DCLLCD DCL7A - quick flash of the back lights only
  • jayoung
    • May 2011
    • 172
    Re: DCLLCD DCL7A - quick flash of the back lights only
    I replaced Q11 & Q12 and was able to get from just a flash of light to basically 2 seconds to black. The lights would stay on for varying lengths of time and there was a distinct arcing sound with the original ccfls and known good ccfls.
    I removed both transformers and found the secondary winding of transformer 1 to be non conductive. I'm not sure if this occurred during the removal process or not since all 4 ccfls were working when the monitor was exhibiting the 2 seconds to black. It's probably not worth the cost of a replacement transformer for a 17" monitor.
    • corrize
      Nikon D800 camera - flash don’t work and capacitor don’t charge
      by corrize
      Hello, I'm stuck in troubleshooting…
      The flash system works like that : when the (mechanic) flash button is pressed, the flash mecanically pop up, and a circuit buck boost elevate 7v (batt) to 200-300v (?) for charging the big capacitor. And when the photo shoot button is pressed, the capacitor is discharged in the xeon light.
      In the D800, there is a first « power board » close to the battery. 2 wires (batt 7v) goes to another little « flash board ». I measured 7v, so ok.
      When I press the flash button, it's detected by the system, flash icon appear on LDC display....
      10-01-2022, 10:02 AM
    • tennno`
      RCA LED46C45RQ,Sound but no Back lights
      by tennno`
      Sound no picture RCA LED46C45RQ,Power Supply Board RE46HQ1301.
      Has All voltages coming from main board.No voltage going to
      Back lights from power board.Have no Schematic.Back lights work when
      Led Back light Strip tester is used.Tester shows 110 volts from each
      side.Also if you use the side controls and use the vol +or- tv shuts
      down.
      Thanks for any help
      04-10-2022, 03:34 PM
      Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
      This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
      I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
      I am comparing them to a brand new one that I installed
      The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
      I going to let it run for several days before I remount back on the wall next to the...
      09-05-2024, 06:48 PM
    • Musictuff
      70UH6350 Back lights
      by Musictuff
      My LG tv started going dark a few seconds after powering on. I replaced the led back lights after doing the flashlight test. The problem I am having now is the bottom of the screen is really bright and the middle to the top of the screen is darker. I can actually see the individual leds at the bottom of the screen. Not sure why that is. I've tried lowering the backlight setting but I can still see the led's at the bottom, and the middle to the top of the screen gets even darker.
      04-09-2023, 11:45 AM
      HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i7-9700 Specification for Upgrade or Repair
      This specification for the HP ProDesk 600 G5 + APC Back-UPS 700VA can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + APC Back-UPS 700VA boardview and ProDesk 600 G5 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
      09-12-2024, 02:30 PM
