Acer main board part ID
+ More Options
Posts
  • 1supertech
    • Apr 2012
    • 384
    Hello all
    I acquired an Acer H233H When turned on it has a white screen problem
    checked all caps on power supply all tested good on esr meter I noticed a burned diode, correct me if not a diode I measured resistance I get 10.25 ohms both directions. I also lost all power to screen led button.
  • selldoor
    Slow Learner
    • 7870
    Re: Acer main board part ID
    Can you clean up the damage area with some isopropyl alcohol - you may even be able to read the part number on the burnt item
    • 1supertech
      • Apr 2012
      • 384
      Hello selldoor
      I cleaned of with alcohol I see A 14 with a burn mark in middle any Idea what that is
      • selldoor
        Slow Learner
        • 7870
        Working on it - is it at I304
        • 1supertech
          • Apr 2012
          • 384
          Yes I see faintly an I304 under diode
          • selldoor
            Slow Learner
            • 7870
            OK No - I think it is I301
            I searched for the board number.
            The same board is in the G245H.
            See Attached
            Think it is one of these
            http://www.alldatasheet.com/datashee...TC/AO3419.html
            • 1supertech
              • Apr 2012
              • 384
              See Attached
              Thanks Selldoor I found it on digikey
              https://cdn.badcaps-static.com/pdfs/...5e3d5c4bc2.pdf
              • Dani_2024
                by Dani_2024
                10-28-2024, 05:06 PM
              • m1ch43lzm
                by m1ch43lzm
                05-12-2025, 08:37 PM
              • cheeky2
                by cheeky2
                05-25-2024, 03:27 AM
              • advant
                by advant
                02-03-2020, 12:25 AM
              • Destroyer-Br
                [HELP] Acer AN515-55 (LA-J871P Rev: 1B) – Board won't power on after GPU investigation – Suspecting Super I/O or PCH
                by Destroyer-Br
                I'm working on an Acer Nitro 5 unit with the following specs:
                • Motherboard: LA-J871P Rev: 1B
                • Model: Acer AN515-55-59MT
                • S/N: NHQ7JAL00403906A973400
                • SNID: 03902728734
                Initial Issue
                The laptop initially presented graphic issues and driver failure (Code 43) for the GPU.
                After preventive maintenance (cleaning, thermal paste, etc.), it powered on normally. We disassembled it again to inspect the GPU, reassembled...
                04-17-2025, 08:18 PM
