Chimei CMV 221D Questions
  • xandora
    • May 2013
    • 4
    • New Zealand
    Just scored myself one of these monitors from work as it 'no longer works' according to the boss. I figured I could take it anyway, and if it really is busted dispose of it later.
    As it turns out, it turns on fine. It is also detected perfectly fine through DVI (not VGA however) on my computer as a secondary monitor (the desktop extends over to it and Windows allows me to alter settings for it), but it won't show anything on the screen.
    The kicker is that when you turn the computer on without an input source connected, then screen will show you a message in the middle of the screen telling you there is no input source.
    After reading through a few threads based around this particular monitor, but not really finding any similar issues I figured I should make a thread about this myself.
  • xandora
    • May 2013
    • 4
    • New Zealand
    Re: Chimei CMV 221D Questions
    Small Update: It seems that you can just make out the On Screen Display while the computer is plugged in and turn on with an input source connected. It's very dark, leading me to believe this is a back light issue?
    EDIT: Opened it up and it looks like there are a couple bulgy caps that I have circled in red. This is my first time getting into component replacement, so I may have missed something. Could this be the issue?
    • newbie1
      • Apr 2010
      • 269
      If I was to repair this, i would replace ALL those caps (except the BIG one) and not only the bloated ones with quality, low ESR caps as a first step. You may want to check F200 (glass fuse beside the bloated caps, in the middle of the board) for open connection using a multimeter. If it is open, replace it as well. Good luck.
      • xandora
        • May 2013
        • 4
        • New Zealand
        I've managed to figure out what all but one of the caps are. The one I'm having trouble figuring out is the small brown one by itself near the bottom of the picture. It looks like it says 22uF 55v, would that be accurate?
        • selldoor
          Slow Learner
          • 7870
          Could be 22uf 35v or 22uf 50v. If you are happy that the 22uf is correct
          I would go for the 50v.
          Replacement caps should be good quality from a known seller we often suggest
          Panasonic FR FM or FC in that order ( Not all values available in all series & make sure they will fit size wise.)
          • xandora
            • May 2013
            • 4
            • New Zealand
            Great, and everyone is often suggesting low ESR caps, but I've got no idea what that means?
            • selldoor
              Slow Learner
              • 7870
              There are many explanations of ESR on this site and elsewhere on the net.
              If you look on a site such as digikey RSonline newark mouser and so on they will have a link to the datasheet for the cap - they sometimes quote the ESR in the specs in one of the columns.
              Really you dont need to know a lot - just buy panasonic FR FM or FC or
              a Nichicon or rubycon equivalent. Care though -many fakes on ebay.
              • Ryan.man
                by Ryan.man
                02-04-2025, 12:23 PM
              • smic717394
                by smic717394
                07-25-2024, 10:16 AM
              • Chrissygizmo
                by Chrissygizmo
                02-10-2025, 12:33 AM
              • spice_disc
                Vizio TV M50-C1 reboot cycle and static on screen
                by spice_disc
                I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
                The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
                09-08-2024, 02:37 PM
              • ipatch
                ipad pro 9.7" blew a SMD component while replacing the screen 🤦‍♂️
                by ipatch
                i have an ipad pro 9.7" (1st gen) A1674 where i replaced the screen, but never attached the screen to the frame/chassis (glued down) due to the ipad being previously dropped so the new screen would never fit in the frame properly. so i need flex/bend the chassis to eventually fix the new screen in properly. so i temporarily just applied blue tape around the edges of the screen to keep it in place. when watching videos with the ipad the screen started flicker, so i though maybe the new quasi cheap amz screen i purchased was going out. so i disconnected then reconnected with power still on,...
                08-24-2024, 02:36 PM
