Re: LG Flatron
OK - Pics have too much flash - need good light but not flash.
I have not seen this board before either .
You cannot test the capacitors properly with a multimeter.
Basic tests - with it all connected up and power to the set but switched off
Meter on 600 vDC CAREFULLY measure across the Legs on the BIG CAP.
Switch the power on then do the test again.
Next meter on VDC 200 list the voltages you get on the connector that goes from the power supply to the main board along with what it says they should be.
Example
PIN 1 12v 11.25v
PIN2 gnd 0.00
PIN3 pson 3.37v
LG Flatron
Re: LG Flatron
i could only post the photos today, hope there will be of any use, if you need anything more just ask.
the photos are very low quality but is the best i can manage, only have camera on phone. so sry.
Think if i replace all capacitors i will solve the problem? what about those ceramic caps i cant get them where i live. do i need to replace them too?
best regards
Andre MacedoLeave a comment:
Re: LG Flatron
To be honest, I don't think you can do much if any useful testing of the caps with the equipment you have, as you'd need to be able to measure the capacitance, and the ESR.
We'll know a bit more when you get the photos, then we can get you to measure a few voltages etc.Leave a comment:
Re: LG Flatron
Thks for the response, i will run this tests when i get home, aswell take care of the pictures to send you guys.
just one quick question, what values do i set to measure the caps on the multimeter, and what do i expect? can i test them "in circuit" or i need to desesemble them?
as for the cold joints, i resoldered what it seem to me a potential cold joint, altough the solder i used was of bad quality and things got bit dirty, youl see what i mean when i send you the photos.
thank you for all the help
regardsLeave a comment:
Re: LG Flatron
I just looked at my repair log. I have repaired 10 LG monitors, haven't seen that particular model. The buzzing may not necessarily be caused the component that is buzzing, it may be caused by something else.
I would definitely check/replace the capacitors, especially if they're known problem ones like Samxon GF. And definitely check the solder joints, particularly around the transformers.Leave a comment:
Re: LG Flatron
ty for the quick response and the welcome greetings, i am at work rigth now and therefore can only send pictures of the board later, i used to have a good multimeter but my tool case was stolen and know what i have is those very basic multimeters, it cant measure caps doesnt have the Faraday option, can olny test them using the ohmimeter, but it isnt working why i dunno, maybe im doing something wrong.
As for the Display model it is the LG Flatron w2246s - BFW.AEUODPN
the component where i think the buzzing is comming is:
IT-007
EBJ55945505
DD 1023
Thank you mate for the time reading my post, it is most apreciated
RegardsLeave a comment:
Re: LG Flatron
Welcome to the forum-
We can help a lot more if you please post good clear pictures of the whole chassis, and then pictures of each board, front and back (in the same orientation) and close up of connectors, (max resolution 2000x2000 and 2MB) using the manage attachments button, which is found by clicking "go advanced" under quick reply.
Examples of what is needed
https://www.badcaps.net/forum/attach...7&d=1280167246
https://www.badcaps.net/forum/attach...6&d=1280167246
https://www.badcaps.net/forum/attach...4&d=1280167246
It will be useful if you can say what the supposed fault was and a bit about yourself - skills tools etc.Leave a comment:
Re: LG Flatron
First. welcome to Badcaps!
Second, your English is fine.
Third, we'll need a model number, and some pictures of the insides of the monitor will help
Do you have a multimeter?Leave a comment:
LG Flatron
Hi badcaps community
Hope im not breaking any rules here, the thing is i got an LG Flatron 22" and it has the "2 sec to black" dissease, differing only that image doesnt appear even with flashlight or sun light.
I have tested the fuse, diodes, still havnt tested the caps and other components but i detected something strange and tought of asking you guys for a little help, the thing is that when i turn on the Display, i hear a buzzing in what i think its the transfomer part of the board, where the ccfl conect, so i ask of you what i should do in a situation like this, i mean i dont know how to test that component and i surely dont know what its name, its a square like thing.
Could some caps be the source of the buzzing?
I dont have any spare ccfl how can i test if it isnt the ccfl?
thank you in advance,
And sorry for my bad englishTags: None
by Ancient1I forgot to take a photo and now I am not sure how to reconnect
As you can see , I have 2 pairs , each pair has 2 colored wires : the black_ish connector and blue_ish connector
There must be a convention to help decide , I assume
How do I reassemble ?
Thanks1 Photo-
by ttmi100xGreetings everyone,
I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
Upon closer inspection...6 Photos-
by mikey5791Hi,
This monitor previously is my main working monitor which i have been using for 8~9 years. Yesterday, when i switched on my pc from fresh to power on, the monitor is just black no display. I started dismantle to look inside the monitor power board but nothing looks suspicious or burnt. So i took my external ccfl inverter to try to power the monitor ccfl lamps which consisted of 2 lamps on upper part and 2 lamps on the lower part.
Found out the upper ccfl lamp which is supposed to connect to cn304 on the power board did not light up. Then i installed a used working...-
by dcbwThe PSU works, but shortly after powering on (either in the G5, or by shorting the power-on pin to ground) it begins buzzing loudly. It also makes the LED lights connected to the same circuit flicker. It's definitely a buzzing, not a high pitched whine.
The buzzing seems to come from the high voltage side of the board, perhaps from the white relay. Could the relay be bad, or could the 5V supply be bad enough that it's unable to keep the relay on? Any pointers to help isolate the issue? Thanks!
Other info: API2FS34, ID 291, Date B040405-31-2024, 07:13 AM -
by reessiThe pics are off the other really long thread as they are much clearer than my phone will do.
The fault:
In standby there is no buzzing.
After signal input and turn on, a loud buzzing is emitted from the main transformer, no backlight.
It is because the 24v line is at 21v irrespective of whether the inverter is plugged in. There is a picture on the screen.
If you wait long enough the buzzing stops and the 24v line changes to 24v and the inverter comes on.
I have checked every single cap on the psu and logic board by un-soldering...-
- Loading...
