Dell 2408WFPb Monitor - No Power
  • ForensicFixer
    • Nov 2012
    • 36
    Re: Dell 2408WFPb Monitor - No Power
    The voltage across the cap varies between 321-327 v. Doesn't seem to change in time to clicking.
    • selldoor
      Slow Learner
      • Dec 2010
      • 7870
      Ok What voltage is there at the torpedo fuse? Measure each side of fuse to ground
      Also near the fuse there is IC701 - can you test it - they dont often seem to go wrong but we have had a couple lately and as the fuse was blown perhaps it got taken out as well?
      You mentioned D 602 can you retest and state the resistances ideally should be
      resistance above 30ohms one way and very high/ off scale the other.- You may have to lift one leg to test.
      • ForensicFixer
        • Nov 2012
        • 36
        Voltage at torpedo fuse cycling 5-7.5 volts on both sides. D602 out of circuit shows 28.9 Kohms and 0 ohms. Don't know how to test IC701. Identified it with markings KA431AZ as being a three terminal adjustable regulator.
        • Toasty
          • Jul 2007
          • 4171
          Check C601, the blue one.
          T
          veritas odium parit
          • selldoor
            Slow Learner
            • Dec 2010
            • 7870
            Can you test the diode on diode mode Oohms suggests a short
            • ForensicFixer
              • Nov 2012
              • 36
              Apologies meant to say no reading. In diode mode shows .533v and 0v
              @Toasty-I take it you mean the blue capacitor next to the transformer. Any tips on how to test these?
              • Toasty
                • Jul 2007
                • 4171
                #27
                Diode is fine.
                Yes. Look at the underside of the board to see the component numbers.
                You'll need a meter that can check the capacitance. Some DMM's have a capacitance check function. It will need to be removed from the circuit to verify the value.
                Transcribe the numbers/letters line by line from the cap here so we can determine the values.
                T
                Additional: Did you replace both electrolytic caps on the hot side? C611 & C606?
                Since the fuse popped, something is wrong beyond the PSU. Getting the PSU working is the first step towards resolving the other issue. Had someone worked on this before?
                There maybe a standby voltage produced by the PSU that is passed to the circuits beyond, but is controlled by the Opto IC652 which tells the PSU "I'm okay" and allows it to switch on when needed.
                Probably produced by the regulator IC603 (3-legged, TO-92 package) above the mains cap. What are its' markings & find a datasheet for it. What voltages do you get measured from HOT ground to each leg?
                T
                veritas odium parit
                • retiredcaps
                  • Apr 2010
                  • 9271
                  #28
                  I assume you mean 0L (out of range).
                  PS. A multimeter always gives you a reading when it is turned on. There is no such thing as "no reading".
                  Interpreting it correctly is key.
                  --- begin sig file ---
                  --- end sig file ---
                  • ForensicFixer
                    • Nov 2012
                    • 36
                    @Toasty
                    Tested the blue capacitor 1.01 nF,
                    Markings
                    102J
                    2J
                    IC 603 is marked MCR 100-6 816
                    seems to be a silicon controlled rectifier, datasheet here http://www.futurlec.com/Diodes/MCR100-6.shtml
                    Tested all legs,
                    a pin cycling 6-12v
                    all other pins showing 0v
                    • jetadm123
                      • 2169
                      #30
                      Did you ever verify that mosfet Q601 is not shorted?
                      • Toasty
                        • Jul 2007
                        • 4171
                        #31
                        Cap is okay.
                        Marking it on the board as an IC is a mistake/misnomer. Should be a "D" something.
                        T
                        veritas odium parit
                        • ForensicFixer
                          • Nov 2012
                          • 36
                          Q601 is marked K3548 6692 01
                          Tested across pins in circuit.
                          Pins 1 2 3, G D S
                          1-2 0L
                          1-3 0L
                          2-3 225 ohms then 0L
                          I think this is maybe worth removing and testing further.
                          Couldn't find a datasheet.
                          • Toasty
                            • Jul 2007
                            • 4171
                            #33
                            Have you tested the 3 output rectifiers? D70? ? (can't make out the numbers)
                            veritas odium parit
                            • ForensicFixer
                              • Nov 2012
                              • 36
                              Yes they are actually 2 schottky diodes and tested ok.
                              Also tested the cold side for shorts with the transformer removed. Again tested ok.
                              • Toasty
                                • Jul 2007
                                • 4171
                                #35
                                You mean 3 don't you?
                                veritas odium parit
                                • ForensicFixer
                                  • Nov 2012
                                  • 36
                                  No, third position on heat sync (middle) is not populated.
                                  • Toasty
                                    • Jul 2007
                                    • 4171
                                    #37
                                    Ok.
                                    Pins 1 2 3, G D S
                                    1-2 0L
                                    1-3 0L
                                    Fuji Electric 2SK3548 - been looking for a long time for that one.
                                    Use diode check function and test both ways. Unlikely that it's bad if the 0.22Ω resistor is good.
                                    Have you checked that little electrolytic over at the far left of first picture?
                                    This uses PFC, if I'm not mistaken. You should be getting 385-400v on the mains cap when on. I think perhaps the boost controller or its' circuit may be the culprit. Love to get hands on with one of these someday.
                                    What is IC651?
                                    T
                                    veritas odium parit
                                    • ForensicFixer
                                      • Nov 2012
                                      • 36
                                      IC651 is marked L6561, Power Factor Corrector apparently?
                                      however c622 that's the cap on the far left is 100v 1uf
                                      measured out of circuit o.92uf and esr 2.4 ohm
                                      This could be the culprit?
                                      Will try to get replacement tomorrow
                                      • Toasty
                                        • Jul 2007
                                        • 4171
                                        #39
                                        Cap values measured sound okay.
                                        Clean the backside with alcohol and a soft brush to get rid of the flux. Visually inspect every chip transistor and resistor for burn marks with a magnifying glass/loupe. Test the transistors using the diode check function.
                                        I'm usually pretty good at picking them out in the pics, but there's too much flux distorting the pictures.
                                        Does R620 have a crater?
                                        Are there any Zener's on there?
                                        T
                                        veritas odium parit
                                        • Tynan Dill
                                          by Tynan Dill
                                          Assuming...
                                          11-22-2024, 01:46 PM
                                        • PantherDave
                                          by PantherDave
                                          Hi all!
                                          I'm trying to troubleshoot a Microsoft Surface Pro (5th gen) model 1796 that won't power on. Motherboard model is M1007506-015. My priority is retrieving data, but the SSD is integrated so it looks like if I can't repair it it'll need to go to a data recovery company. I've done a little basic board repair before, but nothing this advanced until now. So please forgive my ignorance in advance. ๐Ÿ˜…
                                          05-29-2024, 02:01 PM
                                        • Mark01
                                          Dell Optiplex 7490 AIO - red power led after flash
                                          by Mark01
                                          Hi guys,
                                          This is my first post! ๐Ÿš€
                                          I have no idea what Iโ€™m doing, but Iโ€™m learning by trial and error.
                                          Iโ€™m currently working on a Dell Optiplex AIO 7490โ€”one of a bunch of AIOs that mysteriously failed to POST just a few days after the warranty expired. The original issue was that the PC worked fine until it was rebooted, after which it got stuck on a black screen (no backlight), with fans spinning at normal speed and a solid white power LED. Forcing it off by holding the power button would just cause it to switch on automatically and get stuck again on...
                                          07-04-2025, 12:54 PM
                                        • zlr8r
                                          Dell inspiron 17 (7786) - DP/N 09P7JP - odd power issues, starting with no power LED
                                          by zlr8r
                                          hey guys, hoping for some pointers to repair an eBay bought "faulty" laptop.
                                          Ill try and give as much info as I can.
                                          Dell Inspiron 17 (7786) Laptop
                                          Service Tag: 5J0NHT2
                                          Bios: 1.9.0
                                          When I received this , it would only flicker on the KB backlight for a second, then off and on.
                                          Then it started getting weirder!
                                          Sometimes when attaching the AC power supply, and pressing various pre-boot diagnostic keyboard keys... it did try to boot, in fact out of a hundred attempts, the laptop did actually boot into the Bios ! but never has...
                                          12-12-2023, 09:31 PM
                                        • Jesus Coder
                                          Issues Reviving Old Dell 2408WFPb Monitor
                                          by Jesus Coder
                                          I have been having some difficulties reviving an old Dell 2408WFPb PC monitor that I received for free. When I first acquired it, the backlights of the display were on but alas no image was showing. After extensive research on the topic, I went ahead and purchased a new t-con board for the monitor. After installing the board, I was then presented with a new screen that was half black and half green (more so black). I have been unable to figure out what to do next as I have limited knowledge of display electronics. Might anyone on this forum have an idea of what may...
                                          06-25-2023, 02:33 PM
