Monitor 15" GOLD L-151
  • badrianiulian
    • Apr 2012
    • 43
    • Romania
    Re: Monitor 15" GOLD L-151
    Originally posted by selldoor
    Thanks retiredcaps I actually looked at that on the part
    Perhaps I was just hoping too much that it was a 3v running low!
    Badrianiulian ( hope I dont have to type that often)
    I meant for you to check the voltage on them in position unless you have an esr meter taking them off wont show much.
    The measuring part I intent to do is with a capacimeter type CM9601 and measure the capacity...
    On the other hand I could replace all the capacitors (since they're not that expensive) on the main board and U13 (24LC16B) and U10 (24LC02B) since I read once that a bad memory could cause this simptom... any thoughts?
    • selldoor
      Slow Learner
      • 7870
      When you detach the main board from the (Audio) Board is there still 12 volts on the
      inverter?- If the cable is fairly standard perhaps it has 12v gnd x 2 on/off and dim.
      If you have 12 volts and can apply 3 volts using a battery to the on/off perhaps the lights will come on?
      • badrianiulian
        • Apr 2012
        • 43
        • Romania
        Checked with the main board detached and there is 12V on the inverter. However the 0,16V is gone.
        Also checked with 3V to the on/off... still dead
        • badrianiulian
          • Apr 2012
          • 43
          • Romania
          Hello brain786786 .. I do not understand what you mean by your replies...
          • selldoor
            Slow Learner
            • 7870
            He is a spammer - ignore it
            • selldoor
              Slow Learner
              • 7870
              #26
              How did you decide which was the on/off
              • badrianiulian
                • Apr 2012
                • 43
                • Romania
                #27
                Well you got me there... the on/off as I thought and tested was the on/off button... By you asking this question I figure I may have been wrong?
                Tested with minus to the ground, one of the button's contacts, and the positive on the other contact.
                • selldoor
                  Slow Learner
                  • 7870
                  #28
                  Haha communication breakdown I think?
                  The three volts has to be applied with the negative to ground and the 3volts+ to the on/off PIN (perhaps the orange wire pin on the inverter board with 0.16v but its only a guess.
                  • badrianiulian
                    • Apr 2012
                    • 43
                    • Romania
                    #29
                    You asked and I tested (with vga signal 800x600 and 1024x768) :
                    Plugged in 12V and then tested with 3V on the orange wire: the backlights are starting up with a white screen.
                    If I press the Power button in this configuration, I get some lines both horizontal and vertical that flicker.
                    Pressing the Power button again reverts the image to the white screen.
                    • selldoor
                      Slow Learner
                      • 7870
                      #30
                      OK we are getting a bit nearer. - Wasnt expecting any picture as I asked you to detach the main board?
                      So there is 5 volts and 12 volts we know the lights work (I know you tested them already) with this set up so the inverter board is good and the Audio Board is probably good. We need to find out why the Main board is not sending the 3 volts.
                      Can you take it off the frame and post a very clear picture of the back of it.
                      • badrianiulian
                        • Apr 2012
                        • 43
                        • Romania
                        #31
                        Pictures ... front and back of the main board detached
                        • Rtech
                          • Jul 2010
                          • 1095
                          #32
                          Would hope that you have been looking for a replacement board,since Post 14,as it would seem that you have done every test you have been asked to do,and usually, unless the fault on these boards are Caps,Fuses or Voltage Regulators,then the only solution is replacement.
                          • selldoor
                            Slow Learner
                            • 7870
                            #33
                            Can you have a look at U9 which I think is an eeprom. Looking at the picture the
                            contacts at top and bottom line up exactly with the spaces but down the sides they dont. I am wondering if its has been taken out and put back the wrong way round?
                            Is there any sort of marking on it, a dot or an indent or a cut off corner to help?
                            • badrianiulian
                              • Apr 2012
                              • 43
                              • Romania
                              #34
                              Checked the bios type looking eeprom and it is in the right position the dot is in the right corner.. does't fit in the slot if you turn it around
                              • selldoor
                                Slow Learner
                                • 7870
                                #35
                                Thats a pity
                                Running out of ideas!! and I doubt if you will find a replacement board. Are you up for rechecking some components? Just say if you want to give up.
                                In This thread
                                https://www.badcaps.net/forum/showth...t=25282&page=2
                                start at post 20 it is about testing voltage regulators
                                out of circuit and also mentions that although it may test ok it could fault when a load is applied and it suggest using a resistor in the circuit to provide a load.
                                • badrianiulian
                                  • Apr 2012
                                  • 43
                                  • Romania
                                  #36
                                  Thats a pity
                                  In This thread
                                  Read a bit... If i stick in a 100 ohm resistor directly on the main board to test the regulators will it be enough? Or should I take them out one by one and test them with a load of 100 ohm and a 5v/9v supply?
                                  • selldoor
                                    Slow Learner
                                    • 7870
                                    #37
                                    Unfortunately you would need to take them out - which i know is not easy - I was hoping a few others would stick with us on this case - If you like ,wait and see if anyone else chimes in with anything missed or as you suggested change all the caps on the main board. Cant remember did you test any diodes.
                                    • badrianiulian
                                      • Apr 2012
                                      • 43
                                      • Romania
                                      #38
                                      The taking out is not going to be that bad since i got a hot air soldering station available
                                      I did check some diodes... on the main board all 3 diodes test with same values (D4,D5 and D6)
                                      On the "Audio board" I checked one (D008)
                                      Checking with no power with a multimeter the 3,3 regulators on the main board I only get different results with U1 between GND-OUT and OUT-GND; the other values are the same as U5 and U2; U5 and U2 measure the same between OUT-GND, GND-OUT, IN-GND, GND-IN, OUT-IN, IN-OUT.
                                      • m1ch43lzm
                                        by m1ch43lzm
                                        05-12-2025, 08:37 PM
                                        by momaka
                                        03-15-2023, 10:17 PM
                                      • lostone
                                        Looking for help with a Viewsonic VP230mb where the backlight comes on only momentarily
                                        by lostone
                                        Hello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
                                        First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
                                        When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...
                                        05-19-2024, 11:40 AM
                                      • penangit
                                        Hp v193 monitor power supply board
                                        by penangit
                                        Hey everyone,hope everyone is fine, I got an issue hoping you guys can help me,
                                        I got a HP V193 monitor it has a E59670 now i got a few of these, been using them for long time now, however this particular monitor was blacking out for a few times then after unplugging and plugging it back in it gets back to normal until now its dead.
                                        I tried switching the power supply board with another similar monitor and it works,so I'm trying to fix this power supply board I got some basic in electronics as a hobbyist.
                                        Steps taken so far:
                                        Checked all...
                                        02-21-2023, 04:00 AM
