Have a Hnc monitor with the 2 seconds to black. trying to isolate the issue to the bulbs. When I powered it on after a couple seconds it shuts off but the power led stays green not amber. Do those ccfl's run in series? Would one cause them all to go out or cause the voltage drop. Thanks!
2 seconds to black on HNC IH252 HPB Monitor
Tags: None
Re: 2 seconds to black on HNC IH252 HPB Monitor
Just shined a flashlight in the dark and could barely make out the screen. Would one of the bulbs cause a voltage drop or the inverter. Thanks! -
It has 4 individual lamps, if one is bad (draws too much current due to ages, or will not fire and conducts current) the whole Inverter circuit will shutdown.
Please read this:
https://www.badcaps.net/forum/showthread.php?t=10419
Here is pictures of bad lamp and tester lamp:
http://s807.photobucket.com/albums/y...klight%20lamp/
http://s807.photobucket.com/albums/y...g%20old%20CFL/Never stop learning
With them out of the panel try connecting one set at a time They wont stay on but you might be able to pin the problem down to an individual bulb.
Care as high voltage involved = do not hold the bulbs.Please upload pictures using attachment function when ask for help on the repair
http://www.badcaps.net/forum/showthread.php?t=39740Comment
Thanks Selldoor I did what you said and one of the bulbs was pink when it turned on so I'm assuming that's the bad bulb. The others were fine.Comment
Yes, you have bad lamp.Never stop learning
I also had the 2 seconds to black problem with my own I-INC IH252HPB monitor, although sometimes it was more like 10 to 15 seconds to black. I first tried moving the jumper on the inverter board from the 7.5ma position to the 8.0ma position with no luck. My IH252 inverter board looks the same as this one in this YouTube video : http://www.youtube.com/watch?v=NQBTKzpuEqI
I had a 19 inch Viewsonic VG930M-3 monitor on hand with a smashed in lcd panel that I was saving for parts, but with strong backlights. After disassembling the Viewsonic, it turned out it was also made by the Hannspree group and had the same connectors for the CCFL lights as the IH252, nice. In order to test the CCFLs on the IH252, I connected a CCFL from the VG930M to the IH252 inverter board, testing each of the 4 CCFLs on the IH252 one at a time. At any one of the 4 connections made, the other 3 CCFLs would remain lit and bright and no flickering, so I knew all 4 CCFLs in the IH252 were in good shape. But with all the IH252 CCFLs plugged into the IH252 inverter board, it would still get 2+ seconds to black syndrome.
Even though none of the TAICON capacitors on the inverter board were bulged or leaking, I replaced all (12) but the very largest one with Japanese Panasonic and Chemicon capacitors, thinking that one or more of them may have changed value. NO LUCK, I still got the 2+ seconds to black syndrome.
Puzzled at this point and not willing to spend much time and money on it, and with the 25 inch monitor still being acceptably bright with just 3 CCFLs, it was time for some good ole jury rigging, heh.
With some (real, not plastic) aluminum duct tape, I taped one pair (with the holder) of the VG930Ms CCFLs to the back metal plate of the IH252 as there was plenty of room. I remounted the stand and the bezel leaving the back cover off and went about using the monitor as usual.
About a week later, I said what the hey and plugged in the 4th IH252 CCFL. Low and behold, NO MORE 2+ seconds to black syndrome. The monitor now stays on with all 4 original CCFLs plugged in, now still going good for 4 days, knock on wood.
Im not totally sure what is going on, but I suspect at least one of the TAICON capacitors werent holding a charge, and that it took some time for the Japanese caps to charge up.
Any thoughts ?
Anyway, maybe someone else will find my experience useful.Comment
I'm having a similar problem. When the problem began, every few days the monitor would go to black for a few seconds then come back up and work fine until it repeated to process again in another few days. While the monitor went black, I could hear a hissing white noise coming from the back on the side of the power board. When the monitor came back online, the hissing ceased. Yesterday, The monitor blacked out and would not come back on. If I powered it off and then back on, it would remain lit for 20-30 seconds before dying again. during that brief time, I was able to adjust the brightness to zero, and now the monitor is working. When the monitor was blacking out I could see that it wasn't off, but was dark. I opened the monitor and inspected all the caps. I don't see any leaking or bulging in any. Since it works with the brightness turned down, I wondered if anyone had any ideas as to what is wrong. I know caps can be bad while appearing normal. Any insight anyone could provide would be appreciated.Comment
Post good clear pictures of YOUR board so we can see what are dealing with.Never stop learning
I have an IH252 which just shy of 4 years old decided to start doing this 5-10 seconds on before swiftly going blank.
Like sukmir70 I found that lowering the brightness seemed to cure the problem, so am now running it at 25% brightness.
A few months prior to this issue starting I noticed upon switching on the monitor, the bottom of the screen would have a pinkish tint which would slowly fade. With this, I am assuming the backlights are on their way out.
I decided to open the unit and inspect the capacitors, and none of them look blown-out or leaky, so I doubt that the capacitors could be at fault here.
I did not go as far as removing the backlights for inspection, but can anyone advise on the make and model of these backlights, or possibly a suitable replacement for them? Directions to a suitable backlight outlet will also be of help.
Thank you in advance.
RayComment
by Rick_1234Good evening, gentlemen.
Things I tried
- Bought a new AC adapter thinking that was the problem but the problem...-
by sew333My pc:
10850K stock 4800mhz stock Kraken X73 good temps
2x16 GB DDR4 GSKILL 3000mhz XMP
Seasonic Tx-850 Ultra Titanium
Gigabyte Rtx 3090 Gaming OC
Aorus Z490 Pro Gaming
1 TB SSD
4 weeks ago i launched Metro Exodus Enhanced and during cinematic advertisement part ( 30 fps ), pc just shutdown.
Also monitor flickered with NO SIGNAL 10 seconds after shutdown. So only monitor and pc was affected.
Next i pressed only power button, rebooted again and its fine again. Happened once and i cant reproduce.
Power... -
by valscuHello,
I have an Eizo SX3031W monitor and after a period i had problems with the tcon board. I did reflow, it went well for a while after but the problems appeared again. The second reflow attempt was a failure, the tcon board stopped working. In the meantime, I bought a perfectly functional Samsung 305T monitor from which I took the tcon board and installed it in the Eizo monitor. Since I turned on the monitor, the blue color appeared in the background instead of black. And also in Windows, appears blue instead of black. I tried various settings from the monitor and driver settings but...-
by turmixHello, I'm working on a new deskmod pc project and have a problem with my monitor, an AOC U34G3XM, well, I may have bricked it.
The monitor was dismanteled and the separate parts parts integrated in the desk. the screen panel alone is on the upper part, and main board/video board + power board on the back of the desk (not enough place on the cover to fit it)
At first everything was working smoothly, then I decided to change the connexion between the video board and the screen for a longer one. Still working fine
During another reassembly, I made a mistake, and...-
by ant3202Hi Everyone
Lately I am experiencing the deja-vu incident on one of the led monitor like this.
https://www.badcaps.net/forum/troubl...lashing-on-off
The monitor is HP 27es LED Monitor
https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
The monitor will randomly blackout and display no signal and will recover again.
Sometimes need to power and off again to restore the display but...-
- Loading...
