Samsung syncmaster 216BW
  • henrysin44
    • Apr 2013
    • 109
    My syncmaster will turn on for a little bit then flicker then the screen will turn black but the power button will continue to be illuminated. I replaced 1 cap that was blown but it didn't help. Any suggestions?
    I have salvaged and fixed 18 TVs (1 DLP), 22 LCD monitors, 8 stereos, network stuff, and more laptops and computers than i can count.
    Service Menu/Factory Reset Codes for TVs
  • redwire
    • 3906
    Re: Samsung syncmaster 216BW
    When my syncmaster did that, I just replaced them all. It's a few dollars to do. You save nothing given the time to take it all apart and put it back together.
    Search the site, there are several threads on re-capping the 216BW and 226BW's.
    • henrysin44
      • Apr 2013
      • 109
      Thanks! So basically I have to replace all to resolve the problem
      • henrysin44
        • Apr 2013
        • 109
        do i need to replace all caps on power board and video board or just powerboard
        • Rtech
          • Jul 2010
          • 1095
          Powerboard
          • henrysin44
            • Apr 2013
            • 109
            Thanks, i was pretty sure about that.
            • selldoor
              Slow Learner
              • 7870
              Can you define " a little bit" 5 seconds 5 minutes 15 minutes
              • henrysin44
                • Apr 2013
                • 109
                Sometimes it will stay on for a couple hours but mostly like 15 seconds to 10 minutes.
                • henrysin44
                  • Apr 2013
                  • 109
                  I have replaced all of the caps. It will not shut off anymore but every once and a while it will flicker for about 10-30 minutes.
                  • Rtech
                    • Jul 2010
                    • 1095
                    First thing is to check your soldering,making sure the joints are good,and you have not made 'bridges' etc to adjoining components.
                    • ben7
                      Capaholic
                      • Jan 2011
                      • 4059
                      Could be a bad solder joint, bad inverter transformer, or bad lamp/wiring.
                      Muh-soggy-knee
                      • henrysin44
                        • Apr 2013
                        • 109
                        how would i know if a inverter transformer is bad
                        also the flickering will get much worse if the brightness is increased
                        • selldoor
                          Slow Learner
                          • 7870
                          Fault on a inverter transformer doesnt come and go. What you can do is
                          resolder it - remove all the old solder and replace with leaded.
                          What make /series caps did you use to recap the board?
                          Sounds to me like it could be the lamps/wiring - when it is flashing can you hear anything
                          like arcing, Have you nay bulbs in anything you could substitute or another monitor you could try these bulbs with.
                          If neither how about making up some test lamps
                          https://www.badcaps.net/forum/showth...ght=test+lamps
                          • henrysin44
                            • Apr 2013
                            • 109
                            nichicon, i ordered the wrong ones, i dont know how but i had to replace the 830UF with 1000UF ones.
                            • henrysin44
                              • Apr 2013
                              • 109
                              the rest were exact UF and all copasitors are the same voltage or higher.
                              • Lumberjack777
                                • 464
                                Sounds to me like you have a bad ccfl (lamp), bad wiring, or a faulty inverter transformer. Check out retiredcaps guide on 2 seconds to black. Especially the section that deals with ccfls and inverter transformers and how to test them.
                                https://www.badcaps.net/forum/showthread.php?t=10419
                                Start at post #19
                                  09-07-2024, 05:50 AM
                                • fixit007
                                  Samsung flicker - BN44-00932T board or else?
                                  by fixit007
                                  I picked up this TV that the prior owner said - just died.
                                  Tested the fuse - burnt. A dead capacitor is visible too on the hot side (CP801). Got the replacement power board (cheaply - used). Replaced the board - the TV turned ON!
                                  Now, about a month later (yesterday) I noticed the left side of the screen was flickering from time to time. That was already happening with the antenna input, not through HDMI.
                                  Also, some glitchiness with a Fire stick on HDMI3 - I hit an app with quick dark screen in stick, the TV goes - no input. Then I had to choose the stick...
                                  05-04-2024, 06:14 PM
                                • soopacrucial
                                  by soopacrucial
                                  Hi folks,
                                  10-29-2024, 02:40 PM
                                  09-06-2024, 11:40 PM
