Asus X555LD after watter damage - won't turn OFF
  • bajdik
    • Aug 2015
    • 68
    • Czech Republic
    I have a problem with Asus X555LD after watter damage.
    The KBC chip with some traces was damaged.
    I changed KBC chip, repair trace. Laptop works great, but if I turn it off,
    it turn on again. If I put adapter in it, it power on.
    Any idea? Schematic is not available..
  • mon2
    • 14850
    Re: Asus X555LD after watter damage - won't turn OFF
    Which version of X555LD is your board ?
    Need to check your DCin mosfets to see if they are leaking.
    • bajdik
      • Aug 2015
      • 68
      • Czech Republic
      version 3.6
      No problem with MOSFETS.
      • mon2
        • 14850
        Attached is the boardview file for this version of the logic board.
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          You turn it off from windows and it reboots instead of shutting down?? Is this what you mean??
          Or whenever adapter is connected it auto turns on-which one do you mean??
          • bajdik
            • Aug 2015
            • 68
            • Czech Republic
            Both. it looks like a workoholic :-) There is no way how to power off this laptop if battery is charged or adapter is inserted.
            If I push power button for 6 seconds to power off, after 0,5 seconds it power on again.
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              Its usually related to PCI_Wake signal. In absence of schematics for asus, thats difficult to trace. I'll suggest the following:
              01.Clean install windows with no drivers installed
              02.Remove Wifi card
              03.Remove power button and try to turn off with tweezers.
              04.Remove Lan chip
              If still problem persists, probe dc-dc conversion circuit and/or remove audio/card reader chip also.
              PS: I assume you have already tried bios flash.
              • bajdik
                • Aug 2015
                • 68
                • Czech Republic
                There is a no HDD, WiFi modul and still do it the same.
                Power button is on the board directly, but I checked it - button is OK.
                On the KBC should not be any signal for that?
                • mon2
                  • 14850
                  Search for the keyword 'wake' to see if any such signals are present on the logic board.
