel coating off the wire.Never stop learning
budm - I think he is asking about repairing the board - scraping the carbonised area.
I am off to bed so unable to help him tonight.Please upload pictures using attachment function when ask for help on the repair
http://www.badcaps.net/forum/showthread.php?t=39740Comment
The carbonized section is very small and it only burnt through the top layer. So maybe I can apply some type of solution to the that area?Comment
I would scrape it off with sharp knife or small flat blade screw driver.Never stop learning
OK some updates. First I got the monitor to work after installing the new transformer. However, after using it and messing with the resolution for about a hour, something weird happens. There're some stripes showing up on the monitor. Also, when I boot up the monitor and the ASUS logo shows up, the lower half of the screen is white for a second, and then the white is gone. Is the TCON board getting too much voltage??? I haven't modified anything except installing the new transformer.Comment
Did you already try re-seating the LVDS cable?Never stop learning
OK will try this tomorrow. But I think it's pretty tight already. Are you talking about the one that goes from the PSU to the logicboard? Or the the one from the logicboard to the TCON?
Also, this symptoms goes away if I unplug the monitor for more than 15 minutes.
One last thing, when I was installing it today, there was an accident. The cable from the switch panel was placed between one of the heatsinks (I don't know what's it's called. But it's the big metal bar) and the metal shell. When I plugged in the monitor for the first time, it made a spark. I thought screwed up the monitor. Later I fixed the cable, and it turned on fine. And then this symptom appears after 15 minutes or so.Comment
Logic to T-CON. Also make sure all the board mounting screws are tight since it uses the chassis as the ground.Never stop learning
Do you think the spark I made yesterday from the accident could have burned something? How comes it's so random?Comment
We are sure exactly where the spark happened, can you show us? But since you did get good pictures for an hour, then the spark may not be related to the problem.Last edited by budm; 12-26-2013, 08:11 PM.Never stop learning
If you look at my first post with the picture, it's the big metal bar on the right. What happened was that I accidentally placed some wires (wrapped) between the metal bar and the protective metal shell. When I plugged it in, it made a spark right there because I saw some burn mark on the wire wrapping and the metal bar, as well as the metal shell. So maybe the wire wrapping conducted electricity and it shorted something? But the monitor worked fine afterward for 15 minutes.Comment
You may try cooling the board with canned air using it upside down for cooling to see if the problem will disappear since the problem seems to happen after warm up.Never stop learning
You can't see the burn mark in the picture because it's taken before I assembled it.Comment
OK will do. If this is the problem, will there be a long term fix solution? Like installing a heat sink??Comment
That heatsink has line voltage on it, you probably shorted to safety ground. Need to see which component is bad first.Last edited by budm; 12-26-2013, 09:41 PM.Never stop learning
You said to find the bad component. Is there any standard procedure I can follow to test? I can't even find the fuse on the PSU. Sorry I'm such a noob.
And lastly, if I don't fix this problem, will it hurt the monitor? I mean it's not very noticeable at all.Last edited by ucdzombie; 12-26-2013, 10:45 PM.Comment
by DynaxSCHi,
Usually on ASUS boards it worked...-
This specification for the ASUS VivoBook ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD boardview and ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...09-07-2024, 02:50 AM
This specification for the ASUS ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year boardview and ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively...09-07-2024, 02:50 AM
This specification for the ASUS Chromebook ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB boardview and ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional...09-07-2024, 02:50 AM
This specification for the ASUS ASUS E510MA-EJ015TS 15.6" FHD Intel Celeron N4020 Processor 4GB 64G with M365 1 year Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS E510MA-EJ015TS 15.6" FHD Intel Celeron N4020 Processor 4GB 64G with M365 1 year boardview and ASUS E510MA-EJ015TS 15.6" FHD Intel Celeron N4020 Processor 4GB 64G with M365 1 year schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated...09-07-2024, 01:30 AM
- Loading...
