Usage of ultra low esr capacitors on lcd power boards
  • jpyerry
    • 94
    I recently repaired a Samsung 930B monitor power supply board by replacing the capacitors.
    For a couple of the capacitors I used Panasonic FR series capacitors which I understand fall in the category of being ultra low ESR.
    The monitor turns on and functions, but I've gotten worried because after doing some reading on the forum, it is not a good idea to use ultra low ESR capacitors on power supplies.
    So, for long term stability (I really like this monitor), would it be advantageous to pull the FR capacitors out and put in some capacitors like from the Panasonic FC series? Or should I just leave it alone?
    Thanks,
    Justin
    Re: Usage of ultra low esr capacitors on lcd power boards
    The thing you have to worry about using too low ESR is the stability of the power supply and how was it is designed to tolerate wide ESR range, some may become unstable and oscillate. To find that out you will need the scope to look at out put and see waht kind of high frequency signals you are seeing at the outputs. I would not worry about it. The power supply designed for the monitor are very basic not like for precision voltages needs in mother board.
    http://www.ttieurope.com/object/io_1274447859676.html
    "Application examples
    Switching mode Power Supply:
    Switching mode Adapter
    line noise removal
    LCD backlight
    LED applications
    Applications with long lifetime requirements"
    • jetadm123
      • 2169
      I would not worry about using the FR series as they are being advertised as having a much longer life span than the Panasonic FM/FC series. If you look at the spec sheets for the FR/FM series, you'll see the specs for ripple current and impedance very similar. In some cases the ESR for the FR series is actually higher than the FM series. The FR/FM/FC series are recommended by a lot of members (myself included) for monitor/TV repair. You're fine leaving the FR's on the board.
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • PantherDave
        by PantherDave
        Hi all!
        05-29-2024, 02:01 PM
      • GLISIT
        by GLISIT
        01-16-2025, 02:29 PM
        After all of...
        07-13-2024, 08:14 PM
      • mikey5791
        Philips 196V3L monitor power led off
        by mikey5791
        Hi, i was given this lcd monitor last week with the issue of power led blinking. Upon checking the power board, i found 2 pieces electrolytic caps bulged and replaced them.
        Later, when i switched on ac power and detected 5v and 15v dc at output pins. But as soon as i pressed on the front power button, the led on power button lights for 1 second and it turns off.
        So, i tried disconnect the flex ribbon cable from t con board. But all i got is a white screen with nothing on. I suspect there is something short somewhere that prevent the display being turned on. Can someone with...
        01-25-2024, 07:52 PM
