Asus vw193d-b "2 seconds to black"
  • srbax
    • Nov 2012
    • 78
    • Serbia
    Hi guys.
    I have this Asus monitor and "2 seconds to black" problem.
    Help please!
    What is your opinion?
    I'm not very good at this, but I did some tests.
    I checked mosfet, diodes, transistors and I didn't found any short circuit or bad diode.
    Also I removed all caps and I checked their capacity with multimeter Fluke 179. All of them has good values, except big one. It has 92 mikroF out of nominal 100.
    Caps are Hermei and Elite.
    Voltages on CN902 are:
    12V - 13.79
    12V - 13.79
    5V - 5.19
    5V - 5.19
    NC - 0
    dim - 3.78-4.78
    on/off - 2.95
    Voltage on big capacitor is 308 V.
    Voltages on mosfet are:
    gd=306
    gs=0.36
    sd=310-315 unstable
    Voltage regulator (1084-33) on main board has this measurements:
    1. pin=0V
    2. pin=3.29V
    3. pin=4.35V
    Resistance of secondaries of two transformers for lamps is the same and it is 457 ohm.
    Resistance between pins of primaries is 0.1-0.3 ohm.
    Also I checked lamps without one spare, but without one of four lamps.
  • selldoor
    Slow Learner
    • 7870
    Re: Asus vw193d-b "2 seconds to black"
    "Also I checked lamps without one spare, but without one of four lamps"
    Can you explain this better - if a monitor has 4 lamps all four need to light for it to stay on.
    • srbax
      • Nov 2012
      • 78
      • Serbia
      I wanted to say that I used this scenario:
      b) Alternatively, if you do not have a spare CCFL, then try this test.
      a) TURN POWER OFF and unplug the monitor and wait 1 minute
      b) disconnect all CCFLs expect #1
      c) plug in monitor and turn monitor on - note if "2 seconds to black" occurs
      d) TURN POWER OFF and unplug the monitor and wait 1 minute
      e) disconnect all CCFLs expect #2
      f) plug in monitor and turn monitor on - note if "2 seconds to black" occurs
      g) TURN POWER OFF and unplug the monitor and wait 1 minute
      h) disconnect all CCFLs expect #3
      i) plug in monitor and turn monitor on - note if "2 seconds to black" occurs
      j) TURN POWER OFF and unplug the monitor and wait 1 minute
      k) disconnect all CCFLs expect #4
      l) plug in monitor and turn monitor on - note if "2 seconds to black" occurs
      My mistake.
      • selldoor
        Slow Learner
        • 7870
        Ok - so you checked each bulb in turn - yes?
        Did they each light up for 2 seconds then go out?
        Did you notice if any bulb was dimmer than the others ( I know its difficult to tell)
        • srbax
          • Nov 2012
          • 78
          • Serbia
          Yes, I checked each bulb in turn.
          Yes they light up for 2 sec.
          I didn't notice that.
          • selldoor
            Slow Learner
            • 7870
            Is the set all connected up now?
            If not can you retake the pictures of the board - looking straight down.
            If it is connected up then take them next time its apart and try this.
            With it all connected but off disconnect the cable from the main board to the screen
            Main board end is usually easier. Then try and switch it on and report.
            • retiredcaps
              • Apr 2010
              • 9271
              The test that I wrote when you do not have a spare ccfl does not imply that the ccfls are good when they light up for 2 seconds.
              That test only checks for a completely broken/cracked ccfl.
              You could have a bad ccfl return wire.
              --- begin sig file ---
              --- end sig file ---
              • retiredcaps
                • Apr 2010
                • 9271
                The Fluke 179 is a nice multimeter and while it can measure capacitance like any other multimeter, no multimeter in the world can measure ESR. For that you need an ESR meter.
                PS. 92uF is well within spec of 100uF. Most electrolytic capacitors are +/- 20% of their stated value.
                  Do you have old CFL?
                  http://s807.photobucket.com/albums/y...g%20old%20CFL/
                  Bad lamps assemblies:
                  http://s807.photobucket.com/albums/y...klight%20lamp/
                  • srbax
                    • Nov 2012
                    • 78
                    • Serbia
                    @selldoor
                    I did what You asked me to do and the same thing is happening, but without picture.
                    • srbax
                      • Nov 2012
                      • 78
                      • Serbia
                      And tomorrow I will do this with old CFL.
                      • selldoor
                        Slow Learner
                        • 7870
                        @selldoor
                        Ok reconnect the cable and thanks for the pictures.
                        Another problem illimination test is when it goes off after 2 seconds
                        does the power light stay on the same colour and can you still see a very dark image on screen shining a flashlight at an angle might help.
                        It still does look like a problem with the bulbs or wiring so have a look as budm asked.
                        If I recall correctly the cfl should be low wattage 4 to 11.
                        EDIT LATER
                        perhaps up to 14watts here is another budm tester if you didnt see it already
                        https://www.badcaps.net/forum/showthread.php?t=19987
                        • srbax
                          • Nov 2012
                          • 78
                          • Serbia
                          Ok guys, here are my lamps.
                          I suppose they aren't good?
                          • Lumberjack777
                            • 464
                            Nope, they aren't. In the first picture it appears the bottom ccfl is cracked. Those are definitely some well used ccfl's with the dark black ends.
                              Yep, they are bad!
                              • srbax
                                • Nov 2012
                                • 78
                                • Serbia
                                Thank you all very much for help
                                • retiredcaps
                                  • Apr 2010
                                  • 9271
                                  Save the good ccfl's for future testing.
                                  • Rick_1234
                                    LG 23MP55HQ LED Monitor turns off after a few seconds or flickers.
                                    by Rick_1234
                                    Good evening, gentlemen.
                                    I have a problem with my monitor. It turns off after a few seconds or flickers. Shining a flashlight on the screen doesn't show any image, so I guess it's not the "2 seconds to dark" I read in the forum.
                                    To turn it back on, I have to press the power button twice. Then after a few seconds it turns off again or flickers. See video.
                                    https://drive.google.com/file/d/1L6S...ew?usp=sharing
                                    Things I tried
                                    - Bought a new AC adapter thinking that was the problem but the problem...
                                    06-22-2024, 04:44 PM
                                  • sew333
                                    Pc shutdown, monitor flickered with no signal after 10 seconds
                                    by sew333
                                    My pc:
                                    10850K stock 4800mhz stock Kraken X73 good temps
                                    2x16 GB DDR4 GSKILL 3000mhz XMP
                                    Seasonic Tx-850 Ultra Titanium
                                    Gigabyte Rtx 3090 Gaming OC
                                    Aorus Z490 Pro Gaming
                                    1 TB SSD
                                    4 weeks ago i launched Metro Exodus Enhanced and during cinematic advertisement part ( 30 fps ), pc just shutdown.
                                    Also monitor flickered with NO SIGNAL 10 seconds after shutdown. So only monitor and pc was affected.
                                    Next i pressed only power button, rebooted again and its fine again. Happened once and i cant reproduce.
                                    Power...
                                    02-22-2022, 10:27 AM
                                    by momaka
                                    03-15-2023, 10:17 PM
                                  • myth77
                                    ASUS PG27U MONITOR
                                    by myth77
                                    First, i dont work on monitors only on laptops and that also for a hobby. So, i received this monitor in the title and it was completely dead, and power supply when used was going off to a power protection. I found that one of the voltage regulators for backlight GS9238 is dead, so i replaced it and monitor is working fine now. But...on the main motherboard first thing i tested was a main power rail and after power jack there is one mosfet Nikos PD537BA. The thing is when i tested all pins of that mosfet are shorted in between. Now when i plug the adapter the monitor just goes on. I dont think...
                                    03-19-2024, 08:58 AM
                                    ASUS ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year Notebook Specification for Upgrade or Repair
                                    This specification for the ASUS ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year boardview and ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively...
                                    09-07-2024, 02:50 AM
