HP 2309m won't turn on - damage lightning
  • caseyjay
    • Aug 2013
    • France
    Hi, a recent lightning storm has left me with 2 LCDs and 2 Satellite boxes malfunctioning so rather than see them go to landfill I'm starting out on repairs and need some newbie guidance, thanks:
    My HP monitor (2309m, LG23" screen) won't turn on at all - it usually has a blue LED when on/nothing when off. If I plug in, LED is white all the time. I stripped the unit down, no obvious damage to either board or caps.
    I checked the power from the power supply pinouts to the controller board but have no guide to know which ones are which, I have ten in total:
    2 red are giving 5v,
    1 blue = 2.65v
    1 green = 0.45v
    The rest have no voltage. This is in standby mode.
    I have checked resistance on (what I think is) the primary fuse - shows 0.3ohm - see pic attached for what I am testing.
    Any guidance from the experts here? thanks in advance
  • wraster
    MB no turn on, apparent damage but voltage, but none from voltage reg IC - ThinkPad P17 MB NM-C651 - what next?
    by wraster
    Hi, I have a ThinkPad P17 motherboard with intel chipset, NM-C651 that appears to not power on.
    - No light with DC plugged in, no signal to external monitor connected directly to HDMI on motherboard (no GPU module attached).
    - There appears to be damage on a ferrite bead chip (pic here) on the main power rail (20 V), but there is a 20V reading to the in-side, and 15V reading on the out-side. After this chip, the power goes to an IC that I think regulates voltage (NCP81210MNTXG_QFN40, PU1301 in the boardview screenshot here), but I read no voltage on pin 7, nor 11-13.
    02-10-2025, 02:00 AM
  • pajdek
    Lenovo Y700-17ISK turn on and off
    by pajdek
    Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
    09-20-2023, 02:49 AM
  • bajdik
    Asus X555LD after watter damage - won't turn OFF
    by bajdik
    I have a problem with Asus X555LD after watter damage.
    The KBC chip with some traces was damaged.
    I changed KBC chip, repair trace. Laptop works great, but if I turn it off,
    it turn on again. If I put adapter in it, it power on.
    Any idea? Schematic is not available..
    01-11-2023, 02:40 AM
  • SluggerB
    Panasonic TH-50PX80 killed by lightning strike, help me save her!
    by SluggerB
    Yes it's a 17 year old Panasonic plasma!
    I was watching TV when there was a huge lighting strike nearby my house that shook the house. When that happened, the picture on the TV froze and the TV wouldn't turn off except by pulling the power cable. Now if you plug in the TV, it seems to turn on (it makes the turn on "clikcs" it always does, the red power light comes on but there is no picture, although I can see the back light around the edges. And the TV doesn't respond to the power button on the remote to turn off, and doesn't respond to the manual power button on the front...
    06-04-2025, 07:02 PM
  • robante15
    Acer Aspire 4520 won't turn on after reboot
    by robante15
    Hello, I have an Acer Aspire 4520 from a couple of decades ago and I want to repair it solely for nostalgia.
    It happens that when I turn it on after having been disconnected for a long time, it turns on without problems, it tells me that the BIOS has been reset and that it will load the factory settings, if I tell it to continue, the computer turns on and everything works fine.
    The moment I turn it off and want to turn it back on a second time, or restart it and try to start it again, it no longer gives an image, and it no longer responds.
    If I remove the...
    04-06-2024, 06:50 PM
