15.1" backlight fault
  • riget
    • Sep 2011
    • 66
    Hi, got a 15.1" touchscreen monitor that the backlight only stays on for a few seconds, I've opened it and found it's a 2 ccfl, the inverter is small like a laptops, I decided to connect my meter set on 750v and found that the backlights stayed on, even with the meter turned off the backlights still worked, connecting to the other ccfl the backlights didn't stay on.
    From this I'm thinking one ccfl is weak and the meter is drawing current to make it work, is this possible? If so could I connect a capacitor between the ccfl connections and it would work?
    Thanks.
  • selldoor
    Slow Learner
    • 7870
    Re: 15.1" backlight fault
    Have you tried swapping the two lamp connectors over.
    • riget
      • Sep 2011
      • 66
      I decided to just put another tube in it and it's working fine now.
      Strange how connecting my multimeter made it work though, and I tested it many times.
        Your meter is not rated for the high voltage pulse and will have likely have broken down (arced over) internally, giving the inverter the load it wants. I would not trust it further, especially on AC volts setting.
        • riget
          • Sep 2011
          • 66
          The meter is rated to 750v, it went past this and displayed 1, so yes it wasn't rated high enough, and gave the inverter the load it needed, it also did this with the meter turned off,
          what I wanted to know was could I introduce what the meter was doing, like adding a capacitor.
          The meter still works fine, it must have an overload that coped with the extra volts.
          • DanPoka
            Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
            by DanPoka
            I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
            Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
            This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
            02-15-2025, 05:05 AM
            ESR meter came to the rescue again today with a PLC I/O card fault
            by sam_sam_sam
            I have been having a fun time at work with two pieces of equipment that had shorted components or shorted component cables to machine frame
            I would check what my multi meter was telling me about how many ohms I getting with the multi meter was telling versus the ESR was telling me about weather or not it really was a short to machine ground or not
            One note at first we thought that it might be a bad I/O card or a malfunction PLC including me as well but I thought I would try and see if removing the I/O cables would make a difference or not and this time it did make a difference...
            12-18-2023, 08:17 PM
          • howardc64
            Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
            by howardc64
            • Prior owner tried a replacement main board. No difference.
            • Samsung 2x red blinking standby LED = panel fault
            • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
            • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
            • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
            07-19-2025, 10:54 PM
            Design of CCFL Backlight Inverters with Frame & Bar Cores
            Summary
            Portable devices, such as notebook computers and personal digital assistants are developed rapidly nowadays, which places an increasing demand on display technology. The LCD with cold cathode fluorescent back lighting satisfies the requirements on display performance, size and efficiency.
            The backlight inverter plays a crucial role in supplying the power to the lamps of these flat-panel displays.
            The frame and bar ferrite cores, described in this brochure, are especially designed...
            10-07-2024, 04:26 AM
          • TrisHCl
            LED TV Boot loop - UE40F6500SB
            by TrisHCl
            First post...
            I have this TV, which was working, then suddenly would not turn on. It would get the clicking relay then flash up the screen for less than a second, off for a second then on again. Removing the plug the relay continues to click on and off for a few cycles, which I don't think it did before.
            Left it a few months, then finally got round to taking the back off, and it worked as it should. So I tested various bits and all was well. Then turned it on again, and back to the clicking relay.
            I disconnected the main board from the power...
            02-06-2025, 08:42 AM
