HP W2207H No video.
  • kbradio
    • 3
    HP W2207H No video.
    Have this monitor with bright screen no video present. Any repair history? Thanks for any help with this...
  • LiquidSilver
    • Jan 2014
    • 9
    Re: HP W2207H No video.
    I'm having a similar issue. I purchased a "new" power board (HP ILPI-029 Power Supply Unit Board For W2207H) and a "new" main board (HP Main Board ILIF-031 490891300100R). Now the monitor will not power on at all. The LED power light blinks a bluish color and I hear a slight buzzing/clicking sound on the new power board, sound is not constant and only follows the blinking LED. I also tried the old power board that had a stranger sounding buzz w/click (sound is not constant and only follows the blinking LED). Both buzzing/clicking sounds are coming from the center of the boards closest to the huge heat sinks. I have uploaded pictures of both boards and I'm currently working on finding a place to upload the audio I took of both boards making the weird noise.
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4301
      • Italy - Milan
      "Have this monitor with bright screen" what it means? A white screen? A black scr. with backlight on? The ticking and led blink means probably a short at valley of power poard, can you switch it on with nothing attached to it? Unfortunately i don't know the meaning of sense+/- pins but you can at least test the 5v vcc pins.
      • LiquidSilver
        • Jan 2014
        • 9
        I disconnected everything from the power board and plugged it in to the wall. I do not hear buzzing or clicking noise any longer. When I plugged the main board back in and kept the LCD wires unplugged from the power board I heard the noise all over again.
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4301
          • Italy - Milan
          "When I plugged the main board back" sorry my english is bad, what do you mean here for plugged? Because after you say " in and kept the LCD wires unplugged from the power board" so the Power b. was plugged to the rest or not in the last test? If yes your PSU is good, test and post a photo of the main board; LCD wires don't plugs into the Power b. (PSU) but in the main board.
          • LiquidSilver
            • Jan 2014
            • 9
            Sorry, I live in the U.S.A and my English is still bad. LOL.
            When I plugged the power board into the main board, kept the LCD back light wires, and Main board LCD wire unplugged I heard the noise all over again (First Picture shows how I had it connected along with some notes on the picture).
            I'm not sure what to test on either boards, but I do have a multimeter that I've used once before. I'm just getting into diagnosing board level issues and I'm pretty excited to learn it as it would save me a lot of money when fixing electronics.
            Thank you for your help Davi.p!
            Last edited by LiquidSilver; 01-04-2014, 08:10 PM. Reason: spelling/grammar errors
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4301
              • Italy - Milan
              sorry i'm an old billygoat i have forgot that lcd also has b.light wires :-D.. but my english still don't help me, you said:"kept the LCD back light wires" you mean the first test only PSU=no noises, 2nd test PSU+mainboard only= noises? The substance doesn't change much 'cause your psu is ok but your problem is the mainboard. Locate the voltage regulators ICs on that, are those 3 leg+1tab like U101, U102 and ?U113? (visual is not good), without power use the diode test mode and test for short them, all combination of pins, but first of all in your tests have you disconnected CN108 that seem for speakers?
                OK, in the first pictures of post 6, without having the backlights lamps attached, when the inverter board fires up, the high voltage lamp sockets will arc like crazy then it will go into shutdown to protect itself. You can run the power supply/inverter board by itself with lamp attached and force on the backlights inverter to see if the lamps will stay on. You need to locate BL_ON signal pin though.
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4301
                  • Italy - Milan
                  yeah it's true, BL_ON=ON-OFF pin 8, you can connect 1k resistor between pin8 and pin 13/14.
                  • LiquidSilver
                    • Jan 2014
                    • 9
                    @Davi.p CN108 is the Power button w/LED attached with the volume button board. I just tested the two board connected minus the CN108 connection and still got the buzzing noise. I tested the U101, U102, and U113 with the multimeter (pictures have the results).
                    @budm I orginally heard the issue funny noise after plugging everything in where it belongs and tried to power up the monitor before I closed it all up.
                    I guess I'll have to go to Fry's Electronics tomorrow morning to get a 1k resistor. Is there anything else I should pick up from Fry's to help with further testing of this board or other boards? I would love to get everything I'll ever need for testing while I'm there, I just don't know what all I'll need.
                      You have to do the test first, by the way, try that with the original board fisrt. So you do not have any resistor at all? it can be anything from 100~1000 Ohms.
                      • LiquidSilver
                        • Jan 2014
                        • 9
                        Which original board? I kinda crapped (my practice soldering board now) the original main board thinking it was bad and bought a "new" one from ebay. It didn't work so I bought a "new" power board from ebay (china). I guess I could take one of the resistors off the old power supply board that we giving me the same issue but a worse noise. This is my first/second time trying to diagnose anything on this level, so I don't have much of anything for testing with besides a multimeter and a few old boards I will use to take chips from.
                        • Davi.p
                          Hobbist Tech
                          • Sep 2009
                          • 4301
                          • Italy - Milan
                          now see what story if this new psu board is bad!.. You dont have any old/broken/unuseful electronic item where to rob a resistor? (1k=brown black red stripes)
                            I am confused, so you bought new MAIN Board (the board that has the VGA, DVI connectors), then you also bought a new power supply board. So something just does not make sense, new main board and new power suppl board and you still have problem.
                            • LiquidSilver
                              • Jan 2014
                              • 9
                              yes. can it be the back light? or maybe someone sold me a used/refurbished board.
                              • Davi.p
                                Hobbist Tech
                                • Sep 2009
                                • 4301
                                • Italy - Milan
                                I saw in post 2 that you used the word NEW with " " so you don't be sure if is new or not(?)
                                • LiquidSilver
                                  • Jan 2014
                                  • 9
                                  honestly I'm not sure if they are new or refurbished just because I bought them off eBay. Its a gamble when you buy stuff from there.
                                  • LiquidSilver
                                    • Jan 2014
                                    • 9
                                    should I solder the resistor between those pins and do I need one resistor for 15 and 8 and another for 14 and 8?
                                    • LiquidSilver
                                      • Jan 2014
                                      • 9
                                      the original problem I was having with the monitor was it kept going into sleep mode. so I changed the logic board and after that the monitor wouldn't boot up, so I thought maybe the power board was bad and still the same issue. so I plugged it all up and listen for an kind of noises and head what I described in the earlier post.
                                      • m1ch43lzm
                                        by m1ch43lzm
                                        05-12-2025, 08:37 PM
                                        by momaka
                                        03-15-2023, 10:17 PM
                                      • lostone
                                        Looking for help with a Viewsonic VP230mb where the backlight comes on only momentarily
                                        by lostone
                                        Hello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
                                        First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
                                        When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...
                                        05-19-2024, 11:40 AM
                                      • penangit
                                        Hp v193 monitor power supply board
                                        by penangit
                                        Hey everyone,hope everyone is fine, I got an issue hoping you guys can help me,
                                        I got a HP V193 monitor it has a E59670 now i got a few of these, been using them for long time now, however this particular monitor was blacking out for a few times then after unplugging and plugging it back in it gets back to normal until now its dead.
                                        I tried switching the power supply board with another similar monitor and it works,so I'm trying to fix this power supply board I got some basic in electronics as a hobbyist.
                                        Steps taken so far:
                                        Checked all...
                                        02-21-2023, 04:00 AM
                                        HP ProDesk DESKTOP BUNDEL (P5K01EA+M1N98AT) ProDesk 400 MT Intel Core i3-6100 + E232 monitor ProDesk 400 i3-6100 Specification for Upgrade or Repair
                                        This specification for the HP ProDesk DESKTOP BUNDEL (P5K01EA+M1N98AT) ProDesk 400 MT Intel Core i3-6100 + E232 monitor can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk DESKTOP BUNDEL (P5K01EA+M1N98AT) ProDesk 400 MT Intel Core i3-6100 + E232 monitor boardview and ProDesk DESKTOP BUNDEL (P5K01EA+M1N98AT) ProDesk 400 MT Intel Core i3-6100 + E232 monitor schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon...
                                        09-12-2024, 03:28 PM
