Dell E193FPc
  • Peale
    • Apr 2009
    • 96
    Dell E193FPc
    Received this monitor from someone who was just going to toss it.
    He stated that he had capped it, and that it had not worked after that, so he tossed it into a corner.
    When I opened it up, it was obvious what was wrong: the mosfets were blown open. Charred. Replaced them, and then it worked! Well, the backlight works. It has a white picture, with pinkish lines on the sides.
    I'm really hoping to get this going again, since it's a 19" 4:3 monitor. Great for arcade games.
    Photos, forthcoming.
  • Peale
    • Apr 2009
    • 96
    Re: Dell E193FPc
    And, here are the photos.
    Something tells me that this is either the logic board, or a poor connection to the LCD panel.
      Re: Dell E193FPc
      It sounds like the T-con on the LCD panel assembly may not be getting either 5 or 12V from the logic board, check the fuse and the voltage on the LCD panel.
      See examples:
      http://s807.photobucket.com/albums/y...cpZZ2QQtppZZ20
      • Peale
        • Apr 2009
        • 96
        Re: Dell E193FPc
        Curses...I don't have a small enough Phillips screwdriver handy. I'll check it ASAP.
        • jetadm123
          • 2169
          Re: Dell E193FPc
          Transistor Q210 on the power board between the two inverter transformers looks like it shorted out.
          Disregard, I see that you already replaced them.
          • Peale
            • Apr 2009
            • 96
            Re: Dell E193FPc
            Yup! Although I'm curious how you noted that - the board isn't browned or blackened there, that I can see.
            edit: never mind - it's quite obvious, in the photo.
            • Peale
              • Apr 2009
              • 96
              Re: Dell E193FPc
              See examples:
              Finally found the right size screwdriver. There's only one fuse, and it appears to be fine (verified with mulitmeter). From where do I verify voltages?
                Re: Dell E193FPc
                Black probe on the chassis, red probe on one end of the fuse at a time.
                • Peale
                  • Apr 2009
                  • 96
                  Re: Dell E193FPc
                  2.86 VDC, either side of the fuse.
                  • jetadm123
                    • 2169
                    Re: Dell E193FPc
                    Voltage seems a bit low. Typically, it's more like 5 VDC. Try measuring for the 2.86 V at the black wiring harness of the main board and trace your way backwards.
                    • Peale
                      • Apr 2009
                      • 96
                      Re: Dell E193FPc
                      Difficult to trace back. A schematic would be helpful. The board is dual layer, so moving it around, while on, hasn't been easy.
                      Knowing what the voltages are supposed to be on the input/output pins would be helpful. On the harness from the PS to the logic board I found 3.03V, but I'm not sure if that's feeding that.
                        Re: Dell E193FPc
                        Diagram of the main board if it matches yours. I expect 5V as well. There is a switched transistor that supply the voltage to the T-CON.
                        • Peale
                          • Apr 2009
                          • 96
                          Re: Dell E193FPc
                          I'm having trouble trying to follow that. On page 27 I can find the connector (CN103) but I don't see the transistor you mention on that schematic.
                          As a guess, when looking at the board, itself, there's U105.
                          edit: found U105 on page 28, but it just has traces going to nowhere. I can see that it outputs both 3.3 and 5...
                          I'll power it up and see what it puts out. When I use the diode function of my meter to test it, it reads every which way. Perhaps it's because it's in circuit...or, perhaps it's bad.
                            Re: Dell E193FPc
                            Please see PDF.
                            • Peale
                              • Apr 2009
                              • 96
                              Re: Dell E193FPc
                              Found them both. Testing them in circuit also gives some odd results.
                              They're really small, and in a bad spot. I don't have the equipment to replace them properly.
                              • Peale
                                • Apr 2009
                                • 96
                                Re: Dell E193FPc
                                Tested the voltages coming off of Q104, here are my results.
                                I don't know which pin relates to B/C/E, so I included this photo to illustrate what I'm looking at.
                                Top pin - 5.06V.
                                Left pin - 0.08V
                                Right pin - 5.06V.
                                Does that mean that the 5V is being interrupted somewhere upline?
                                  Re: Dell E193FPc
                                  It is MOSFET which has S, D, and G.
                                  S should have 5VDC, G = ~5VDC, D (the top tab) = 5vdc
                                  Also take the resistance reading between the D and the fuse on the T-CON board to make sure that it is less than 1 OHM.
                                  Voltage measurement must be done with the monitor power on and with running PC.
                                  • Peale
                                    • Apr 2009
                                    • 96
                                    Re: Dell E193FPc
                                    Do I need to have a running PC if this is one of those monitor which is "always on" when it's on?
                                    • Peale
                                      • Apr 2009
                                      • 96
                                      Re: Dell E193FPc
                                      So...
                                      Source = 5.06V
                                      Gate = .08V
                                      Drain = 5.06V
                                      That's without the LCD panel attached. Working on that, now...
                                      • Peale
                                        • Apr 2009
                                        • 96
                                        Re: Dell E193FPc
                                        It's reading in the MEGA Ohms. Red lead to Drain, black lead on the fuse on the TCON. So, somewhere, I've got a break, correct?
                                        • Bowline
                                          by Bowline
                                          06-11-2025, 10:13 AM
                                        • Akhlz001
                                          by Akhlz001
                                          09-20-2025, 07:15 PM
                                          Dell Thunderbolt Firmware
                                          by SMDFlea
                                          Dell thunderbolt firmware, extracted from dell firmware update exe. Padded to 1MB.
                                          Some models have a choice of 2 different firmwares, it depends on the dell SKU.
                                          The SKU is in brackets (****)
                                          EDIT: NVM65...
                                          01-26-2025, 06:22 AM
                                        • dell_sadness
                                          Dell Latitude 3440 - Service tag ending in 0001 - Locked!
                                          by dell_sadness
                                          BIOS password locked Dell Latitude 3440 (Service tag B4HNJX3)
                                          Have extracted the BIN and want to know how to rebuild a clean BIOS
                                          I have come across the 8F8C patcher but not sure if that would work in my case as the service tag ends in 0001.
                                          I tried it and although the log states it patched several mentions of 8F8C in the BIN, I haven't flashed it yet in case such a patch wouldn't work.
                                          Have also tried to extract a clean BIN file from Dell's .exe BIOS updates using 'Dell PFS Extractor', but not confidently; Ended up with a 25MB file instead of the same 32MB...
                                          11-12-2025, 02:54 PM
                                        • F R 2568
                                          Dell Latitude 5420 does not start (no post) need help to find the reason why
                                          by F R 2568
                                          Hello all,
                                          this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
                                          I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
                                          If the laptop is only connected to the AC adapter (battery removed):
                                          When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
                                          The power/battery...
                                          01-08-2025, 05:45 AM
