19" Hanspree New York XM-S
  • marts_8
    • Sep 2012
    • 7
    • Phils
    hi! Im new to this forum but I have been reading this for awhile now. I have a couple of 19" Hanspree New York XM-S that I'am trying to fix.
    The first one, I think, has a problem with the logic board since I swapped the power board in a working unit and it was working. When i turn on the power button, it goes white then slowly goes to backlight (not totally black). I have changed one capacitor (encircled in red) already but same results.
    The other one that needs fixing has a problem with the power board, I think, since I swapped its power board into a working unit and its not working. When I push the power button, it goes green for a few secs then 1 sec orange then no light then green again for a few secs then 1 sec orange. The cycle goes on and on for 20 mins until it says "No Signal Input" that's when I can only power up my computer to use it. there is no physical bloating of any caps and I dont have an ESR meter to test them.
    hope someone can help...
  • opamp
    • Dec 2012
    • 160
    • united states
    Re: 19" Hanspree New York XM-S
    You can make an esr meter if you want. Check the link below, the schematic is pretty simple. I was going to make one myself but I couldn't find the ferrite core for the transformer so I just ended up buying one.
    http://electronics-diy.com/electroni...tic.php?id=947
      Did you check the voltages of the 3-pin Voltage regulators on that logic board? Compare them to the working board?
      Learn more here:
      https://www.badcaps.net/forum/showth...999#post300999
      • selldoor
        Slow Learner
        • 7870
        Re: Hanspree 19 in NY needs warming
        Hmm Sometimes its better to have a thread for each machine - I am sure we are going to get confused unless we fix one quickly.
        On this one can you set it up all connected and with a pc connected and outputting a signal. Then as soon as you switch it on heat sections of the power supply gently with a hairdryer and see if it starts working quicker. Its probably the caps so heat those first - not the big one - the group near the heatsink.
        Daft enough it could also be that the two small caps at the bottom one of
        which may be the startup cap has dried out and will need replacing.
        To be honest they probably all need changing except the BIG cap but try the hairdrier first.
        • marts_8
          • Sep 2012
          • 7
          • Phils
          This is my first time to be repairing stuff and Im learning on using tools like the multimeter. Will get back once I tried some of your suggestions. Thanks much
          • selldoor
            Slow Learner
            • 7870
            Ok youll soon get the hang of it - I sometimes suggest doing a dummy run for some tests (especially high voltage) where you dont have any power on - not even plugged in
            and you do the probing and try and look at the meter at the same time, without the probes slipping. That way even if it does slip you wont do any damage. Whilst it is unplugged you can do various resistance tests to get practice at holding the probes.
            Retired caps 2 second to black guide - has lots of tests that are without the board plugged in and here is a off site tutorial
            A multimeter tutorial.
            http://www.sparkfun.com/tutorials/202
            • m1ch43lzm
              by m1ch43lzm
              05-12-2025, 08:37 PM
            • howardc64
              by howardc64
              07-24-2025, 05:17 PM
            • ttmi100x
              HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
              by ttmi100x
              Greetings everyone,
              I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
              The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
              Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
              Upon closer inspection...
              07-31-2024, 06:36 PM
            • Hakuu
              by Hakuu
              Hi There,
              More Details
              TV Model - LG OLED77G1PUA
              07-12-2023, 02:37 PM
