HP 2159m - No signal issue
  • Lledargo
    • May 2013
    • 7
    I recently aquired a HP 2159m monitor. The monitor will turn on for a short period of time after having a video source (Can be HDMI, VGA, or DVI) and AC power plugged in, it will display a menu that claims it cannot detect a signal from any of the video sources, then the display goes into stand-by.
    So far, after reading a few threads about this monitor and general trouble shooting:
    - I tested the fuse on the power supply to have no resistance.
    - The large cap on the powersupply has ~160V across it.
    - The +5V leads from the powersupply to the mainboard measured 5.28V.
    - The voltage regulators I could find tested as follows:
    U202
    ⊃||8J4
    17-18L
    Pin 1 - 0.000V
    Pin 2 - 1.781V
    Pin 3 - 3.500V
    U201
    ⊃||8BU
    17-33L
    Pin 1 - 0.000V
    Pin 2 - 3.28V
    Pin 3 - 5.006V
    I could not find datasheets for the VRs, as they seem to have unusual model numbers, I can take pictures of each regulator though my magnifying glass if anyone would like to see. I am of the impression that because a nice constant 5.3V is coming off the powersupply, that the issue must be with the mainboard.
    Other than that the only information I can think to give is the monitors product number:
    FV585A
    and regulatory model number:
    HSTND-2571-T
    All help is greatly appreicated. If I forgot anything please let me know, I will try my best to get you any desired information.
  • Lledargo
    • May 2013
    • 7
    Re: HP 2159m - No signal issue
    A little thing I over looked, for some reason there is a missing capacitor (C854) on the top right of the power supply board in my top veiw, bottom right in the bottom view attached. Looking at the traces, it went between the Gnd and VADJ (voltage adjust?) pins on the connector. Any ideas what it is for?
    Also, I am about 99% sure I am the only person to have opened this display before, I did not notice a cap floating around in the case, and I did not notice any caps break off while I've been working.
    Also, as the bottom veiw shows, there is solder on the holes where a the cap should be.
    • Lledargo
      • May 2013
      • 7
      Decided I might as well attach an up-close picture of the traces near the conncector and missing capacitor.
        There was nothing installed at that location from the factory, you can tell from the look of the pad, the holes are cover by solder from wave soldering.
        The regulator voltage readings are correct.
        • AstutePauciloquent
          Requesting Help For GA-970A-DS3 rev. 1.0, No Post code, no RSMRST# signal
          by AstutePauciloquent
          Hi everyone, over the past few months i have taken a deep dive into motherboard diagnostics and I love the challenge. Currently im trying to learn all about the signals that travel around the motherboard, such as frequencies, enable signals High and Low logic states etc. And i have been learning to read and using the Schematics for this board that i requested here on Badcaps forum, from a few months ago, this is such a great place for these.
          I’ve been working on a GA-970A-DS3 (rev. 1.0) that does not post. This motherboard has been my main learning board. I would like share...
          11-23-2023, 11:02 PM
        • howardc64
          Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
          by howardc64
          Failure Symptom
          No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
          Where is the short?
          Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
          Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
          05-27-2025, 02:56 PM
        • ugamazing
          by ugamazing
          12-17-2024, 07:05 PM
        • JayPoorJay
          Converting +/- 5v to a Usable Hz Signal
          by JayPoorJay
          Good morning.
          I have posted here before and have gotten AMAZING advise (thank you!). I'm back for more. This BCaps Sub Forum is so well attended I thought I would post here.
          This question is for an automotive application but has to do with what are essentially electrical questions and problem solving... If this is inappropriate I get it. Feel free to delete it or move the question.
          The V 12 Jaguar XJS is notorious for overheating in stop and go traffic in hot weather... Y'all will be potentially helpinh a LOT of people. The solutions and directions...
          08-07-2022, 08:35 AM
        • shahnld
          Lenovo legion 5 pro startup issue
          by shahnld
          Good day Experts
          I have a lenovo Legion pro 5 16ACH6H with AMD RYZEN 7 5800H and RTX3070,.
          A weird issue has troubled me. If i power on off the laptop 20 times then only power LED will lit but no fan spin no display. At this stage gpu, vram. DDR voltage. 5v 3.3v 1.8v and the rest are present and cpu core is stuck at 0.84v.
          And sometimes lets say the 21st time it will boot perfectly and there is image and everything is working perfectly and at this stage i see cpu core...
          08-24-2025, 12:31 PM
