Recap Surface mount capacitor
  • supersabre
    • Feb 2006
    • 45
    I don't have experience in recapping surface mount capacitor.
    Is it possible to remove the caps with a radio shack 25w iron without damaging the pad?
    Any suggestion for removing the surface mount cap?
  • -cp-
    • Oct 2006
    Re: Recap Surface mount capacitor
    1. add some more solder to both pads (yes, more!)
    2. use tweezers to gently (!) lift the capacitor on one side while heating the pad
    3. same procedure on the other pad
    4. voila..there it is
    you can also use the tweezers holding the capacitor while heating one pad and then quickly start heating the other pad. this way the capacitor will come off (nearly) without any force. use some solder sucking wick to clean the pads before recapping.
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      i use 2 isotip irons with fine tips.heat both pads till solder melts and lift the cap with the irons.
      • eclypse
        • Nov 2007
        • 19
        How about putting it back on? Iron fine or just buy a heatgun?
        • starfury1
          • May 2006
          • 1256
          two irons as KC8 said is what I use when I have too.
          There are tools for this if you got deep to very deep pockets
          cheapest (and not that cheap) are the tong type tool which is more or less 2 irons like tweezers.
          cheers
          You step into the Road, and if you don't keep your feet, there is no knowing where you may be swept off to." Bilbo Baggins ...
          • Per Hansson
            • Jul 2005
            • 5895
            • Sweden
            I quite like SMT caps, i you can get something to practice on first
            I find it much easier to repair a board with only SMT caps vs through hole; no holes to clean at all
            • CudaDave70
              • Jun 2008
              • 72
              Hello you mother (board) cappers, Just want to ask this simple question, then I will go away . Are the surface mounted caps suspected to be as much "no good" as the through hole radial electrolylic caps? I replaced a cracked LCD panel on a Dell E176FPf and it has this shakey-snowy look to it like it has some EMI problem .
              I replaced all the through hole caps except for these 3 aluminum surface mounted ones that are right near the video output ribbon cable. The interference is not as bad as before I changed all the other caps. I even switched the lcd screen to another one, thinking it may have been defective one, NOPE ,I changed the ribbon cable too,NAADA. It is absolutely awful this way so,makes you sick just looking at it, I gotta try it before I toss it against the wall .
              I am pretty good at keeping a secret,it's the people I tell that can't keep their mouth shut!
              • PCBONEZ
                Grumpy Old Fart
                • Aug 2005
                • 10661
                Surface mount or radial is only the mounting method.
                Both can be electrolytic caps.
                Both can be poly caps.
                Mann-Made Global Warming.
                - Dr Seuss
                • arneson
                  • Sep 2005
                  • 1267
                  Yes surface mount electrolytics are failing.
                  I see them going out in eight year old radar scanner domes and massive failures in camcorders.
                  Both hard to repair.
                  Jim
                  • CudaDave70
                    • Jun 2008
                    • 72
                    I changed them out and it didn't help any ,my guess this LCD screen or screens I tried are not compatible with this Dell .I don't know what else can cause this strange look to the display ,it's now a in the box with the others that don't want revived at least till I can get a LCD panel that is compatible with this E176 FPf. I guess just because the connectors fit together ,don't mean they are compatible with each other.
                    • kc8adu
                      • Nov 2003
                      • 8832
                      • U.S.A!
                      is the busted lcd too bad to see if the same interference is present?
                      and pull the ccfl tubes before tossing it.
                      • CudaDave70
                        • Jun 2008
                        • 72
                        Yes it was busted up pretty bad ,It also had a problem with some bad caps and no video when I tried it , that is possibly why it had a big ole fist print in it in the first place . I tried two different screens and it is the same problem on both .
                        Would a failing transistor produce this kind of interference on the screen? I had one similar to this one ,doing almost exactly the same thing ,I replaced all the capacitors and it was almost gooder than new after that.
                        The box of junk just keeps growing. I removed the lcd panel from the LCD assembly and kept the lamps the frame -housing ect and tossed the panel after I removed the circuit board to use for spare parts in desperate times.
                        • CudaDave70
                          • Jun 2008
                          • 72
                          Does anybody know what the 4s. marking is on these capacitors ? Does it indicate 6volts (I would assume). This is an LCD Control board out of a 22 inch Sharp TV . It turns on, has sound ,the backlignts are working ,but the screen is all segmented with all kind of weird designs and colors (mostly grey) .The longer it is on ,the brighter it gets. I am thinking of recapping this before I replace the whole board,but I don't know for sure what this 4s. indicates on the top of some of the smd caps.
                          • kc8adu
                            • Nov 2003
                            • 8832
                            • U.S.A!
                            likely 4 volt
                            • PCBONEZ
                              Grumpy Old Fart
                              • Aug 2005
                              • 10661
                              I agree.
                              The "S" looks like a logo.
                              - Dr Seuss
                              • CudaDave70
                                • Jun 2008
                                • 72
                                Thanks for that,I am going to go with it ,There were also somemore on this board that said 6 s that is why I said 6volts I just took picture of the 4 s ones.There are about 50 caps on this LCD Control board. Would it be better(SMARTER) to replace all the caps or buy a used and working board for around 60.00 dollars?
                                Dave
                                • PCBONEZ
                                  Grumpy Old Fart
                                  • Aug 2005
                                  • 10661
                                  It depends on what you have more of.
                                  Time or money.
                                  - Dr Seuss
                                  • PCBONEZ
                                    Grumpy Old Fart
                                    • Aug 2005
                                    • 10661
                                    This depends on if the card fires up (works) at all.
                                    When in doubt and if possible just check volts on cap with a multi-meter by connecting the probes to solder points on the other side of the PCB.
                                    Remember, depending on what the cap does there might be times when volts changes because of what circuit is doing (device mode/condition.) so if you aren't sure of the caps purpose check the volts in all known operating modes to be sure.
                                    - Dr Seuss
                                    • PCBONEZ
                                      Grumpy Old Fart
                                      • Aug 2005
                                      • 10661
                                      If you know the purpose of ANY of the caps 'with the same marking' (and so know if the voltage should be changing with mode changes) then check the volts on that one.
                                      - If it's over 4 you know 4v isn't the voltage.
                                      - If it's under 4 the you still only know it might be 4v,, because other caps might be on higher volts.
                                      I'm pretty confident the mark is for 4v though.
                                      Just rambling on about methodology~~~~~~~
                                      - Dr Seuss
                                      • CudaDave70
                                        • Jun 2008
                                        • 72
                                        I also tend to ramble,but it is almost always because I don't know about something ,your ramblings are valuable information and greatly appreciated by me and I'm sure many others that are reading it. I absolutely have more time than money
                                        plus it isn't much satisfaction just replacing boards,Where's the challange ? I never got burnt doing that.
                                        Thanks man
                                          Surface Mount Fuses Fundamentals Datasheet
                                          TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
                                          TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
                                          10-07-2024, 06:07 AM
                                          Microsoft Surface Book Surface Book 3 + Surface Dock 2 Hybrid (2-in-1) 3 Specification for Upgrade or Repair
                                          This specification for the Microsoft Surface Book Surface Book 3 + Surface Dock 2 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Book 3 + Surface Dock 2 boardview and Surface Book 3 + Surface Dock 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
                                          09-06-2024, 08:10 PM
                                          Microsoft Surface Book Surface Book 3 + Surface Dock Hybrid (2-in-1) 3 Specification for Upgrade or Repair
                                          This specification for the Microsoft Surface Book Surface Book 3 + Surface Dock Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Book 3 + Surface Dock boardview and Surface Book 3 + Surface Dock schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
