Horizon 2206SW repair
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    • Romania
    Had this one brought in today by someone who saw my ad on a local computer forum. He said he hasn't used it for about an year, because it took 20-30 minutes to turn on. I instantly knew what that meant... yup, bad caps.
    Sharp eyes will also notice something funky about the power supply connector where the inverter plugs in, but i'll let you spot it.
    A working TV? How boring!
  • Lumberjack777
    • 464
    Re: Horizon 2206SW repair
    It appears to be 1 pin short of a full load
    By the way your suggestion about using a higher rated reverse voltage on the Schottky diode for the Dell 3008WFP has really paid off for a lot of people
    • Th3_uN1Qu3
      Believe in
      • Jul 2010
      • 6031
      • Romania
      Mmmmyup. And as you probably guessed, i got it wrong first time round.
      I got lucky tho - the configuration of the connector is so that the BL_ON got wired to one of the power supply rails but that was all. The inverter wouldn't turn off (full white screen when the panel was supposed to be "off"), but fortunately there was no smoke. Moving the connector to the other position restored 100% normal operation. Phew. Customer picked it up today.
      Thanks. I've been keeping an eye on that thread myself - it would be interesting to find the root cause of this, as i suspect it's something on the primary which causes the PSU to require a higher voltage replacement diode after the original blows, but as long as it works... who cares why.
      • jvc9000
        • Nov 2013
        • Romania
        To the OP. I have the same monitor with the same problem. What exactly do I have to replace? (it takes ab 1-2 min to turn on and it's getting worse)
        • Th3_uN1Qu3
          Believe in
          • Jul 2010
          • 6031
          • Romania
          You have to replace the capacitors on the secondary of the power supply. The side where the 3 ribbon cables plug in. The 16v and 25v ones.
          • jvc9000
            • Nov 2013
            • Romania
            Done. Thanks! All I had to do was to take it apart. Man, what was there, it was a massacre!
            • Thundermaster
              • Sep 2015
              • 3
              • Romania
              I just replace the inverter but something goes wrong because i have on/off command only on VGA without ajdustments , DVI doesn`t receive the command to turn on CCFLs . The picture shows the connections .
              • Thundermaster
                • Sep 2015
                • 3
                • Romania
                The inverter doesnt receive the on command from DVI , only from VGA with no posibility to adjust luminosity - it goes in off protection after 60% .
                • Thundermaster
                  • Sep 2015
                  • 3
                  • Romania
                  On the new inverveter are marked the connections : 1,2 +Vcc , 3 on/off , 4 adjust , 5,6 GND .
                  • nebundemult
                    • Jun 2010
                    Where i can find power supply schematic diagram for this monitor?
                    • warsztat
                      Trademi Horizon, freeze after start.
                      by warsztat
                      Hi, trademil Horizon freeze after start like video, i try reset (3sek push stop), remove and I put new ones capaticors 3,3V line digital and analog line.
                      The device in service mode passes all tests, except for the display test, where it hangs. The display in service mode during engine testing, etc. seems to behave correctly, it shows values, the engine is working, I can adjust its speed but only in service mode, in normal operation after pressing start the machine freezes
                      All the multiplexers that support the display seem to be working. It's like the processor...
                      03-06-2025, 07:33 AM
                    • ZOrd_Z
                      Bang & Olufsen Beovision Horizon always in standby.
                      by ZOrd_Z
                      I every one!!
                      I have a Bang & Olufsen Beovision Horizon that is always in standby mode ( green light on ).
                      Main board is 715g7132-m0h-000-005k. Corrupted firmware? I have all the ok voltages in psu.
                      Any idea?
                      Thank's...
                      12-12-2024, 11:44 AM
                      Mean Well Dimmable HLG-320H-15B 285Watt 19,000mA LED Driver Power Supply On sale ends today
                      by sam_sam_sam
                      This is something that I recently just bought the other day when the sale started for a LED lighting project that I plan on doing
                      I just bought another one today to make make two lighting panel fixtures
                      I thought I would share it just in case someone else happened to be interested in buying one and you are limited only one per order
                      https://theelectronicgoldmine.com/products/g27501
                      05-27-2024, 06:59 AM
                    • bryanX
                      Control board for treadmill Horizon Omega II
                      by bryanX
                      Hi guys!
                      Firstly, I will apologize if my topic is in the wrong section, please move it if necessary.
                      I want to repair one treadmill from the brand Horizon the model is Omega II. Practically, the motor power control board has suffered one damage.One mosfet has blown and I suppose by doing that, the short circuit has damaged a couple of diodes, one zener diode and two transistors. I hope that is all. I will find out when I will put them all back on board. I have dismantled and cleaned the rotor of the DC motor, tested it, and it seems to be working properly. I suppose it was water...
                      03-05-2024, 01:11 PM
                      ESR meter came to the rescue again today with a PLC I/O card fault
                      by sam_sam_sam
                      I have been having a fun time at work with two pieces of equipment that had shorted components or shorted component cables to machine frame
                      I would check what my multi meter was telling me about how many ohms I getting with the multi meter was telling versus the ESR was telling me about weather or not it really was a short to machine ground or not
                      One note at first we thought that it might be a bad I/O card or a malfunction PLC including me as well but I thought I would try and see if removing the I/O cables would make a difference or not and this time it did make a difference...
                      12-18-2023, 08:17 PM
