Viewsonic VX2235WM - blank screen on/off
  • Mrx3750
    • Jul 2013
    • 311
    Re: Viewsonic VX2235WM - blank screen on/off
    Okay! Something very interesting happened. I connected pin 16 to my multimeter and I get something like 2.61 volts when the monitor is not lit, and 0.06 volts when it is lit. So i ran the PC, played Solitare... The monitor went out and the multimeter still read 0.06 volts. However when I shut the PC down, it lit up saying the no signal message, then went into standby as normal.
      OK, how about pin 15, did it go low also? I am trying to find out if pin 15 is the Inverter on and pin 16 is the DIMMING control pin or it is another way around. It may be using active LO (LO = Inverter ON)
      • Mrx3750
        • Jul 2013
        • 311
        Okay just tested Pin 15, and it stays at 3.01 volts even after the monitor blacks out.
          So those two signals stay the same when the monitor blacks out, then I would look at the inverter circuits section then.
          There is small glass fuse, that fuse is for feeding the B+ to the inverter circuit, see you have DC voltage at both ends measuring against the chassis ground when it is working and when it blacks out.
          • Mrx3750
            • Jul 2013
            • 311
            Okay just tested the fuse, and when the monitor is not lit, the voltage is around 23.5 or 24 volts DC. When the screen is lit it drops to 19.2 volts.
            When the screen blacked out, it went up to 22.1 volts.
            Oh, and voltage readings are the same on either end of the fuse against chassis ground.
              That is a big drop from 24V. Did you replace any caps in that 24Vdc power supply section, at this point you may need ESR meter to verify the ESR of those caps, the bad cap can have correct capacitance but the ESR can be high.
              For example:
              https://www.badcaps.net/forum/showth...416#post288703
              • Mrx3750
                • Jul 2013
                • 311
                All right. I think I have the caps needed, so all the ones I saw in the pic you posted I'm gonna pop out and put in known good ones.
                Okay, just replaced everything except a couple 220uf @ 25 volt capacitors, because I don't have those right now. B+ voltage still reads 19 volts when the display is lit up. Haven't tested it further.
                Getting kinda nervous about this board. Even with my 40 watt iron at 2/3 setting I lifted off a foil trace on the 330uf cap and had to get creative with bridging the gap. I'll look for some 220uf caps and if I change those and there's no joy, I'm stumped unless it's a bad CCFL, then there's no point in me bothering with it.
                  You may have to make a couple of these test lamps:https://www.badcaps.net/forum/showth...er+testing+cfl
                  Some monitor with bad lamps can run fine for hours, this one will go black after 3 hours or so, I finally took it apart to see what is going on (it runs fine with my test lamps in place all day).
                  http://s807.photobucket.com/user/bud...?sort=3&page=2
                  • Mrx3750
                    • Jul 2013
                    • 311
                    That's interesting. I'll keep that in mind.
                    But if it comes down to bad CCFL's, that's where I give up and scrap it, unless I can source a panel cheaply.
                    • Mrx3750
                      • Jul 2013
                      • 311
                      Okay, even after replacing every capacitor on this power board, I'm still getting the same problem. Monitor will run nice and dandy for a few minutes, and gives me a perfect picture, then just up and shuts off.
                      I'm at my wits end. Gonna try running it with a CFL unplugged, one at a time, and see what the results are.
                      • Mrx3750
                        • Jul 2013
                        • 311
                        Well, I think you guys are correct. It's a bad CCFL.
                        Starting from the bottom and working up, I unplugged one CCFL connector at a time. Having the first one unplugged, the monitor ran for about 30 seconds, unplugging the second one I got about a second before it quit.
                        I unplugged the third one, with the others plugged in, and now the monitor seems to be running fine. I got through a whole game of solitaire without an issue.
                        Now, here's where it gets really weird for me. Even with one of the CCFL's unplugged, the picture looks just fine. I figured there'd be a dark band in the image.
                          It is edge lit so you will not see any dark band like you will see on LCD TV which does not use edge lit CCFL setup. The top edge and the bottom edge may not have the same brightness.
                          I am surprised that the circuit did not detect open lamp connection and goes into shutdown.
                          • Mrx3750
                            • Jul 2013
                            • 311
                            I'm surprised too, but now that I'm fairly confident it's the CCFL's, how would I go about sourcing replacements, or would I be better off finding a new panel?
                            • Ryan.man
                              by Ryan.man
                              02-04-2025, 12:23 PM
                            • Chrissygizmo
                              Panasonic TX-48CX350B backlights but white screen , blank screen
                              by Chrissygizmo
                              Hi all, I’ve got a problem I hope someone can help me fixi.
                              I have a Panasonic TX-48CX350B tv , it powers up ok but the screen is blank, the backlights are working, there’s nothing else though, no picture or sound. I’m not sure what the fault is called whether it’s BLANK/ BLACK/ or WHITE SCREEN I’ve actually came across this before on a similar tv but just ended up scrapping it, I will upload pictures of the boards etc , if anyone could help me I would really appreciate it...
                              01-11-2025, 03:18 PM
                            • dicky96
                              HP Elitebook Screen blank - backlights but no image
                              by dicky96
                              Hi guys
                              I'm trying to fix this laptop screen
                              Basically the owner is a computer shop and they brought it to me with two screens. They said the repair shop they use could not fix it, so I thought i would try to see if I am better than their current repairer!
                              OK so I have the original screen which works but has lines across the bottom quarter of the screen
                              I have the replacement screen, which they fitted and it worked. They then put the laptop on one side for a couple of weeks until they found a buyer. When they showed it to the buyer, the screen would...
                              04-28-2021, 07:30 AM
                            • kotel studios
                              Funai 32FL553P/10 - squealing from PSU, dies after 10 seconds, blank screen after logo, bootloops
                              by kotel studios
                              Found an Funai 32FL553P/10 TV on sale for cheap listed as broken, so I decided to give a shot at reparing this.
                              State I got it in:
                              Squealing from the PSU
                              After logo I get a blank screen
                              After 10 seconds of having a blank display w/ backlight the TV dies
                              Give it 7-10ish seconds again and it starts to bootloop.
                              What I did so far:
                              Replaced all the caps on the PSU (apart from primaries, they were fine and none at hand)
                              Checked all voltage rails:
                              5VSB - 4.8V
                              AMP+13V - 14.4V
                              13V - 12.98V (in manual 12V)...
                              09-21-2025, 02:00 AM
                            • reformatt
                              by reformatt
                              07-31-2025, 08:37 PM
