What component is this that burnt?
  • m3at
    • Nov 2012
    • 7
    • usa
    Smelled some electrical fire smell from monitor. A few days later monitor would start to flicker and lose power and turn off. Turn on monitor and saw some part shooting electrical arcs. Evens though the monitor still works, I opened it up. The part looks pretty fried. Can anyone help me identify the part that is burnt?
    And what do I replace it with.
  • selldoor
    Slow Learner
    • 7870
    Re: What component is this that burnt?
    what is the board number ? machine make/model?
    Is there a board description Cxxx D xxx Rxxx
    cant quite read the bar code what is the number in the box begins
    PLL******1D and has a tick beside it
    • m3at
      • Nov 2012
      • 7
      • usa
      Sorry, it is : lg m276d-pm. Are the blue things capacitors?
      • selldoor
        Slow Learner
        • 7870
        Yes how odd - thought this was going to be the same board - anyway see if your board has the same cap in the same position at the other side.
        • selldoor
          Slow Learner
          • 7870
          Edit El Stupido it is the same but the other way up so the toast is the one marked same and the good one Toast
          • m3at
            • Nov 2012
            • 7
            • usa
            Anyone know the specs for those ceramic capacitors? I've never replaced those kinds. Just the typical electrolyte ones.
            • selldoor
              Slow Learner
              • 7870
              They are all different , but usually have some numbers on, have a good look at the one in the position marked toast - may need a magnifier but not usually.
              • ben7
                Capaholic
                • Jan 2011
                • 4059
                Probably like 10nF - 47nF, high voltage (>= 1kV) ceramic epoxy coated capacitors.
                Muh-soggy-knee
                  master hoarder
                  • May 2008
                  • 12175
                  • Bulgaria
                  Read the marks on C414 or the other blue caps of the same size. The marks on the burnt caps were most likely the same. As ben7 said, probably a few nF rated for 3 kV or higher (so far 3 kV for those caps is what i have seen regularly in monitors).
                    by momaka
                    03-15-2023, 10:17 PM
                  • keepread
                    Dell monitor PSU vs Dell laptop PSU
                    by keepread
                    Hi there!
                    Someone gave me their old monitor, it's Dell S2715ht.
                    The owner was using it when his PSU began to smell and then to smoke. It literally began to melt. He turned the monitor off, pulled the PSU, and ditched it because it was smelly even after it cooled. So I got the monitor but not the plug.
                    Now, I tried to bring the monitor back to life, by plugging one of my many Dell laptop PSUs. They are of the same 19.5V, and the wattage of the laptop PSU is higher than that which the monitor is rated for. Visually, the socket on the monitor seems compatible, and the plug plugs...
                    10-30-2025, 04:45 PM
                  • electomech-fixer
                    First post -Intel NUC 10i5 -BXNUC10i5FNH not powering on -IC burnt- request for IC details/datasheet
                    by electomech-fixer
                    I came across this very active forum with knowledgeable folks on electronic circuits and components, while google searching for the details of my burnt IC marked 7603 in Intel NUC board. I joined this forum today and this is my first post here.
                    I recently got an Intel NUC 10i5 and had installed Linux Mint and was using it for about a month when it died suddenly and did not power up after that.(Power Adaptor is ok). When I opened the NUC , there was a burnt IC marked 7603 (and ILCB in second line). I am unable to find the details/datasheet of this IC. I will be grateful if...
                    09-15-2025, 01:42 AM
                  • wattage
                    AOC AG493UCX 49-inch monitor - Firmware request
                    by wattage
                    Hello Badcaps Community,
                    The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...
                    07-13-2025, 04:41 PM
                  • ant3202
                    HP 27es - LED monitor - Monitor Flashing On - Off
                    by ant3202
                    Hi Everyone
                    Lately I am experiencing the deja-vu incident on one of the led monitor like this.
                    https://www.badcaps.net/forum/troubl...lashing-on-off
                    The monitor is HP 27es LED Monitor
                    https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
                    The monitor will randomly blackout and display no signal and will recover again.
                    Sometimes need to power and off again to restore the display but...
                    03-20-2025, 07:30 PM
