Benq fp222w Has no screen it lights up for a few seconds then goes black Any help please. All caps look ok
Benq fp222w
Re: Benq fp222w
Do you wonder why you seldom get any response to any of your posts?
If you read some of the other requests for help you may notice the amount of detail the others provide including what they have tested, what they have replaced & pictures. Many/most of us will have never seen a Benq222w.
The more effort you put into your query the better chance someone will respond.Please upload pictures using attachment function when ask for help on the repair
by liquidzorchHello. I bought a faulty Lenovo ideapad 3, but it turns out the 3Valw buck converter burnt a hole through the board. I was able to clean it up, and remove all the shorts. I now can power the 3.3v rails from a bench power suppy while connecting the laptop to its psu, and I get the additional 5valw, 1.8v, and 1.05v, form what I can tell in the schematics, those are the only 4 voltages I should see before turning on, and they are present. When I hit the power button, the power indicator on the left side turns on (not the one on the power button), stays on for about 12 seconds, then turns off for...
by kalemaroniThe capacitor on the board was slightly bulged at the top so I replaced. Unfortunately the cap I bought on eBay was much thinner than the original, even though the spec was the same (4.7uf 100v). The problem persists. Would the thickness of the cap actually make a difference - is it worth trying to find the correct one?
by twonk9098Hi all,
I have a Lenovo Legion 5 with a Ryzen 7 series CPU and RTX 3070 GPU. My issue is that it turns on and all seems fine except after a few seconds the fans spin up high and the laptop turns off after 34 seconds.
I can get into bios and can even boot and login to Windows however after 34 seconds no matter if Im at the bios screen or booted into Windows it will just turn off.
I have managed to run HWmonitor and the temperatures of the CPU and GPU are fine, I can also touch the heatsync which is warm but not hot.
I have tried a few new bios but exactly... -
by fab13Hello,
I have a ps4 Fat CUH-1116A, the worry is that when I got it back it turns on with the blue leds and a few seconds it turns off and you have to turn it back on and it turns off again.
It seems to be in security.
The fan does not turn even with a new one
Motherboard SAB-001
Checking made:
- New power supply block OK and even with another one always the same problem
- PS4 metal sheet is not too screwed
- New thermal paste and new fan
- Voltage 12 Volts arrived on the fan, no short circuit on the 12 V ... -
Assuming...7 Photos - Loading...
